85 4runner and the work never ends....
Started by John Doe, June 15, 2008, 03:54:11 AM
John Doe
I had a twin stick on the rear case and the single stick on the crawl box. Now all 3 sticks are on the crawl box via linkage from the rear case. This frees up the space so I can have a center consual/ arm rest again.
85_4RNR
Quote from: THK90 on December 14, 2009, 02:29:33 PM
why u need a triple stick? whats it do.
only heard of a twin stick
X2
I work a 2000 BMW 540i 6 speed
Quote from: John Doe on December 14, 2009, 02:35:26 PM
we need pics of this man
85_4RNR
John Doe
I am guessing you mean the linkage and not the center consuel?
peacesells
Lookin good! How do you like the triple sticks so far? do they seal up properly? I would really like to get one of those setups for the same reason, sucks not having center console space!
this my man lysol, fresh out the joint
John Doe
Today was my longest drive with it so far and I am hearing some things that are making me  :headscratch:
It might or might not be the T-case/ crawl box I have to look into it. I know I need to adjust the links a little. So far I like it. I made sure to use alot of RTV when installing them so I dont think there was a problem sealing. I'll know in a day or so when I pull off the tranny cover and take a look at a few things.
Jakesteads
pics of triple stick!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I like Toyota
John Doe
See what happened was..... Yesterday on my way back from Houston I noticed something off, a vibration and rattle from my under carrige. I made note of it and went to bed. On my way to work this morning I looked into it closely and I found that the U-joint at the rear of my rear drive shaft was toast! I spent what little time I had this afternoon changing it out.
I learned a big lesson from all of this....
-Drive shaft 101: I learned to make sure to align or key the drive shaft when re installing it. Apparently when I removed my drive shaft to install my transfer case I re-installed it out of alignment. Make sure you install the drive shaft straight  :smack:
I am going to do my best to get some shots of the triple stick linkage before Saturday. If I dont have them by then you will all just have to wait for 2 more weeks while I go back to cali for vacation.
PhantomD aka Zach
found this searching for shifters... did some research into triple shifters... thought you might like this picture...
http://www.drsmash.com/drsmash1.html
-Zach
3rd Gen Extra Cab, Dual Cases, E-Lockers
John Doe
That is almost exactly what I have. Mine is just slightly different sinc I have a rotated adapter. The main difference is the linkage is at a angle but other then that its identical.
axled89
i love oregon wheelin.
John Doe
#224
I got some more small things done lately. Aux fuse box installed in the engine bay. Wired up 6 led rock lights. New seats and 12 volt guy switch panel for in cab winch and aux lights. Like usual I forgot to bust out the camera during the work. I took 3 pics at night of the new rock lights, but with my flash you cant see anything. I'll get back out tomorrow or Friday and get some new pics.
I have to thank Volcom, I used the same plastic box from Radio shack that he used on his build. Thanks  :thumbs:
1 of the rock lights
some of the changes to the interior
You can see the new electrical work
John Doe
Anyone know of a rebuild kit for the ifs steering box? Mine has been leaking lately.
Jordan7118
Quote from: John Doe on January 21, 2010, 04:43:20 PM
Hit up the Pirate4x4 FAQ. Lots of good info. in there...
Rebuild Kit - http://www.pirate4x4.com/forum/showthread.php?t=587519
Rebuild Steps - http://web.archive.org/web/20050322011020/http://128.83.80.200/taco/box.html
Hope that helps!
John Doe
John Doe
John Doe
Got my new bumper and winch installed!  :greengrin:
I still need to wire and mount the control box.
yota_krawler
bigarms23
it looks like it came from davez offroad
John Doe
The Bumper came from Davez
No guess as to whats on the pallet?
GJToyotabug
my guess some sort of v6 or v8 i would hope a toyota motor
Jakesteads
nice 12v guy ash tray panel i have one too fits so good
I like Toyota
zippo
Im guessing a smaller wooden pallet. Can never have enough small wood pallets around the garage.
If you see it, its for sale.
axled89
nice winch and bumper combo.   :eye: :eye:
94KRAWLER
sick runner. what seats did you put in it?
