The Mossy Runner build
Started by Mossyrocks, July 02, 2008, 05:34:50 PM
Mossyrocks
Mossyrocks
rough cut for the rest of the frame.  Still have to make the clean final cut.
The true Hi9 with ARB
And the spider housing.  Im waiting on the bearings in the freezer so Ill get a pic of the knuckle together later.
slabcs
Relentless
46&2
Sweet, this should be good!  :popcorn:
AaronB
what is a high 9? dana 60 with a 9" center
Mossyrocks
Well the High 9 is just a high pinion 9".  True Hi9 is just a built diff and technically this axle is called a 609, 9" center and 60 outers.
Mossyrocks
Well, the frame is back, sorta.  Im gonna plate it from the front to the body mount.  Things should start progressing a little more quickly now.
Busted a fuel line, could of sucked pretty bad.  But :pokinit: happens, gotta replace that now too.
Old frame capped, and the new piece all welded up.
Mossyrocks
I decided not to plate all the way out.  Its already 3/16 wall tube so I just went a little ways past the joint.  I really didnt want new brackets to land off center of the rosette welds or anything like that.
Cut all the crap out from under the headlights and removed the body mount.  Now I can put the steering box anywhere I want.
And here are the new body/ radiator mounts.  They definately sturdied it up more than I thought they would.  The fenders will have new mounts later on as well, so it shouldnt lose any integrity.  If anything itll be a good bit more ridgid.
NorCalToy
holy good go dude! what are you planning or this thing!?!
:flamer: IFS
46&2
Looking sick man, very nice work  :beerchug:
Mossyrocks
Quote from: NorCalToy on July 03, 2008, 10:08:13 PM
I got tired of screwin up leaf springs so Im goin with a 3-link front and 4-link rear.  I only pulled the rear 60 to get regeared, Im still debating on goin to 40s or not.  Ive been running 37s but would like a little more meat, maybe even 38.5s.
Mossyrocks
heres one of the reasons
The shackle got shoved backwards and ended up folding the leaf over.  It got worse after this picture.
slabcs
How'd you fix that out there?  That's been a fear of mine for a long time now.
Relentless
Mossyrocks
Quote from: slabcs on July 04, 2008, 12:37:37 AM
We high lifted it up and kicked the shackle back out, then set it back down and drove home very slowly.  1 week later went to morris mt. and bent the new one, but at the front of the spring this time.
DTB
  :haha: :boozer:
That cage is tits! Looking sharp mossy
Mossyrocks
first of many cuts, all I needed was a 550 dollar mistake.
and here she is almost fully assembled.
lucky7
46&2
unclejpl4x4
dam thats sick   :beerchug:     can't wait 2 see more
Mossyrocks
The motor mounts are in finally.  I still have to box the top of them, but Im just unsure of what I wana do right now.
The mounts on the motor are from Ors and they are beef, little pricey but Ive got more crap to deal with and cant waist time making them.  And then I made the frame side.
porkchop
looking damn good man those welds are rocking also we are going to Windrock sunday you should come with us.
85 TRUCK AUSSIE IN FRONT LINCON AROUND BACK MARLIN 4" SPRINGS UP FRONT WITH 63 CHEVYS ON BACK. REBUILT 22R WITH CRAWL CAM AND FEW OTHER THINGS NOTHING HUGE JUST WAITING TO GET PROPANE ON IT. RUNNIN 35'S M/T WITH MY LONGFIELDS 30 SPLINE SUPER AXLES. 4.7's IN T-CASE AND ON THE WAY WITH DUAL CASES. FULL HYDRO WITH TG ROCK ASSULT PUMP AND 2 X 6 AG RAM
Mossyrocks
Quote from: porkchop on July 10, 2008, 07:20:40 PM
Man Id love to, but Ive been working non stop so my ass is goin to the river to drink beer all day.
Mossyrocks
Got the motor mounts boxed this morning.
Full compression puts the diff 3/8" from the oil pan and puts the frame 21.5" off the ground on 37s.  I could move it forward a little and gain some but thatll probably be good.  Or even notch the oil pan.
Mossyrocks
got the lower link axle mounts done today.  And then the thinking process with the tires started.
This is sitting at a frame height of 24.25" with 3" of vertical compression.  If I move the axle further forward its gonna get friendly with the headlight, any more back and I lose oil pan clearence.  Im 50/50 right now on sending these back for 37 12.50s.  Id just like to be a little bit lower if I could and these are taller than I expected so Im thinkin Ill lose a lot of streetability with them.
I mounted one to see what it did on an 8" bl with air in it.  It made it a little narrower as I was hoping, but it also rounded off the top.  They may flatten out once they're broken in though.
unclejpl4x4
hats some nice stuff you got there.
what U did 2 the frame is what i need done.
NorCalToy
are those the 38.5s previously mentioned? how would the streetablility be anyways considering its a comp tread?
:flamer: IFS
Mossyrocks
they arent the competition compound, just the standard bias ply.  It wont see many miles on the road, its just that when it does I dont want it to bring the suck.
