Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
does that pic open for anyone ??
#361
ok,  got the tranny/tcases in yesterday :thud:  almost got :heavy:  by the tranny,
i have a 85 front shaft for the front, i guess a long spline kit would make it perfect,  and im going to use the rear most part of a 2 piece 86 2wd auto shaft and the slip splines from a 86 front shaft  for my rear shaft
also i made some solid spacers for my L43 shifter mechanism, to take the slop out of the side shifter
yea,  so it opened for you :screwy:
JanMarie13
Glen's spacer material  (yeah, I was helpin him with his truck....haha)
RIP Kyle, we love and miss you man.  :smooch:
Quote from: KYOTA on October 03, 2009, 10:33:31 AM
thanks for the smooch I miss you too !  :yesnod:
i used that spacer thingy from the rear of the diving board spring, cut a couple of pieces  around 1/4 inch thick/wide,  and fitted them over a couple of the double washered 10mm /14mmhead bolts and installed them into the shifter hole were the rubber washer things usually go,
JanMarie13
see attached "thingie"
:rofl:  thingy :rofl2:
notice the metal spacer/sleeve in the lower part of the "thingy"  ::)  girls :smack:
next should be the finished drivetrain pic
JanMarie13
tah daaahhh!
unclejpl4x4
:popcorn:
when will that be showing up at my door ?
Very nice there Glen, uh Mrs. P, uh Glen.  :gap:
DTB
Looks like someone's been a busy bee!     good job, im jealous
Quote from: 79Coyotefrg on March 27, 2006, 04:19:54 PM
what happened to my pics :headscratch:
Whoa!! that's weird?? Oh Mrs. P what are you doing
i was about to have a serious :tantrum:
:eek:
anyway,   im thinking of running a stock 22 carb  so my uphill runs dont have to be 1/2 throttle or more
unclejpl4x4
just get a Turbo  or a supercharger  they look cool!!!!!!
4inchToyotas
What did you end up using for the bloack? I got confused? Stock 22r block or bored 22r block?
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
i had the .060 block checked,  it has no cracks  but the head i had was screwed  so i am going to run a ported 22R head  and im thinking just a 22R stock carb  for hill climb dependability
I like my stock carb, it hasn't really failed me.  But i don't know much about aftermarket carbs.  I know i wouldn't spend money on an aftermarket carb, i would just go propane or EFI.
the one i have is a 22r aisin carb  and intake,  from a 86,  im going to use the 22R head  so if later i find a efi   swap  in my future i dont have to change heads
when i was at gilmer   on the hill climbs the weber  couldnt handle it at all i had to keep a foot on the gas all the time or it would die and wouldnt start very easy either
4inchToyotas
are you running a pressure regulator?
4inchToyotas
The guy that is helping...er that I'm paying to do my build made me put one on my Weber and he also runs one on his and he's been running it for over 5 years and looooves it even if it is in a FJ40 F motor
alwayzbroken
Quote from: 79Coyotefrg on March 27, 2006, 07:20:45 PM
Do you have a 22r head? I have one for very cheap that needs a valve job. I have a 38mm mechanical secondary Weber that I can't get to run right also.
i'd love to have the weber,  and yes i have 3 22R heads
remember i have the 80 celica  :eyebrow:
