The Official 3RZ Knowledge and Database Thread
Started by BigMike, January 03, 2006, 08:44:17 AM
howdydude
Hey All,
New guy here, recently picked up a 2000 4runner 4WD 5 speed with the 3RZ engine, to replace my venerable 1988 22RE 4runner.  (We needed 4 doors to accommodate a new family member.)
This will be my DD, used mainly for light wheeling/exploring/camping on USFS road system here in Oregon, winter travel and occasionally towing a light trailer with my 14' river raft.  Goals are fuel economy and long-term reliability.  My impression is that the 3RZ moves the heavier 3rd gen 4runner a bit better than the 22RE moved the 1st gen, but with significantly better torque, i.e. much less need to downshift on hills.  But improving throttle response and a bit more pep would be nice, if that can be accomplished without major mods.
I've read that this motor responds well to opening up the exhaust a bit.  Current tentative plan is to swap in a later style (2001+) "mini-header" exhaust manifold, an LCE 2.5" free-flow cat made for the 3RZ, and maybe a Magnaflow muffler- I want to keep it pretty quiet.
But I'ld really appreciate input on exhaust system options from all you 3RZ gurus!  Specifically, is the $160 LCE "exclusive" 3RZ cat really exclusive to them?  Or is the same thing available elsewhere for less?  Is 2.5" diameter the way to go?  Lastly, most folks seem to think fiddling with intake mods doesn't do much for this motor.  Do you agree?
Thanks in advance!
TIMS89CRAWLER
I got a question about the alternator wiring on the 2rz.... are the colors on the alternator gonna be the same as on the 3.0l v6? this is all I have left to wire and I dont have a FSM for my 89 truck..... any help will be much appreciated....
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
jmsdad
Quote from: davidr34 on September 24, 2008, 09:40:49 PM
jmsdad where did you get the fuel line made? or how about the power steering line.
sorry, haven't been in here for awile...like TimsCrawler said, any hose supply store should be able to make one for you.  I got mine made at Delta Rubber in Modesto.  As for the power steering line, I used the stock Tacoma.
davidr34
 had a power steering line built at hydrolics store but they didn't want to build a fuel line so I'll ha e to come up with something. Jmsdad have u got yours running
wslytoy
Quote from: davidr34 on October 15, 2008, 10:43:02 PM
Go to Napa and get some 5/16" fuel hard lines and just re-route it.
howdydude
Quote from: howdydude on October 06, 2008, 01:29:06 PM
Hey All,
Thanks in advance!
OK well thanks anyway...figured you 3RZ experts might have some opinions about exhausts for this motor but apparently not.
88_Pathy
Just get a decent high flow cat and a Borla muffler. I have a Downey header with dual stock cats and Borla and a open intake, it is still very quiet.
TacoRunner
Ok, I figured that BigMike would likely step in here, but I'll give my two cents, in his absence.
I'd stay away froma 2.5" exhaust. Typically on a 4banger you need some back pressure to get any kind of touque from the motor. So I'd stay with a 2.25". I'm running a 2.25" exhaust and a size 14 Magnaflow muffler. It's not LOUD, but its not quiet either.
As for the LCE cat, sorry dude, but I have not run one and know of no one that has. Let us know what you think.
As for headers, I like a Tri-Y. But other than Northwest Offroad, I know of noone that makes one for the 3RZ. You will be safe with a either LCE or a Thorley. Downey, from what I've heard has or had some issue's regarding the flatness of their mounting flange to the head. PM BigMike on that one.
For added power, always buy Ceramic coated. If possible, buy a Stailess Steel exhaust and then heatwrap the whole thing. Your floor boads will stay cooler, along with you engine bay. You will also add power by doing so, it may not be noticable but the thoery at least is that by keeping your exhaust hot as it travels down the tube it will travel faster wihich inturn will help suck in fresh air into your combustion chamber and produce extra power.
Mufflers, its a muffler. Buy one.
www.4WHEELUNDERGROUND.com
[email protected]
howdydude
Thanks for the replies!  And that is good advice about the 2.5" vs 2.25" pipe size.  I have heard several opinions on each side of this choice, but for my purposes I think 2.25" is the way to go.
RE a header, I think I'm going to just go with the late (2001+) style stock "mini header" rather than an aftermarket item.  I have heard elsewhere what TR suggests- that tri-y is the way to go, but the NWOR header does not fit 3RZ 4runners according to THIS link http://www.4x4wire.com/toyota/4Runner/reviews/lce_header/.  I've also been told that the "mini-header" is just about as good as an aftermarket header, and they can be had for ab out $80-100 at a junkyard.
Anyway, thanks again folks!  Much appreciated.
*ROKTOY*
Anyone out there get there AC working? I need some info as to what you all did, I don't want to convert to 134 if at all possible, so what I need to know is what compressor or ac clutch you used to make it work?
BUDDERS
Use the stock 22re compressor (3 out of 4 mounting bolts line up).  Use a 5 rib magetic clutch out of a 1st gen mr2 and the stock belt on the 3rz and everything should work line up.  As for the 134a, go down to Napa or Kragen and get a kit to convert the fittings from r12 to 134A and make sure you change out the O-rings to the newer style 134A (should come in the kit).  I haven't got mine running yet, but everything on the A/C looks like it will work fine with the mods I just described.
P.S.    Just make sure it's a normally aspirated mr2 (4age engine).
davidr34
Hey guy got the 3rz running but i have a few problems i need your help with. First it runs fine for about 1 min and then it just starts sputtering and dies. That's the main problem next is that the diagnostic kit i bought the one that big mike uses, i cant get it to work. It always stays softwear not found, I was wondering if anyone had any experience with this. Lastly does it matter witch heater hose goes where from the block to the cab?
*ROKTOY*
Did you download the software from the site? As far as the heater hose go I don't think so.
davidr34
yeah dl it from the site so i dont know im just slow i think, operator error. and i hope not with the heater hose cause ive been running it.
*ROKTOY*
jmsdad
ChrisA
So, I just got my 3RZ today for my swap going into my 82 longbed pickup and after researching for a few months there are still a few things that are eluding me.
#1-Purge Canister(charcoal, evap, etc.) Which one should I run. I know they all serve the same purpose but, i've seen some guys run the "EVAP Canisters" that look totally confusing and rather bulky and then I see guys, like bigmike, running what seems to be a simple charcoal canister with 2 lines running to it. What dictates which one to use?
#2- Fuel tank- Once again, what tank to run. Obviously it will need to be an EFI tank, but which one, and why? fabricating new mounts, cutting and moving things to make it fit is not an issue, but i'd like to keep it as bolt in as possible. Does the tank you run have an impact on issue #1?
any(and all) help is appreciated!
thanks
wslytoy
Quote from: ChrisA on January 12, 2009, 10:50:13 PM
thanks
As far as the charcoal canister, I'm going to run the one out of my 85', I'll just have to cap some lines off/reroute some lines. The best option for you would probably be to get a 85-88(9) tank. That pump is sufficient for the swap.
TIMS89CRAWLER
Quote from: wslytoy on January 13, 2009, 05:17:27 AM
I am running my 89 v6 charcoal canister with no sensors on my 96 2rz.... and I am using my 89 v6 fuel tank/pump and for fuel lines just build new metal hardlines thay are much better thann having any rubber.... the only rubber line I have is from the front of the frame to the motor that is a factory line.....all works great and you will love the torque....
www.choptechfab.com
CHECK THE BUILD
ChrisA
sweet action! I picked up a charcoal canister out of an early 90's 4runner and will run that. Does anyone know how legit this is in Califonia? if i'm suppose to have the 4-line purge system that is? will they even know?
thanks!
allbones
guys where can i get a 3rz for my 92 exc and does anybody make a wiring harness
He who dies with the most toys wins: 92 toyota climber and bogger, 96 xcr sp 600 polaris snowmobile, 134 cc honda pit bike, 07 honda crf250 dirt bike,06 joyner 250 sand buggy,02 yamaha pw80, 97 yamaha wolverine 4x4 quad and several rc buggies
Steve_925
check the parts for sale section. someone has a 3rz for sale
UA 342
STEAMFITTERS
UNBREAKABLE
Ok, so here's the deal...Ive ALMOST got my wiring harness cut down to bare necessities. Do I have to have the VSS for the engine to run correctly?
OK, basically what do I have to keep and run, and by run I mean run correctly?
That's how I roll
Duffil
Quote from: UNBREAKABLE on February 05, 2009, 07:03:00 PM
you might want to double check BMs thread but I think he said he didn't feel the engine put everything out with the VSS disconnected.
Anybody done the balance shaft delete?  The 3RZ I'm fixing for my swap has a screwed up balance shaft so I thought I would just leave them out.
wow...... this should be the only engine swap considered for a toyota.
the info here is phenominal.
Thanks for this BigMike and everyone else.
This is really convincing.
E-9
I used the plug and play harness from Off Road Solutoins for a 2RZ swap, worked great. Now they are out of business. Does anyone know of another source for a ready made harness? Larry at 704-860-6136
wslytoy
Quote from: Lucky HO on February 19, 2009, 11:12:43 AM
painless!
Since when... Painless wouldn't even consider a 5vz harness when I emailed them about that.
