The Mossy Runner build
Started by Mossyrocks, July 02, 2008, 05:34:50 PM
kiyul4130
coilovers, atleast in the front. im sure in the rear to, BUT i could be wrong...
-kiyul-
ECV 7-11
KYOTA FOREVER
Mossyrocks
16" coilovers front and rear.
Mossyrocks
Small problem with clearance.  The shock can go up 3 or 4 inches but the damn tire sure as hell cant
FRENCHBLUE72
Bad azz :bowdown: I really need to stay off this board as my ride is gonna be cut back apart if I keep reading these killer threads...
82 YOTA
Mossyrocks
well heres where the shock is but the other side cant droop all the way because of the tire.  if that makes sense.
And heres the tire...
Here is what I mean about the radius of the wheel well.  It will look really bad if I keep goin up behind the door.  You cant really make it round, itll have a big hump in it.
Mossyrocks
damnit i wana use it all...  haha
havik
this thing is so sick i am going to have to say its my fav runner build and fo show one of my fav builds on this forum. good work.
i wouldnt mind rubbing my hands all over that front axel. no homo
got another 85 runner. build coming soon!!
Mossyrocks
just workin on the rear air bumps.
And, I might cut it off, cut out the frame, and outboard the coilovers as much as possible.  It just seems like with it flexed it will just pivot off the coilover as opposed to compressing it.
TIMS89CRAWLER
I love this build  :love: lookin sick man..... I want coilovers soo bad  :rivers:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
gotrocks
What fuel tank are you using.  Is it a ford tank?
Mossyrocks
Alright, here we go...  46" apart.
gotrocks
that separation looks a lot better
what you guna do to the frame?
Mossyrocks
Quote from: that HO kid on September 14, 2008, 05:58:38 PM
Haha, well Im not sure yet.  I might get to it tonight though, Ive been working on the bumpstop pads.
TIMS89CRAWLER
lookin good bro, lookin good!  :beerchug:
www.choptechfab.com
CHECK THE BUILD
Mossyrocks
the rear housing is almost done.
Just have to gusset the upper link truss towards the back
Jordan7118
You've gotta stop doing such nice work, cuz I won't be able to afford both Rick's Tuki and your 'Runner when it comes time to buy them  :talkingn:
Looks dang good, man! Glad to see you're still making progress!  :beerchug:
Mossyrocks
Its holding itself up....
Its sitting at a frame height of 24.75" front and rear.  But thats with the coilovers threaded all the way up.
Front springs are my 250 over 350 and feel a little stiff but without the front bumper.  the front corner weights are 1750.
I used Chris's springs for the rear because mine were too much.  So Ive got 200 over 300 in the rear with each corner weighing in at 1150.  It feels perfect but its a little tall.
So I may try 200 over 350 up front and 175 over 300 out back.
Mossyrocks
Im paintin the damn frame tonight, DONE.... done done done.
nice work on that frame... you worried about that being a weak point?
Mossyrocks
a little bit, but it shouldnt be.  its cut right between the coilover hoop legs which are part of the cage.  and then there are two more cage mounts behind it on either side.
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
gotrocks
Quote from: that HO kid on September 17, 2008, 01:31:16 AM
I wouldn't be to worried about it because most of your frame stress is before that point since you have a linked setup.  I'd be more worried if it was a leaf sprung rear because you'd have the torsional stress of the leaf springs when flexing.
Mossyrocks
Workin on the belly pan.  Ive got the whole frame done, just gotta pull it out and weld what I couldnt get to...  Then its time to add the plate, that I probably dont have.
It also braces the rear xmember.
And I also added another tranny mount, I dont think there is gonna be anymore drivetrain slop.
