Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 29 Guests are viewing this topic.
unclejpl4x4
Quote from: 79Coyotefrg on April 12, 2006, 05:31:17 PM
not getting gas thru the aisin carb :down:
did U remember 2 put a fuel pump on :rofl:
burnyota
closer to bein done than you were before...got any more pics? :beer:
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
#423
its alive :woohoo:   :psss:  weber carb :cheese:
lilbuddy
Quote from: 79Coyotefrg on April 15, 2006, 08:11:30 PM
Woo finally. Lets hope this time it lasts for a good amount of time!
RIP Kyota.... you are the man
GET IT!!!
unclejpl4x4
Are we talking about  the cAt ? the lawn crawler ? or the truck ?   J/K       time 2 get that puppy muddy :yupyup:
its only front wheel drive,  i put a 85 front shaft in to get it moving,  it needs to be lengthened about 3 inches,
but i used a modified 2 peice shaft in the rear,  but havent been able  to get it welded yet
dual cases are KOOL MAN
burnyota
mmm....lawn mower.....get er welded up glen :beerchug:
:eyebrow:   i gotta get my welder wired up  :yesnod:
just hooked the welder up thru the utility room window to the dryer,  welded my drive shaft,  now im gonna go see how it turns :woohoo:
smooth as a babies butt  :woohoo:  no vibes at all
unclejpl4x4
sweet  what elas U got left ?
well,  now i need to lengthen the front shaft,  remove the rear bumper and add a different  mount for it  so it doesnt interfere with my shackles
Cool Glen, nice to have that 220v dryer.
yea  i had some weird looks from neighbors going past  when i waved at them from the side of the house with this big :moon: home made extension sticking out the window
:screwy:
i just started stripping the front end on the 86,  i think im going to put the hubs and vented rotors on my truck
did the 86  come with these vented rotors  or do ya think somebody added these aftermarket ???
BUBBA
Quote from: 79Coyotefrg on April 30, 2006, 12:19:03 PM
good thing I ain't got no neighbors or they'd be doing the same thing.I use my stove plug in,it's alot easier to get to,plus it's rated for higher amps.
My budget beater
Quote from: 79Coyotefrg on April 30, 2006, 02:06:02 PM
86 was the first year for the vented rotors, so yea they're stock.  You can't use em either, which kinda sucks cause I always seem to have some of them laying around, but never any fj40 rotors.
so i guess the fj40 rotors have a deeper dish to them :dunno:
:down:   anybody   gonna answer that :dunno:
toybuilt
I have heard that before but I do not know for sure
1983 Toyota Turned Chevy
skid
the fj40/60 rotors should have the same dish as the IFS rotors.  To use the IFS hubs, Sky manufacturing makes a spacer for the rotor.  Or I've seen people mount the ifs calipers to the outside of the knuckles, and use a nut and bolt after drilling out the threads on the knuckle.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
sounds like more work than its worth
skid
$100 for wheel spacers or $200 for rotor spacers?   I'm sticking with wheel spacers.  Simplest it the fj rotors on solid axle hubs, ifs calipers and wheel spacers.
Ditto, I see no reason to over-complicate things.  Simple=easier to fix.
IronClad
i say IFS hubs.   why ?  because  the hubs are designed to support the bearings in such a manner.  where as the solid axle hubs are not.   spacers + SA hub = more stress on bearings.
dude here ran 42" tsls on 2" bs wheels with IFS hubs.. never had a problem with bearings.
Annihilation  Fabrication
Do you need a Hammer?
42s yes, but for glen's 32s :dunno: can't see it being a real problem.
IronClad
he DD's it though.. when its running that is :P
so  thats why i see it being a problem
skid
Quote from: IronClad on May 08, 2006, 10:19:48 PM
Not sure I totally agree with that.  Your mounting surface on a ifs hub is the same as a solid hub with 1.5" wheel spacer.   The offset to the bearings should be identical.  I see no problems running spacers on a dd, if that's you concern.  Seen about 10 wheels come off from hard impacts/loose lug nuts.  Never seen a spacer come apart.
