Dingman's Build Thread
Started by Dingman., March 01, 2009, 08:42:37 PM
Thomas P
Yeah Chris your rig is very streetable but pushing the limit how was your trip up anyway????
'14 Camry SE
SCX10 Honcho on roids!
lilbuddy
Quote from: Thomas P on February 21, 2011, 07:28:02 AM
It was dumb. We waited for 45 min and no one moved so we messed around on yh way back and then went down powellton. The snow was dialed down lower and we pretty much broke our own trail.
RIP Kyota.... you are the man
GET IT!!!
Dingman.
Nice..  Least you got a little bit of fun in the day lol.
Hopefully next time there wont be so many people blocking the trail
P-DiseToy24
Shoot i'll give you the Dingey special at 300 to your door..  :deal:
Dingman.
I appreciate it kasey but im going to have to hold out for right now. I dont have the money for that at the moment.
I was just gonna tear apart my axle and inspect the damage but our damn floor jack is suddenly broken.  So im apparently going to have to buy a new jack on top of everything else
I might just weld the holes shut and run it.  Im on a really limited budget.
yota_krawler
Take off the damn "looking for a v6 carrier"
Tear it down and we can weld it at my uncles so your not using fucks core
ToYocRawleR
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
Dingman.
Well its been snowing up here and the power has been out all day.  Pretty lame.
Dingman.
Look what I got today :greengrin:
Gonna pick up a new axle housing soon and I'm trying to collect parts for duals
Anyone got any deals on a top shift case?   I still need to source two and buy everything but drivelines.
I need to call Marlin in the am.  They sent me a 21 spline coupler instead of 23 I ordered
86bobbedtoy
Dingman.
Dingman.
spc mike
Hey Dingman, I just got my dual case adapter too but the first one i got had a fracture around the bottom bearing recess edge. You might want to check yours to see if there is any imperfections. I say that because even the second one Marlin swapped me for had a little crack as well but  the first one was pretty bad.
Here's a pic of the first one
Dingman.
Dingman.
#916
Your crack was pretty bad. Mine looks Good.
The most I have is tiny cast imperfections Most likely not a problem at all I would think
84t0y
sick man finally getting duals. btw I live in chico now so we should go wheelin sometime.
IronClad
hey mike nice on the adapter ! bout time you are going duals. no idea on a case though but pretty much anyone i would know you would know aswell
Annihilation  Fabrication
Do you need a Hammer?
Dingman.
I may have a line on one from a first gen truck.  Hopefully that will be alright.  I'm not really sure on what year top case is best to use.
Dingman.
As of now I'm just planning on two stock cases.   Unless I get the urge to drop money for a 4.7 gear set.   Its not like that matters now anyways since everybody is sold out..  but I will have to buy two 23 input gears and Marlin is sold out which is unfortunate.
Dingman.
Quote from: 95t0y on April 07, 2011, 04:09:40 PM
When did you move back up here?
84t0y
Quote from: Dingman. on April 07, 2011, 10:03:04 PM
couple months back been broke as :pokinit: so i havnt gone wheelin at all and i really need to change the clutch before i do. but now i have the money for the clutch so ill be able to go wheelin pretty soon.
Dingman.
#923
So i spent the evening fixing my front axle.  Might be amusing to you guys also.
After work i headed home, jacked the truck up and started dissembling everything to pull my diff because i wanted to be able to order gears from work tomorrow if i needed to.  Pull the passenger side apart and it went smoothly, other than fighting those cone washers which was weird because i never have a problem with them, but when i pulled the driver side knuckle off my upper trunion was rusted or all corroded, im not really sure, so i had to replace that one. pull the diff out expecting to find that one bolt that backed out and punched the holes in my axle, and to my surprise.......................................
That was how many bolts were floating around in the bottom of the housing.    :yikes:
And to my surprise my ring and pinion looked untouched\
As you can see some of the holes got kinda messed up, but i just hammered the raised parts back down and lock-tighted EVERY bolt..  Its amazing people don't use lock-tite in the first place.  Then welded the holes in my housing
shut and assembled everything. Yes thats pretty ghetto, but.... im gonna run it, cause i sure as hell am not going to pay 700+ on another arb.
i have 4 wheel drive again!   :yesnod:    well technically 3wd cause the rears open. lol
86bobbedtoy
Dingman.
Just got done fixing my oba so that works again and got a few new led rocklights gonna mock them up and ill get pictures. Brighter than the vision x tantrum kit I had which doesn't work anymore.  :thumbdown:
86bobbedtoy
hay were all rollin to the shooting range here in oroville, sunday
you should roll
Dingman.
Damn man I haven't gotten anymore ammo yet.  I need to order some asap.
86bobbedtoy
well come out and shoot our shiz
go look at my ar thread
