Blackdiamond (Gup-C build-up)
rednk1980
Hey bd are you going to take the runner to the funny rocks any time soon (after it is finished)? I really want to get a good look at this thing close up, Im headed up Memorial day weekend maybe then?
Quote from: rednk1980 on April 07, 2007, 11:20:56 PM
I have no plans as of yet to go anywhere.  I gotta get it first and then I can start breaking things in and working on tuning my skills offroad with the new rig.
Duffil
Lots of 22Rs leak at the front main seal.  Get a manual gauge and screw it in, just to be sure it is/is not pumping. If it's leaking there, I would think that it is.  Was there a groove in the balancer or did you notice?
BTW--that thing looks  :boobs:
gotrocks
Quote from: Duffil on April 08, 2007, 12:35:54 AM
I'm assuming when you mean groove your referring to the keyway slot.  Yes its there and the key is in.  I am going to get a manual pressure gauge and screw it in.  I should be working on the engine tomorrow.  Today I have some other obligations lowering a Jetta so I should know shortly what on earth is going on.
gotrocks
Quote from: blackdiamond on April 07, 2007, 11:17:42 PM
Looking excellent!  :jawdrop:
Other than the leaking, what tipped you off to the low oil pressure?
the oil light came on
Johnny5
i think he is referring to a groove wore into the harmonic balancer. the part of it where it slids through the seal. they can wear there and leak out the front main seal.
Duffil
Quote from: gotrocks on April 08, 2007, 09:18:30 AM
No, sorry if I wasn't clear :boozer: I do mean the one that gets worn into the balancer.  :turtle:  takes the seal, and grinds the rubber off the backside to relocate the lip and stop the leaking
From the "Save the Jetta" foundation...
I recommend this lowering kit: http://kalecoauto.com/index.php?main_page=product_info&cPath=4&products_id=11
854RUN
-JOSH-
gotrocks
thanks
no the kit I installed was a H&R complete strutt and coil kit.  It looks really good and it only took 2 hours to install.
It sounds like the oil pressure "idiot light" could be from air in the line.  Maybe the leak is a seperate issue and will stop.
:dunno: just some ideas
gotrocks
Quote from: blackdiamond on April 09, 2007, 12:20:05 PM
maybe but after running the motor for 10 minutes all of the oil should be circulated through the engine
Quote from: gotrocks on April 09, 2007, 06:35:46 PM
A couple of my coworkers made it sound like you can actually bleed the gage line?  Maybe it is different on other motors.
:dunno:
Duffil
Quote from: blackdiamond on April 09, 2007, 07:05:37 PM
:dunno:
there is no need to...I've had a manual gauge hooked up with bubbles all through it and it read fine.  Remember, air is a fluid.  Also, even though you can compress air, in a tube with liquid next to it, the pressure is passed on to the liquid(oil).  There is not enough volume to account for air pressure losses in an oil pressure line, anyhow.
Quote from: Duffil on April 09, 2007, 09:16:09 PM
Is that why air in brake lines doesn't matter?  :yupyup:
mudaddict
that runner is looking mighty fine if i do say so my self!! nice job gotrocks!
98 Taco- Super charged, sas'd, bobbed, locked,taco boxed with 39's
Taco Build http://board.marlincrawler.com/index.php?topic=88901.0
I work At
All Pro Off Road
gotrocks
Thanks.  Right now I'm not worried about the looks.  Gotta get this thing running perfect.
Quote from: gotrocks on April 10, 2007, 09:46:31 AM
Any ideas yet?  Is the new oil pump just bad?
:psss: No pressure from me on this one.  :thumbs:
synwars
Quote from: blackdiamond on April 10, 2007, 10:45:26 AM
Nice pun. :thumbs:
Better check the sending unit... make sure its got good contacts, and check the resistance on it...
Build up thread:
KEEP IT CLEAN PEOPLE!!! :bat:
Quote from: synwars on April 10, 2007, 02:31:31 PM
Nice pun. :thumbs:
I noticed that after it was too late.  :shake:
Cheesemaker
A new delivery date has been agreed on.  The bdrunner should be crossing the state on Friday afternoon.  Gotrocks is certain the the oil pressure and leak problems have been identified and are easily corrected.  I'll let him explain if he wants, I'll just make myself look stupid if I try to put it into words.
The bdrunner should be complete with the exception of the twin stick which will be installed in the near future.  I'm working with Marlin Crawler on the details of that transaction.
Once again,  :turtle: is treating the customer right!  :thumbs:
toy4x4ota
im not sure if you have fixed your oil pressure problem or not, but when i did my front main and put everything back together i wasnt getting pressure either.  i rechecked the o-ring style gasket and it was messed up.  if that o-ring gasket isnt just right you wont get any pressure at all, maybe you should check that.
Liqour in the front   Poker in the rear
LIFTED TRUCKS ARE GAY
85 toy, 223:1, welded/welded, 38's, running on PANE
Quote from: toy4x4ota on April 19, 2007, 07:59:14 AM
I think the o-ring was a problem.  Gotrocks thought they had the problem identified, but I have not heard if the repair was successful.
:crossed:
 :phone: from gotrocks and the engine is running great!
It seems that the only oops that has been identified so from the project is that during the dual case assembly the shift fork pin was reinstalled so in order to run the twin stick, once I get the correct application, the cases will have to come back out.  I never really found the increadible benefit of the twin stick so I'll have to evaluate if it's worth pulling the cases again.  I'm sure if I wait a while, an "opportunity" will present itself and give me another reason to pull the cases.
We have worked out the details for the delivery process, all I will say as it will be a surprise to some.  The event will be well documented.
:snapshot:
