Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 88 Guests are viewing this topic.
yotaboy79
wow so yours probably is uglyer than mine lol
uglier  , man i aughta :bat:  jk  yea it looks pretty good  just made it one big hole instead of 2,   i got a pic with my cheap camera, we'll see if it comes out
yotaboy79
lol im just saying every time ive tyed to cut a round hole with a cut off wheel it didnt turn out round :_oops:
me too thats why i made it square
ok today i went to put my rear shaft in and the dang tcase flange had the small holes :thud:   out comes the drill
well the head is on and torqued down,  intakes on,  i'll probably fire that baby up today,
then drill out the tcase flanges for the larger bolts like my shafts are allready, thinking about the grade 8 12mm bolts but i like the toyota drive shaft bolts,
man is it hot, 97 with 70% humidity  :thud:   i hope it will :rain:
it reached 107* here today actuall temp, heat index of 118
but by jiggy,  i sat the carb on the intake, no bolts, hooked up the dist and put plugs in poored a little gas in carb and hit the key, i figured it would pop and sputter,  :smack:   the pregnant dog ran  :horseride:  apparently ive dont this so many times even in 100* heat i timed it perfect the first time,  i couldnt believe it ran, well for like a minute,  but it surprised the crap out of me,
dam im good  :clap2:  :eyebrow:
Ramrod
lets see it and lets see some burning rubber. I think I am going to be doing a build up like this soon I am thinking .40 over, stock crank & rods, ported head, ported intake, thorley header, bigger ss valves,comp cam.  How bad do you think the stock carb is going to hold me back.  All I want is to be able to hold 75-80 on the flat ground.
FATB0Y
well the stock 22 carb should flow enough to handle the extra flow, you want a 1 1/2 inch header tubes  and 2 1/4 exhaust,  my cam is a stage 2 LCEngineering race cam,  thats 12mm of stroke at the valve stem,  i'll get some burn out pics after all the bugs are worked out
i have pics RJ  i just dont have them on a disc yet so i can share
i installed the header last night,  just got done installing the carb,  i'll go back down in a bit and get the #2 alt installed and the radiator and fan
FATB0Y
Quote from: 79Coyotefrg on August 23, 2005, 09:34:24 AM
That is a piss poor excuse :yupyup:
Quote from: Willy Mammoth on August 27, 2005, 07:32:30 PM
:headscratch:
:dunno:  almost seems like there should have been something else there huh Mark
well the #2 alternator is installed
now all i need to do is get the bolts all tight
today i managed to rebuild the other rear spring
top 2 toy leafs*=======*
then a chevy    ---------------
then 1 front leaf-------------
3rd toy leaf        -----------
then my add a leaf--------
divingboard          --------
oh crap,  no it was the top 2, then chevy, then 3rd toy, then 3rd stock front leaf, then blackdiamond addaleaf, then divingboard
ok today i got the brackets for the a/c compressor and #2 alt figured out, i'll have to make another adjuster or modify this one   so it will be long enough
got the radiator cleaned up and ready to install tomorrow
i was going to use the big electric fan from the plymouth mini van but the motor interfered with the waterpump
That's great, but I think you
RHG
 :headscratch: Someones on crack! And someones name is BigMike. Your supposed to finish typing before you hit the post button. I thought you knew that ???
brainlessfool
Quote from: rocks hurt good on September 05, 2005, 05:18:34 PM
I don't see a problem, if you ask me I
brainlessfool
it  runs,  gotta get a lower radiator hose , bolt the seat down finish mounting the cb
worked on the new torque rod mount , i'll get some pics of that :hyper:
stick it with a fork baby its DONE
 :attention:
                                                     :worthless:        :biggthumpup:
BUBBA
My budget beater
waiting for mark or diane to post the pics and small video they made last night so yall can hear   that baby
reklund5
Glen you need a digital camera.  I've got an older HP 1.3MP camera I never use....want it?
Ryan
