Dingman's Build Thread
Started by Dingman., March 01, 2009, 08:42:37 PM
86bobbedtoy
Dingman.
Stupid windshield bar broke so the motor wasnted connected to anything.   Got to drive home from damn near spring valley with my arm out the window removing water..
Dingman.
Dingman.
Sorry about the photo quality its from my iphone.
Dingman.
86bobbedtoy
P-DiseToy24
someone wanna buy some shackles???? haha
good pics man!
yota_krawler
Update? Lol just read your "cliff notes" it ain't the same as it was lol
Dingman.
Dingman.
Sooo went wheeling today..  Well attempted to...  Way tooo many stuck people so ended the trip early.
Anyways had to tow a buddy home cause he possible toasted his cases.  Truck would not move, making noise earlier, etc..
Got him home and he spots that my front diff is pouring oil out.   Soo it appears a damn ring gear bolt backed out and punched multiple holes in my front housing.
So at this point im looking for a new front 85' housing, possibly gears, setup kit, and hopefully there is no damage to my arb nor my high pinion housing..
Shitty trip.
86bobbedtoy
Quote from: Dingman. on February 19, 2011, 04:00:53 PM
Shitty trip.
man if I were you Id giveup on toy axles!
I have never heard of anyone with as much bad luck as you!
on diffs anyway, you Fn kill them, seriously!!
ill keep an eye out for ya.
you poor ba$tard, lol
Dingman.
I honestly think ive only broken a set of gears by themself.  The rest of them have been because of stupid bull crap reasons; locker breaking, ring gear bolts backing out (two diffs cause of this, and stupid welded ones breaking.
I blame myself for buying used diffs.  The rear one im driving on right now, that my boss showed me how to setup is done correctly, and its been the only diff that i have run except for a stock 4.10 that has been quiet.  Which means all the other used ones i purchased were improperly installed.
Dingman.
yota_krawler
ya i am! part out what you got and do something else
you are to diffs as thomas is to cases.....
Thomas P
but then he will need bigger tires and then wont have a streetable rig.....
'14 Camry SE
SCX10 Honcho on roids!
yota_krawler
why would he need bigger tires? im not sayin 1 tons, there are alot of options out there other than toy axles and 1 tons
Thomas P
'14 Camry SE
Thomas P
what dana 44? how is that better than toys with longs?
'14 Camry SE
Thomas P
'14 Camry SE
yota_krawler
Thomas P
what he has is sufficient for his purposes, he just needs properly set up equiptment
'14 Camry SE
Dingman.
I am not going ton's.. Not anytime soon either.
This came down to not being setup correctly (once again). Nothing to do with my driving style.  Ring gear bolts dont back out for using the skinny pedal.
I will buy new :pokinit: and setup myself and not worry about it again
Thomas P
btw thanks for the tow mike!! we were gonna call jasonC and have him tow us on the trailer but you just never stopped.....
'14 Camry SE
yota_krawler
and if you wanted to go there, you can actually build a pretty beefy dana 44. rcv's, rebuildable ball joints, dana 50 ring and pinion conversion, 6 stud knuckles.....
keep the yota axles I dont give a :pokinit:. It aint my truck, he just has shitty luck with the diffs. Low pinion, hi pinion, 4cyl, v-6, welded, open, pro set up, set up by himself etc etc....
Dingman.
That 3.4l has some balls.  Maybe small japanese ones :haha: but it did do 45 mph, damn near all the way back to your house once we got on the roads.
Thomas P
good call on that mike, your front axle should never have to be touched again after that, ill work on getting my garage cleared out and get you a space if you waznt, and you can also drive my 2wd if you want until you get your junk put together
'14 Camry SE
Dingman.
Thanks man.  Im not super worried about it right now.  I pulled my driveline off and drained the last remaining fluid out.   I was going to pull my diff and look at it but i didnt feel like doing it laying in the snow at my house.  At least i still have 2wd for the time being
lilbuddy
Quote from: Thomas P on February 19, 2011, 10:49:04 PM
I got 1tons 40s and a streetable rig
Talk about shitty luck on the axles mike.
RIP Kyota.... you are the man
GET IT!!!
P-DiseToy24
x2 on that fucked up man I drove on that front 3rd for days and so did the dude I got it from that thing lived through years of wheelin on 44's 39's 38.5... even reds and still never not a problem you have it for like a year and you go and trash it all up... haha Want to buy my old housing with the 6 shooters ill ship it to you for 375
