Project Never Easy
Started by Peterbuilt84, July 02, 2010, 03:55:42 PM
4RunnerChevy
hansi530
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
Peterbuilt84
Quote from: hansi530 on August 26, 2011, 09:23:30 PM
do i see 3 tcases there
No, just stock duals. Triples would be crazy though lol
4RunnerChevy
Well, whats the deal buddy, you got it rolling yet.  Hope you get some wheeling in before school.   :cool:  If not I can get a bunch of drunks together and test your truck while your away :beer: :beer: :beer: :beer:
Peterbuilt84
Haha. No real updates unfortunately. Duals are in and my rear driveline is ordered. Just have to wait for it to get back.
I've been working on the rust, hope to get it finished up tomorrow. I have to figure out what I'm going to do for a crossmember. The idea I've been kicking around in my head is to copy the 4xinnovations mount out of pipe. Then I have to build my front driveline and do my front bumpstops.
If I really bust ass I might get it done by labor day weekend. Seems like the list is never ending.
csb
Just go with the TG or Budbuilt skidplate- its 3/8 plate steel -It wont let you down. Are you going to make a square shaft for the front?
It all started when Marty went back to the future and opened that garage door.
Peterbuilt84
I thought about those skidplates, but the only thing is I'm running the rotated adapter so my rear case wouldn't line up right. That's the only reason why I haven't gone with one of those two.
Yea, plan on running a square shaft in the front.
csb
Right on. I have duals and only run one (bomb proof)tcase mount. I have a friend that also runs duals and has one (stock)tcase mount, and hes done Moab, Hammers, and the Con several times without any issues. We both run the mount on the rear case though.
Peterbuilt84
Good to know, thanks  :thumbs: The 4xinnovations crossmember only uses 1 mount, which I wasn't too sure about. If it needs another it looks easy enough to add another. Now I get to use my hf kinker to make the crossmember  :gap:
This is the crossmember I was going to copy, if anyone is wondering.
santa cruz crawler
Peterbuilt84
Thanks guys! Unfortunately that's not my truck, just a pic I stole of what I want to do  :gap:
4RunnerChevy
Gimme Dims and the tube, i'll bend it for you. I can input it in the software so you can see it before its bent.  I just wanna see this thing hit the road.
Peterbuilt84
Thanks for the offer Kevin! I don't have any tube though. I was just going to use sch 40 to save on cost since tube is $3+ a foot, but I don't even have the pipe.
Peterbuilt84
Here's the progress on the rust. I put some fiberglass filler on the smaller holes. Just need to sand those down and paint the window frame.
Passenger side
Driver Side
Bottom Rail
4RunnerChevy
Peterbuilt84
Thanks guys! It wasn't as hard as I expected, just time consuming. It's going to be nice to not have any more leaks.
Peterbuilt84
Pretty much finished up on the rust repair, just need to clean and paint it with some Por-15. I used some fiberglass filler called Long N' Strong on the smaller rust holes, highly recommend it. Just spread it over and sand it down.
On another note I found out I have to take my cases out again. I didn't grease the input/coupler when I put together my duals which can cause fretting. Shouldn't be too bad though, don't have to tear them down just pull them apart. Hoping to get everything done tomorrow.
Peterbuilt84
Well, found more rust  :shake:  It's right inside where the passenger side cowl empties out into the inner fender. I noticed a bunch of leaves and junk in the hole so I decided to try to get it out. Once I started to get it clean I noticed  a lot of rust. Seems like the leaves blocked the hole so the water would just sit there after it rained. Figured this is another place where water was getting into the cab.
I was thinking about just blocking off the whole side, maybe with some waterproof foam. I was thinking the stuff that in the can :dunno: Any suggestions are welcome. I don't really want to tear out all the heater lines and junk to get back there though.
4RunnerChevy
If your gonna go that route, try spraying or brushing rust converter in all the affected areas.  The stuff we use at work, does real well, and you know how we are fighting rust every day.
Peterbuilt84
Definitely, rust sucks  :(  I pretty much put Por-15 on everything I have to paint to fight the rust. I should have mentioned the problem is a big hole caused by the sitting leaves, I can probably fit a couple fingers through it if I reach behind the dash. That's why I was thinking about blocking it off, so I don't have to fix the hole   :)
4RunnerChevy
For your rig, I would just block it.  Its a wheeler, not a show piece.
Peterbuilt84
That's exactly what I was thinking. If it was nice to begin with it would be one thing, but at this point I just wanna go wheelin.
4RunnerChevy
Quote from: Peterbuilt84 on September 06, 2011, 05:32:18 PM
Thats funny.
If its nice to begin with, then it has not been wheeled !
Peterbuilt84
Forgot to update this before I left, I'm back at school now. Got the windshield put in before I left, not much else besides that though. I have a pile of parts when I get a chance to work in it though. New driveshaft came in, found a good deal on some 4runner rotors and calipers so I can use the fror taco brake kit I have. Also picked up a spartan locker for the front. Found some rear disk brake brackets on pirate for a really good deal, so I'm going to put my front rotors and calipers on the rear when I finish the front up.
I still have to put the dash back together, build a front driveshaft, put in the t-case brake and figure out how I'm going to do the dual case crossmember. I should be ready to wheel by next season...hopefully  :greengrin:
Peterbuilt84
Small update. Got my front axle taken apart to put in the new brakes, but I forgot I needed to get the hubs turned down so the rotors will slide over :smack: Overall with family and stuff I didn't get as much done as I would have like to. Should start making progress in a couple weeks when finals are over :woohoo: Hoping to get everything done for a new years run at Johnson Valley  :greengrin:
Peterbuilt84
Quote from: Peterbuilt84 on September 06, 2011, 03:43:29 PM
Anybody have any ideas or suggestions on this? I just want to block it it off, but not cause more problems later.
*** YELLER ***
4X Inovations crossmembers are great and If you add a metal plate to the bottom thy make a great tranny/ transfer case skid, trust me lol
except BACON
Peterbuilt84
Quote from: ** YELLER ** on December 16, 2011, 03:49:42 PM
Haha, I'll take your word for it. I definitely plan to add a plate to the bottom, did you just weld yours?
