Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 71 Guests are viewing this topic.
IronClad
Quote from: skid on May 09, 2006, 06:58:03 AM
Not sure I totally agree with that.  Your mounting surface on a ifs hub is the same as a solid hub with 1.5" wheel spacer.   The offset to the bearings should be identical.  I see no problems running spacers on a dd, if that's you concern.  Seen about 10 wheels come off from hard impacts/loose lug nuts.  Never seen a spacer come apart.
k you can think that..
Im talking about how the hubs are designed.   basicly a  SA hub witha spacer  your tire is "hanging" off of the mounting surface  and the support of the bearing in the case.
IFS hub  you arent hanging off of the surface and arent putting more stress on the bearing..
its all in how its designed
Annihilation  Fabrication
Do you need a Hammer?
IronClad
lol i had the same problem with my truck..  in the past 4 years ive gone through 4 motors lol
skid
#454
Quote from: IronClad on May 09, 2006, 07:01:40 AM
perhaps more leverage on the flange, not the bearings?
Either way, I've never seen a Toyota bearing failure due to wheel spacers, large tires or high offset.    Usually lack of maintenance or water
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
you forgot to get the [  at the front of the quote
well  for now  i'm selling all the 86 stuff
i did install the fan from the 86,  works much better since my fan clutch was really bad
:sofa:   nuttin  really new,  but i have this kinda whining sound   but goes away after the engine warms up :screwy:  oil pump :dunno:
AR80Toy
That whining sound is prolly from that girl you picked up down at the truck stop   :smack: !!!! Sorry man had to do that  :yupyup:
1983 Toyota 4-Banger Completely "Stock" For now ......HeHe
burnyota
Quote from: AR80Toy on May 23, 2006, 08:31:26 PM
:yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes: :yikes:
wouldn't that be more of a humming kinda sound :ladys-man:
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
4inchToyotas
No, that's a different whine...more of a nagging whine
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
brainlessfool
I put the FJ rotors on my 83 with out the use of wheel spacers.
40 rotors and ifs hubs :dunno:
oh well  today i chained the pass side motor mount, just in case,  and i gotta fint me some 1 1/2 x4 thick walled tube  ,i want to lift the body 1 1/2 - 2 inches to keep the tcases from eating my shift boots  :headshake:
FATB0Y
LMAO :haha:
KYOTA
Glen, FJ rotors and IFS calipers and spacers if you need them. Spacers get a bad rep because of a few failures, keep them tight and you'll never have problems with them.
cant afford either,  done sold the calipers  and i think the rear axle,  so i'll just keep it simple for now,
need to sell some ifs hubs though
SWAMPER
Glen foo you need to start you moon shining business again so you can have some mula :pimp:
Id do the spacers do it the K.I.S.S way Keep It Simple Stupid :slap:
i need to start makin some corn squeezins  to run the truck on :ack:
dang tailgate  pass side hinge broke off the gate,  so  i either gotta weld it back  or  drill and bolt it
Quote from: 79Coyotefrg on June 20, 2006, 11:20:33 AM
We'll call it Glen's Cornmash Fuels.
....and here's the company motto:
Drink it or put it in your tank, either way you'll get a kick.
Quote from: Rocksurfer on June 20, 2006, 11:27:22 AM
hey  :think:
skid
or, either way it'll give you gas?
well,  i used a BFH  to massage things back in place, and ground some of the rust of the rest of the tailgate,  didnt have my welder plugged up ,so i used rivets  instead,  seems to working nicely
sprayed a LOT of black rustoleum on everything and will put a couple layers of royal blue over that
man those front springs are doin great,   i need to redo the rears  and move my bumper  to get better rear flex :disturbed:
RK
thats a beefy front bumper ya got there glen..
Max
Black Hole Racing - 84 Jackalope/79 Devil Bunny/87 Golf - Service rig: 2012 Ram 3500
