85 4runner and the work never ends....
Started by John Doe, June 15, 2008, 03:54:11 AM
John Doe
Quote from: Wermz84 on September 21, 2011, 01:39:31 PM
Good seeing your rig in action on the trail!   :beerchug:
Was that a canvas bag on the back for trash? or just a logo?
The bag is a re usable trash bag that my girl friend made. I had at least 6 or so people asking where they could get 1  :)
Quote from: MiniSimp on September 21, 2011, 01:47:06 PM
Got some of you on Sluice
The sweet trash bag!
Thanks Mini  :beerchug:
Wermz84
I like to Drive!
Wermz84
I like to Drive!
John Doe
A few more pics from MCR while I wait for my rear shafts to come back from getting straightened.
GloNDark
How do you like your Goodyear MT's? I'm on the fence after tearing a sidewall on my 37" old style MTR and not being able to find a replacement. Got a great quote on a set of 37" MT's on recentered hummer wheels.
Truck looks awesome!
John Doe
They seem to be as good as my old mtr's but way cheaper.
88Rokyoat
Quote from: John Doe on October 13, 2011, 02:08:10 PM
I have been looking at those tires also. Looks like you are running 16.5s beadlocks? Did you get them from trail worthy fab on pirate? They seem to have good prices on the whole set up. How are they on the highway?
stupid people shouldn't have kids.
John Doe
I did get them from Trailworthy Fab. The only issue I have with them is weight. They are very heavy and my little 22re gets bogged down when heading up I50 to get to the Con. However a little added up sprung weight when on the trail is never a bad thing. As far as road noise they are not much different then the old MTR's I had.
88Rokyoat
John Doe
Well I spent a good amount of time working on my truck at the shop today.
Ran into a few issues that slowed us down. But progress has been made and it looks good!
John Doe
After a few slow downs my Runner is back on her own rubber again.
It seems though that the drivers side birfield has a cracked cage :( So I will be tearing it back down t check on that.
zebracrawler
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
John Doe
not my shop. I would not have gotten this done as nicely with out the help of Steve at http://goldenstatemotorsports.com i have a bad back and cant do all the heavy lifting anymore. Steve has been a great help.
Shamb
who welded those tab's on the front axle?   they need to turn up the heat a bit on those welds!
looking good though   :thumbs:
redrocket93
Any updates? I saw you cruising this thing down Baseline the other day. Looks way sick with the new wider stance. You wheeled it yet?
John Doe
I havnt wheeled it yet. It turned out the drivers side birefield was going bad when I 1st put everything together. I got it swapped out last weekend and now it almost sounds like the passenger side is a little bad but not nearly as bad the the drivers side was.
I flexed it out on top of an old MR2 the other night my front shocks are currently limiting my front travel.
If your free this weekend I can stop by and let you take a look at everything. I recently moved out to Elverta and my buddy gave me free reign over his 2 car garage :D
John Doe
Iam going to try and take a few pics this weekend,any requests?
*** YELLER ***
except BACON
John Doe
#350
Well I have been working on a few small projects lately......
-new dash lights, fixed the fast Flasher http://www.pirate4x4.com/forum/showpost.php?p=9365528&postcount=1
-replacing heater core
-relocate ECU
-OBA with York
I still need to order up a gasket kit for the York. Any one have any suggestions on what psi Pressure switch, or what size air line to use? Anyone looking for air tanks to run with OBA, look up a tool repair shop and ask them. I got a great twin tank set that holds apx 4gallons of air for less then $20, had to talk him down a little :D
88Rokyoat
I usually just use 3/8" hose. Right now I'm using a 85-100 psi switch, if and when I get ARBs I'll change it out. Basically just putting this one because I have it, and it will keep from blowing lines off...
John Doe
I have looked at all sorts of info and this info was never really covered. So what I am currently looking at: http://www.amazon.com/Viair-90007-Air-Source-Relocation/dp/B000YC42RQ/ref=pd_sim_auto_6 and http://www.amazon.com/HornBlasters-90-120-PSI-Pressure-Switch/dp/B0043XDLEM/ref=pd_sim_auto_1. I am running dual e-lockers so I wont have added pressure to worry about from ARB's.
redrocket93
Nice! I'm working on a York OBA conversion and 100 amp GM alternator swap right now as well. Just scored a York at picknpull last sunday on half price weekend for $17. Those pressure switches look like they'll work out good.
Have you seen this manifold. Seems like a lot better that cobbling some T's together.
http://www.northerntool.com/shop/tools/product_13795_13795
I'm going with this safety valve.
http://www.northerntool.com/shop/tools/product_200397374_200397374
John Doe
That manifold looks good. I hadnt yet looked at northern tool much. For fittings I thing I may get this http://www.4wd.com/prodDetail.aspx?partno=V%2fA90006 It could atleast save a few bucks and give me a few pieces I know I'll use.
What are you planning to use for huse?
redrocket93
That's a good deal for all those fittings. For hose, I'm just gonna use some goodyear air hose I have laying around. I'll probably just start using it without a tank and see how it does. It'll only be used for airing up only. I carry a cordless impact, drill and grinder so no need for air tools.
John Doe
For starters I intend on only using it to air up, but may use tools later
John Doe
Are you just replacing your  current ac comp with the york? Have you built your bracket yet? Your running a 22re right?
redrocket93
Yeah I got a 22re. It doesn't have A/C so I'm just gonna make this bracket.
http://www.pirate4x4.com/forum/showthread.php?t=236027
Probably gonna get my buddy to cut it out on his torchmate. Might just bust out the drill and band saw make it myself. Looks super simple to make.
John Doe
Quote from: redrocket93 on January 18, 2012, 01:45:36 PM
I've got some 1/4" plate I can donate for a 2nd bracket  :greengrin:
