Toyota Chinook Build!! Mach 2.
Started by 4xChinook4, March 04, 2015, 09:10:40 PM
redneckcustoms13
Need some info on this diesel heater please.
01 double cab hunting truck
06 tacoma street truck
4xChinook4
Quote from: redneckcustoms13 on March 06, 2020, 04:52:29 AM
It's a happybuy from Amazon. 5kW . With the remote start. It was somewhere around $135 - $150 I believe . I flipp'n love it so far..  it comes with a 10L plastic fuel tank. Totally fine. But opted for a green jerry can I have permanent all mounted on the back bumper. The heater kit. Comes with a little ¼" bulk head  so you can tap into any tank . Whether it be the plastic tank they supply , or in my case.  The jerry.
Sent from my SM-G960U using Tapatalk
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
4xChinook4
Quote from: 4xChinook4 on March 06, 2020, 07:26:37 AM
Oh and it's very compact for the heat it can do.
I think it was something like 15" long 5.5 " wide and 6 or 7" tall. From its floor plate.
At one point . I just wanted to see how hot I could get it in there. Through all efficiency to the wind [emoji28]   It was 92° in that little camper and out side was something like 20 or 22° . This last January.
I had 2 buddies stay in the truck for a week and half. This January And they lived in it every day and night. Street bumming it. Around upstate NY and NYC. It cost them I think $14 in diesel fuel. To live comfortably.
For some real life perspective
4xChinook4
Sad news. Dang wind caught us off guard. 2 days ago. I was in the middle of replacing the canvas. And that adds stability to the whole topper .
Long story short. The only thing that's trashed really are the 4 slides that's the 'X' bracing uses to . Go up and down. Same idea as a drawer slide but much more heavy duty.
So you guys know anyone who is parting out a chinook lol. Or have slides as an idea or retro fitting,  let me know !
helipilot77
Thanks for the tip on the heater. I was looking at Webasto but they are over $1000. too bad about the hinges. I'm sure you can use this as an opportunity to improve things.
4xChinook4
Quote from: helipilot77 on March 07, 2020, 08:34:50 PM
You got it. Yeah. Stay tuned. I think I found the best replacement
4xChinook4
Making the new slide rails for the roof to pop up again.
4xChinook4
5/16 " bolt grinded down on 2 sides to fit into the puck. And not interfere with the slide ability
4xChinook4
Picture worh a 1000 words
4xChinook4
Cut the old brackets from the trashed original slides. And welded them to these new ones.
They're made of a high density plastic type . Same stuff bullet proof vest, fishing line, and prosthetic joints are.
4xChinook4
Originally when looking for replacement slide rails .for the originals. I was looking at $300 - $400 .and was still going to require retro fab work.
Finally found the company 80/20 . Which is basically legos/ erectorset for grownups. .
And the liner bearing slides. And the 60" x 3" x 3/4" aluminum channel cost me $90 after shipping . Which was $20.
And cut the 60" into 4 15" slides.
And done.
Will hopefully be installing this all next weekend
helipilot77
Great solution and I imagine much stronger than the original.
redneckcustoms13
4xChinook4
Quote from: redneckcustoms13 on March 23, 2020, 11:25:51 AM
You have inspired me to start another project
http://imgur.com/a/gMeJoBY
Sucker for a good truck bed camper build. [emoji1687]
4xChinook4
So I looked into getting a 5'x10' sheet of FRP board for the ceiling (that thin fiberglass sheeting you can buy at home depot , but only comes in 4x8 )
Found some for only $70 ! BUT with $130 shipping and only coming from 3 to 4hours away [emoji28] .
And with this Corona going around,  I've been quarantined at my place of work.
So instead . I'll use the 4x 8 sheets I do have .from lowes a few months ago And headliner fabric the ceiling. For $50 . Once the fabric get in this week I'll try and install the new fabricated slides  and wrap the ceiling all in the same weekend.
Hickory Nut
I work in the industrial automation world and found another company that makes a product similar to that 80/20 extruded aluminum. It is called TSlot and they are out of UT. I have seen it used for Machine Guarding in industrial plants and Structure for pieces of equipment or conveyors.
4xChinook4
Quote from: Hickory Nut on March 23, 2020, 02:41:21 PM
Yeah I saw thier gear too! . I was looking at thier dimensions,  and they seem theres a few good pieces that could inter swap.
Good note thanks
4xChinook4
Getting ready to get rid of the old slide rails .
4xChinook4
Clean up old holes
4xChinook4
Sanded over filled fiberglass and new holes for the new slide rails
4xChinook4
New rails in
4xChinook4
Feel like this one is pretty self explanatory
4xChinook4
Same for the roofs set of rails
4xChinook4
Sorry I never got any pic of the putting the panels in. But basically used some flush mounting wood screws,  really small. Like an M6 size diameter by maybe ⅜ length of screw .
And took a ⅜ drill bit and drilled out some fiber glass but being careful to not drill all the way through the 1/16" panel. Just enough for the head of the screw to actually seat in. And really be a "flush mount" .
Did this about 20+ places through out the ceiling.
And as you can see there a little bit of ramp up in the ceiling just infront of the forward flush lighting . .
I was able to get that shape. By taking a torch to the fiberglass panel along that line. And flex it to have that new crease rather than be flat.
I over creased it . Then when I had it all screwed in. I took the torch that same crease and let is relax to its final shape.
Put some duct tape over all my seams where the panels came together  and then rolled on the headliner. Which was very easy. But a little more delicate than I'd like. We'll see it does.
But that all cost me $150 start to finish with the new fabricated slides. And ceiling job.
I'd day pretty worth it
4xChinook4
Naked inside
4xChinook4
R3.3 rigid foam board insulation.
Just one 4x8 sheet by a ½" thick did the trick. There were some bare spot along the edges . But this wasnt that critical, just a little something compared to the nothing it had before.  Helps with stiffening up the whole roof and even a bit with sound.
4xChinook4
Just about back in action
4xChinook4
How the lift works .
Fyi. I had to replace one of the springs. But incase anyone reading this thread needs to know. A 160 lbs garage door spring from home depot. Cut to size. Works as a good replacement.  I couldnt find another alternative.
4xChinook4
1st coat of sealer
