OVRAROK. My 87 4runner
Started by OVRAROK, July 11, 2014, 04:04:18 PM
Started disassembly on rear axle. Found my right wheel bearing is no good.
Sent from my SM-G955U using Tapatalk
joeyf
How is the axle wrap with those blocks.
Quote from: joeyf on October 25, 2018, 03:58:03 PM
They are part of the leaf pack. I'm not 100% satisfied with them. Have been speaking with a local spring maker. But I'm torn between linking rear, or new custom rear springs...
Had 2 stripped studs, had to weld nut to stud. Decided it was time to replace all housing studs. My local reibes had them. Will need to grind slightly on housing.
I should have gotten one of those gaskets for my rear diff. that cover is still leaking. and I feel if I tighten it any more, that those bolts are going to snap
OTO Phil
Wish I could have gotten the into to you sooner, but my buddy sells an upgrade kit to eliminate the stud problems our diffs can have:
http://nwtrailinnovations.com/toyota-bolt-differential-1979-1995?manufacturer_id=11&sort=p.price&order=ASC
Sent from my LM-G710 using Tapatalk
Got the ARB 3rd in, and new bearings. I used aluminum foil to line the diff. Took my time making sure it didnt tear. Used approx 7 layers. Grinded what I needed. Cleanup was nice, just folded aluminum foil inward.
joeyf
Like the foil idea. I usually stuff shop rags in there and end up catching them in fire.
Quote from: joeyf on November 01, 2018, 01:44:37 PM
It was my easiest cleanup. I did stuff rags in the axle tube, then foil over everything.
Slabzilla
Sweet idea with the foil.  I did the NW stud eliminator kit, happy so far.  Yours looks great, though I need a Lube-Locker for my diff too.   :thumbs:
My 2nd switch showed up. Going to make a gauge panel with carbon fiber. Dual needle viar air pressure gauge
My scan gauge 2 showed up, going to lose the altimeter, in order to install SC2, and air pressure gauge.
300k
How much for altimeter guts? :greengrin:
Quote from: 300k on December 06, 2018, 11:00:01 AM
It's a complete altimeter...I haven't done much research on what there are worth these days
Check out Aircraft Spruce to get idea of what experimental airplane parts cost
One down, one to go.., I temporarily wired the SC2, just to get a visual....
Well.., the air pressure gauge will be relocated to radio area. Made a little bit more progress..
Just need to fiberglass cover.., may make last layer, carbon fiber...
:)bestgen4runner
I can't tell what's in the air gauge location?
Another picture please.
Are they switches?
I am 1/5th of Perfect Fit
Quote from: :)bestgen4runner on December 09, 2018, 12:57:56 PM
Are they switches?
Nothing....  it a reflection of my phone, and fingers. Left it blank, for now...
There ya go..
Got the air locker switches drill out..
More progress..
Almost there..
mudmaster
Damn you do nice work!
Time to go wheelin!
Couple more goodies
cbeers
Quote from: mudmaster on December 19, 2018, 09:46:11 AM
agreed!!  looking good Dave!
question - you going to bench bleed the master?  i didn't do mine when i replaced them but all seems ok so far.
i bench bled the brake master though.
CB
