Willy Wonka: 87 4runner, 5VZ, SAS w/ FJ62,
Started by zippo, May 11, 2014, 09:29:42 PM
helipilot77
Welcome to page three.
I had that exact same problem on my 22-re.
zippo
Yeah, the next step was to test things with a NOID light, but it didn't come to that.
If you see it, its for sale.
Dingman.
zippo
I'm thinking 3link the front, Leaf the rear, sitting on diamonds, duals t-case all on 38's. But the wallet will determine how fast all that gets done.
zippo
So I slapped some new brakes on the front of my runner today. Went from a stock 87 4cyl caliper to a 89 V6 caliper. Also flushed the brake system with new fluid. This is always a great upgrade. was able to lock up the 31's that are on the truck. Down the road I will upgrade the MC and rear drums, but for now i'm happy.
So, when I picked them up from the parts store I took the 4cyl caliper and turn them in as a core. With both caliper sitting side by side, the part store guy, looked a little puzzled they looked so different, them put them in a bag and I walked out. It makes me giggle. How do you not notice this? or do they just not care as long as they get a caliper. Could  I take in some busted GM calipers?
Dingman.
all my buddy's keep telling me to take in some toy calipers for cores on the dana44 calipers i bought. i have not done it, because i would assume they want the same part back.
helipilot77
I'm going to do that. I am in the middle of a full front axle rebuild right now. Nice timing.
Nation
zippo
SUMMER TIME BABY!
Blasted and painted the wipers, ther look almost new!
Upgrades to a 1" MC and removed the LSPV. Awesome upgrade as always! it will put you through the windshield.
INK!!!
zippo
So I got in a bar fight last night with a leprechaun, ended up with a black eye, new wheels and tires. Black steelies with 32/11.5/15 BFG All-Terrain T/A KO2. I was going to get KM2's but I will wait till I SAS and move up to 37's. They look so much better then those shinny, mismatched, air bags that were on it before.
zippo
So recenlty while playing around I found it. I knew I have it somewhere, though not as bad as it could have been. Stupid Rust... I have seen several yotas rust here. I'm not sure if its the gasket or spilled brake fluid.
Cleaned it all up.
POR15!
Threw in a new Clutch Master and a used double diaphram booster.
zippo
So been doing some small things. Put a new PS pump in.
Built a Power Tank on the cheap. Came in under 100 bucks! Traded an extra tank of tri mix for a bottle of C02 and bought an oxygen regulator. Swapped out the inlet pipe to fit, added an air chuck. Works like a charm.
I have one of those extra safe 4runners, so no rear seat belt was installed. I have no idea what bolt it takes, nothing I have seems to fit, but a drill tap and heli coil fixed it. 1/8 plate steel.
I need to get some better straps.
Wainiha
Nice build.  I need a regulator for my CO2.  I've been airing up without one.   :shhh:
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
porkchop88
This is one extremely clean, well built 4runner. I wish i could get my pickup truck to look this good.
Please keep us update on the progress with this.
dropzone
You  might see if you can find a fire extinguisher bracket, I paid $15 for a used bracket that fits a 10lb CO2 bottles.
81 Toyota Trekker 221:1
zippo
So I have had a lot going on, and well the runner has been getting neglected. Well no more. I have something fun planned! I got the first step done tonight.
Front diff is pulled. No its not a SAS, and No its not getting a locker (though I might throw a spartan in if they go on sale"). You will never guess what next!
1985CRAWLER
long travel? diff drop? ifs lift? what can it be if no sas? :headscratch:
Nation
zidaro
tell me your putting in a centered supra!! and you would rule
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
helipilot77
HaHa! I know what he's doin. But I'm not saying a word!
zippo
#81
So while it was out, I found a spartan locker for about 300 shipped to the door. Couldn't say no. Install time was about an hour. But awesome funs is still to come!
zippo
So some progress and set backs.
My stick on oil pan idea turned out to be a terrible idea. I just couldn't get it to hold oil...... Maybe a different tape?
Found an used oil pan, junya92toy tigged a -8 AN bung in, so I put that back in. Thanks Junya92toy!
So let me just say, Putting an IFS diff in by yourself.... Sucks.
86bobbedtoy
Nation
zippo
Wrong side for turbo drain. Right side for a supercharger.
zippo
Soooo. I finally got it! I know some people will dog me about putting money into a 22re and not just swapping, but I have always wanted to do this! Supercharger TIME! I should be around 5lbs of boost. We shall see!!!!! I will try and take a lot of pics and what not. Its hard to find a lot online... I picked it up from the factory to. Camden is local to me. They are super nice!
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Nation
OVRAROK
