A.J.'s Runner - "Please Stand-by"...Product Review
Started by CTENG in KS, July 14, 2004, 01:22:37 PM
unclejpl4x4
lol   that looks funny
for some $$$ you could of got the :bling:  gas filled/shock bump stops
DTB
Quote from: unclejpl4x4 on October 15, 2006, 10:50:32 AM
agreed it does look kinda funny. u shoulda just used some steel stock square with a plate on top
CTENG in KS
It doesn't look funny...it looks just fine!
DTB
Quote from: CTENG in KS on October 15, 2006, 01:12:37 PM
maybe it just needs some paint!
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
FatAzzRunner
I gotta tell you from EXPERIENCE, those tubes will NOT hold up under stress.  Ask me how I know  :maddest: I have had nothing but troubles with mine and even after fixing them, they still bent.  I ended up bracing mine with some flat stock from Lowes and it made ALL the difference in the world.  I will go snap a pic of them and show you what I mean.
Hold on....................................................
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
FatAzzRunner
#576
Here it is.
I know they are a bit of a different thing than yours but I "THINK" along the same idea.
I bent mine 3 times, had to heat em up and beat them back straight.
Finally, I bought flat bar stock stuff from Lowes and just welded a piece from the bottom of the drop down tube to the frame.  I have had the entire weight of the rig sitting on the front drivers side tire and did not bend it at that point. I know mine are notched tube to fit around with the frame but still its a long piece of tube that is subject to bending.
I would buy some flat stock and run a piece from the top of your tubing down at an angle to the top edge of the spring plates.  I think it would hold up MUCH better..............................Just my opinion.
CTENG in KS
What type of wall thickness are you using....mine are bout 1/8 inch...a brace is pretty easy to throw onthere though.
FatAzzRunner
On the way you did yours, I dont think wall thickness will make ANY difference whatsoever.
There is an unbelievable amount of force placed on bumpstops when you get to wheelin hard enough.  You will eventually get flexed out enough that you crush those bumpstops pretty hard and if your moving and if the tube doesnt line up PERFECTLY with the upper part on the frame, they will bend.
I also use those exact bumpstops in the rear and have gone through 3 SETS in the front.  The rear I have been through 2 sets.
I finally bought some super beefy ones that had a weld on plate on the bottom and they work awsome.
CTENG in KS
These are kinda just something to get on there so I can wheel it...I want to go with those timbren deals later on, but right now I gotta keep the wheel outta the firewall and the draglink off the springs.  I have a lot more work to do.  I JUST WANT TO WHEEL!
DTB
CTENG in KS
CTENG in KS
I started on the other side...going a little different route.  Made a strike plate first.  THis should allow me to keep the tube as short as possible to prevent it collapsing.
CTENG in KS
Since I am back in Wichita it was back to werk...
Put together the bumpstop for the other side, added one gusset, think I might add a second as well.
And no more cruddy mating surfaces...this is going back together for the last time the right way.
CTENG in KS
As Bazzi has so wisely pointed out, my trackbar mount at the horsecollar is ripe for destroying itself and requires a brace.
Of course I have painted myself into a corner as far as room to werk in the area so this little contraption requires compound angles and some creativity.  You will have to keep watchng to see how it turns out.
DTB
Quote from: CTENG in KS on November 06, 2006, 07:43:23 PM
u got alot of paint on the floor too. Landlord ain't gonna be happy  :shakehead:
CTENG in KS
CTENG in KS
It ain't pretty, but it'll do the job.
CTENG in KS
Here is the mess that I made of the crossmember...NOT GOOD.
CTENG in KS
I decided I wanted to stay away from the crossmember so I ran the brace stra8 off the bracket, thus countering the moment on the crossmember and taking the load out at the frame rail. It had to go around the exhaust, but it is pretty sturdy.
rednk1980
this might be stupid but i thought you weren't supposed to weld verticle on the frame it creates weakpoints
CTENG in KS
It can be a stress concentration point, but I am not really worried about it here.
blackdiamond
CTENG in KS
When you have lateral frame loads like at the steering box you can create points where too much bending stress gets concentrated at a verticle weld.  It is referred to structurally as a "hard point" and can result in cracking over time due to metal fatigue.  The best way to mitigate hardpoints is to cut fish mouth (diamond shapes) into your frame braces to spread the weld out along the frame.
In this instance I kept the brace close to the lower horizontal flange of the frame and much of the load will be a front to back shear into the frame so I am not particularly worried about creating hard points.
4runnin_87
just finished reading the build...and man i have to say good job!!!cant wait to see the wheelin pics....finish up
CTENG in KS
I done got her running on saturday so she needs some adjustments and I need to run around and check my suspension bolts and such, then:
ROAD TEST!
4runnin_87
oh yea cant wait to see the pics!!!
CTENG in KS
I took her out for the arond the complex circuit...here is what I got.
Started it with jumper pack cause battery hasn't been charged up since...well...a long time
Pull it out of the garage and let it set and settle.
Runs amazing when I first start it.  Nice and quiet.
starts to warm up and it gets a bit noisier. clackety clak...may just be valves.
I take it around the buildings and she runs fine, but when I get back to the garage she is pretty noisy.
I go to turn into the garage and she stalls out.  Had to sit and charge battery off my car to get it to start.
I am thinking most of these symptoms are those of a battery beyond redemption, anyone else smell anything else going on?
I am gonna go grab a new battery tomorrow.
FATTshack
run it with a good batt and see what she does.
describe the noise
CTENG in KS
I'll have to get back to you on the new battery thing.  The noise sounds very much like blueys valves.  Only other possibility is that the battery is so worn that I am getting weak spark and the fuel isn't fully burning...could cause detonation.
