Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 17 Guests are viewing this topic.
unclejpl4x4
Quote from: 79Coyotefrg on March 27, 2006, 07:43:55 PM
remember i have the 80 celica  :eyebrow:
:offtopic: U know what i always wonderd  if i could put a bowtie 350 in a 84 celica   i miss that rust bucket
i have considered a Cologne 2.9 ford and aod,  should button right up,  light weight  and man those little motors are HOT
alwayzbroken
I have a 425hp 454 I can hook you up with for that hotrod celica  :thumbs:
yea but i'd have to cut the fenders off to put that in there
alwayzbroken
C'mon Glen  :shake: You know real hotrods don't have fenders, or hoods for that matter.
MiniSimp
Quote from: 79Coyotefrg on March 29, 2006, 07:50:53 PM
Cut em then! :greengrin:
unclejpl4x4
well glen    cut out the fenders  and "tube it"   and if U realy need fenders  sheet metal
4inchToyotas
So now after the need for an engine rebuild and talks of tube fenders and such has this turned into the budgetless rebuild??..j/k, Ever decide what to do about the carb?
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
yea  im going to try the aisin carb from the 86 truck,  everybody says they handle the steep inclines way better than a weber, and i know the weber dont like anything past a 45* angle
of course since i have the duals  that will help
and no,  THEY were talking tubes and 454  not me :screwy:
skid
I've had real good luck with my stock carb. Dropped the float and vented the float bowl vent outside the carb.  I need to get a regulator though(wish list).   Seems to handle offroading better then a few weber's I wheel with.  The 38 outlaws had a little more power and response though.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
one thing i like about the weber is they are so easy to tune,  this things has like 10  switch hicky things :aaa:
BUBBA
What kinda fuel pump you running,pressure wise? On my old 79 i ran a 12 buck electric pump that only put out 2-3 psi. So i didnt have to run a regulator. Worked perfectly.
My budget beater
my 79 has a e pump in the tank
now thats what ya call a bent valve,  notice only on side of the bevel is shiney
Willy Mammoth
dang thing  wont post a pic
and i tried sending it to myself to resize  and i cant even do that  :thud:
lets see if it works again :eek:
without the proper equipment  a guy gotta do  what a guy gotta do
a drill, a big vise, a flat screw driver, a 4 inch file, some rags, fine and course grinding compound,  and a bench grinder
i first spun the valve to check for trueness,
good thing too cause 2 of the exhaust valves were bent
found some replacements  and cleaned them up  using the drill to spin them and the flat screwdriver on the top pushing down  helped the grinding and cleaned the face of the valve too
engine is together,  probably put her in tomorrow
unclejpl4x4
i aint got a engine stand as you can see
 :_order:
Willy Mammoth
Some of the best engines were built rolling around on the ground.
yep   ,  well it was on a door,  i wanted to go all new stuff but i HAD to get it running ,  so i stole the oil pump from the celica,  checked it and its in perfect shape so thats a $100  saved,  checked the length  on the 20R chain  and it showed no signs of stretch,  ( only run a few thousand miles)  so it went on  :crossed:
now all i need is to finish drilling the pinion flanges and weld the rear shaft
not getting gas thru the aisin carb :down:
