A.J.'s Runner - "Please Stand-by"...Product Review
Started by CTENG in KS, July 14, 2004, 01:22:37 PM
6.72:1
You are always the one to bring the nic-nacks!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
FatAzzRunner
I would be interested in doing it this weekend.  If you are POSITIVE that you are gonna do it this weekend, let me know, I will make the phone call to the land owner and make sure he will allow us on this weekend and then we can go.  I work 3rd shift so it would either have to be  Saturday after 2:00pm or Sunday about anytime, I am off on Sundays so I dont care about messing up my sleep too bad.
Let me know and I will make some phone calls.
Aaron
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
CTENG in KS
Got the turn signals taken care of.  These stupid little LED lights are designed HORRIBLY.  Whatever, I made em work.
CTENG in KS
...and once I extend the links about 4 inches I won't have to worry about tire rubbing the sway bar arms.
CTENG in KS
In order to make the arms clear in their new location I had to make a small adjustment, I think it really added to the look of the front end.  (ignore all the tools)
6.72:1
This thing is turning into a battle beast!
[email protected]
CTENG in KS
I got about 1/4 mile into my friggin test run and the timing chain started making the most horrific sound.  I turned around and sure enough, by the time I got to the garage the coolant was boiling.  Tomorrow I will be ordering a new timing chain kit, timing cover, and a new water pump.  sniff, I hate my truck right now.
BLACKDOG
Quote from: CTENG in KS on July 12, 2006, 05:54:34 PM
:therethere:  I know how that feels :down:  don't worry, you'll get over it soon :yupyup:
              -Ronald Reagan
CTENG in KS
I am starting to feel better.  Gonna order parts in a couple hours when stores open.  Will try to get it running maybe for NEXT weekend.
rednk1980
timing chains blow, i had one go on me in the mountians on a wheelin trip and had to get towed out. bent my valves all the hell! NO BUENO!
CTENG in KS
Yeah, chain didn't break so valves are ok...I hope!
Ordered up the parts, should be here Mon-Tuesish.
CTENG in KS
My parts came!  Too bad it is 109 degrees today...forget it, not going out there.  I sent them over to quality control for inspection:
6.72:1
[email protected]
CTENG in KS
After a grueling hour and a half in the hot-dark garage this evening I am about ready to pull the cylinder head off again.  I wanted to post up abut the LC Engineering EGR block off plate though...
I got these cause they were on sale last month for $17 and this is probably the nicest thing I ever bought for $17.
These things are cut perfectly, it comes with new hardware and everything...I can't believe the kit is that cheap.
6.72:1
[email protected]
FATTshack
did the timing kit pass inspection?
CTENG in KS
unclejpl4x4
woW KS   your engine is gona scream with such a nice support/ R&D team backing you up :rofl:
hay is all your engine coponets painted black ?
CTENG in KS
CTENG in KS
I was a bit sad when I opened the cyl head cause it seemed pretty dirty...but I finally got it out to the garage and next tothe old one it is clean enough to eat off of!  This time I got a real good straight edge to check the deck and it is straight as an arrow.  I got the second piece of the EGR plates on...looks pretty!  On the second pic-the kit came with three plates and hardware for two.  Did later model intake plenums have a different shaped port and this kit covers all years, or is there another hole I need to plug?  In the first picture, what are the round coiled green things?  I have some from multiple gasket sets, but have no clue what they are.
Last question for now:  Do 22r(e) heads use cam bearings?
Shamb
I thought you just got done rebuilding this engine?
Rockdiver
Quote from: CTENG in KS on August 14, 2006, 08:23:37 PM
what are the round coiled green things?   Exhaust gaskets for bottom of stock exhaust Manifold??
CTENG in KS
Duffil
the green things are pipe to manifold gaskets, and negative on the cam bearings.
CTENG in KS
Ahh, pipe to manifold...I see.  Thanks.  Thats good casue I don't have any cam bearings.
Ramrod
just looking over this thread for the pics of your sliders and came upon your traction bar and wanted to say that without a doubt if you dont brace the hell out of it your gonna rip off that entire crossmember its mounted too right off of the frame.  I've seen it happen on every truck setup that way
CTENG in KS
Werd..it will be gettin braced soon...getting the truck running has become first priority before I can get back to the welder.
CTENG in KS
nyone try these yet?
I'ma give em a shot, I'll let ya know, they sure are pretty!
milla85
I think them "ricers" are all bout them there pulgs! Idk :gap:
CTENG in KS
I'm sure they are good for bout 50 horseys!
