Project Never Easy
Started by Peterbuilt84, July 02, 2010, 03:55:42 PM
Peterbuilt84
I'll get updates tomorrow of what I've done. Leaving for SLO on thursday, so basically progress on this thing is gonna stop till I have time off school.
Peterbuilt84
#33
New gear pattern. Shim is .067". Opinions?
Dr.Maxwe001
:dunno: about gears so i cant say anything  it might be a hair to deep from te picts but then again it could be a hair to high or a hair to the left or a hair to the right   :weirdthread:
IF YOUR LOOKING OUT THE FRONT OF YOUR 4X4 AND YOU CANT SEE THEN JUST TURN ON YOUR WIPERS. BUT THEN THINGS GET ALL MESSED UP LIKE IN LIFE.
WHEN YOU GET TO THE END OF YOUR ROPE JUST THINK THAT ALONG TIME AGO  YOU WERE THE FASTEST LITTLE SWIMMER TO THE EGG
08:55:22 PM BeccaLoo24 – i like to screw things
$99 scratch and dent drill press has drilled more holes than Ron Jeremy.
http://board.marlincrawler.com/index.php?topic=48342.0
[img]http://bo
Peterbuilt84
Yeah, I still think it is too deep from what I can tell. Just wanted some opinions before I take it apart again.
LowSantorin
No expert by any means but it does look a bit too deep to me as well.  Wait for some "experts' opinions
whats the backlash  set at
santa cruz crawler
Dude you can pm me and I'll help you out with whatever ,
your getting better each time you set the gears up!!
Gears are a pregnant dog , and big money to install I think I looks good this last time but it is a little low in the rear part of the gear.
Awsome keep up the good work .
santa cruz crawler
I have some front leafs 4" lift idk
let me no !!!
Peterbuilt84
Quote from: santa cruz crawler on September 15, 2010, 06:39:29 PM
Thanks, the gears where kind of a pain, but really not too bad.
Peterbuilt84
Updates  :greengrin:
Finished up installing my gears this was the pattern I ended up with, think it looks pretty good.
Also here are the rest of the updates, not much.
Rear shock mount
Finished putting my shackles together. Probably going to have to replace them. Still need to box the frame too.
Threw some new doors on. Also made some interior panels, but forgot to take pics.
IFS box mount
Hackjob to the the core support and body mount.
That's it for the summer. Hopefully will get a few things together on weekends when I can make it home.
Sparkplug
Mountin the ifs box a pain in the ass, huh? Looks good man, bet u will be thinkin of truck the whole time ur in shcool
Peterbuilt84
Might be able to work on it this coming weekend. Had some trouble when I was trying to put my birfs back together last time. I have 27 spline longs with longfield inner axles. When I tried to put the inner snap ring in the birf I had no luck. I tried a hose clamp and a couple screwdrivers, but was still unable to get it in. There was only maybe an eighth of an inch between the end of the inner axle and the snap ring.
Are there any tips or advice you guys have for putting the snap ring in? Should I just martack it instead?
Any help or ideas would be appreciated. Thanks
locked 4x4
Why do those plates for the power steering box never seem to fit right.  I got a set for mine and had to have them rotated so much I just chucked them and made my own.
Yota Rolla
it doesn't look like that body mount is doing much. . mite want to brace it up
82 locked,geared,cased,caged daily
Peterbuilt84
Quote from: Yota Rolla on October 18, 2010, 11:47:02 PM
Yeah, I went a little overboard when I cut it out. Bracing it back up is definitely gonna happen. I also plan on putting some sort of guard across the front.
Peterbuilt84
Quote from: Peterbuilt84 on October 18, 2010, 01:48:27 AM
:headscratch:
84krawler
Peterbuilt84
I am going to martack my inner axles, but had a question before I do so. If I measure for the martack with an open carrier will it make any difference when I put a locker in? I plan on running a locker in the future, but don't have the funds now. Thoughts? Any help would be appreciated.
Peterbuilt84
Finally got some time to work on my junk. Finally got my front axle together with 5.29s and longs. It's still open though, ahve to wait until I find a deal on a locker or get some more money.
Still have to install drop hanger, hydro assist and a few odds and ends. Then put the bed back on and get wheelin!   :chew:
Sparkplug
I martacked mine with a detroit, and it was quite a bit dif than wat online said should be welded, so i imagine it will differ between lockers, lets see some pics of the truck recently
Peterbuilt84
Yeah that's what I gathered so I ended up just using the clips. I'm just going to wait until I have a locker and then make the martack accordingly.
As far as pics go I'll try to get some tomorrow.
82juguete
Looking forward to seeing you set up the hydro assist....wish I would've done it on mine right when I went to hi-steer...
Peterbuilt84
Ran into a problem putting together my front axle. When I put the u bolt on the pass side near the diff it doesn't seem long enough. I called tg and they said both bolts are supposed to be the same size.  :dunno:
This isn't torqued down, but doesn't look close at all. Does this look right to you guys?
Other than that I finally finished putting together my front axle
5th stud
Sparkplug
Nope thats not right. I know on mine some are longer, but u need full threads though the nut, try lossening all, and redoing it. As long as you have full threads, it sits even, and torued right, ur golden. Looks good by the way :beerchug:
Peterbuilt84
Thanks, I think they sent me the wrong u bolt. It's all the way against the bottom of the axle and isn't even close. I'll give them another call in the morning
yota4x4sc
nice!!!! im liking that 5 stud upgrade..if i ever run another toy axle im gonna do that for sure
