Project Never Easy
Started by Peterbuilt84, July 02, 2010, 03:55:42 PM
Peterbuilt84
To any one running taco rotors what wheel studs did you use? Definitely need some longer ones, but I haven't been able to find much searching.
So after this the main things I need to do is get/make a front drive shaft, armor, finish brakes and... that's pretty much it. Just some little :pokinit: left after that. Soooo close to being able to go out and wheel!
nisota
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
Yota Rolla
Quote from: Peterbuilt84 on June 28, 2012, 10:37:32 PM
Bit of an update. Picked up a t-case crossmember off craigslist. I think beef is an understatement, the main portion is 1/2" and it has a mini skid that goes underneath where the t-cases mount. Also bolts with through the frame. Very solid to say the least. Here's some pics I stole off craigslist.
So I got it fitted up and tried to install it, which led to this...
The truck it came out of had a 2" body lift which is why I had to cut up the floor. The top of the front output is still hitting the floorboard, so there is still trimming to do. Sheet metal work shouldn't be too bad. Also had to move the frame mounts a bit since it came off a 3rd gen.
Anybody have any suggestions on stiffening up the holes in the through the frame? Was thinking about running some tubes through the frame, but I don't know if I want to go through with it haha.
ha ha i was goin to buy that . . i called and it was already sold
82 locked,geared,cased,caged daily
Peterbuilt84
Quote from: Yota Rolla on August 02, 2012, 02:20:38 PM
Damn, missed your post. Guess I beat you to it haha. Guy I bought it off was pretty cool, was glad to see it live on.
Peterbuilt84
Well, there has been progress on my junk. All I need to do is find some tires for my 17's and build my front shaft and it's wheelable. I'll post some pics and updates tomorrow.
Peterbuilt84
Update time  :clap:
As posted above my new t-case crossmember wasn't going to fit without some cutting.
First Cut
Eventually cut quite a bit more. Used some 3/4" square tubing to make a frame.
Then added some supports.
And some finished shots installed.
Mounted the skins for the tunnel with some sheet metal screws. It was a bit more work, but being able to remove them if needed seemed worth it to me.
Raising the cases that much meant that the horsecollar crossmember was going to have to be modified pretty heavily for driveline and exhaust clearance, decided to just cut it out completely. Made a new one out of 2"x2" square tubing with a notch for the exhaust.
Also had to move the gas tank because it attached to the old horsecollar, to the bed it went. Used some left over 3/4" square tubing from the trans tunnel to make a frame and mounts for the tank.
Going rear disks meant that I had to redo my rear brake lines. Picked up some 3/8" copper brake line and went to work.
Making the lines ended up being super easy so I redid the front lines since I didn't like how they were set up.
Pass side, cut the old mount and moved it to the side of the frame rail.
And how I rand it to the caliper. Made some tabs to attach the lines to that mount with the caliper bolt.
Driver side had a female fitting on the frame rail so I used an old line I had and ran it to the frame rail. I think the line was the old rear soft line.
Had to pull the tranny since the clutch wasn't disengaging. Threw it back in and everything worked great  :greengrin: Can't wait to use the duals.
And how it sits today.
Just have some rollers and my old 15's with 1.5" spacers until I can find some tires for my 17's. And if in any of the pics you see gear oil that's because it was leaking out of the rear shifter since there isn't an oil slinger  :shake:
Cheesemaker
Looks like you need some paint under there.  You are closer to crawling than me.  :thumbs:
Peterbuilt84
Definitely need some paint haha. Just welded in the horsecollar replacement crossmember today and still have to do bump stops in the front, once that's done I'll give everything a nice coat of paint.
You'll get there  :biggthumpup:  I honestly wasn't sure if this day would ever come  :talkingn:
Cheesemaker
I hope so.  I'm tired of saving money up, just to see it disappear for things other than my truck.  I'm tired of being the last one to get what they want.  (but being a father tends to do that)  Been working my ass off in overtime, just to pay the bills.  I'm getting closer to getting all the parts for my front axle.   I've had a rebuild kit longer than I've had an axle.   :rofl2:   Then it's getting parts for the sas.
Peterbuilt84
Bit of an update. Sitting on some worn 37" km2s now.
Just got back this morning from Hollister lol. Worked damn good, pretty much point and shoot. Only trails I really ran were Jungle and Tank Trap. Wasted a driver door at Squeeze and driver tail light on Tank Trap. Bed is kinda fucked. Driving home with no window was not fun lol. I'll see if I can get some pics.
If anyone has or knows someone who has a driver door near San Luis Obispo let me know. Tail light or lens too.
86yoter
wow i havent checked out your build for a min. looks good, my bud built crossmember pushed my tran/tcase all the way. so when i took it  to the floor. basically the my hole shifter and base are above the floor. So i have taken the yota to con twice ( not all the way threw), and in the snow and the tran/tcase will bang a little. especially in the snow.   i really haven't researched this project quite yet so its nice to see how it was done by someone  :beer: . i think it is time for the yota to get some  :love: .
86' runner nothing special
Peterbuilt84
Quote from: 86yoter on November 14, 2012, 07:34:07 PM
Thanks. Love the clearance with the cases tucked up and gas tank moved.
Only pic I could find from Jungle/weekend. Found a door and tail light, but still need a driver side mirror. Added another color to the list lol. Now the driver door is red.
4RunnerChevy
I like it Peter, good stuff, I know you put alot of work into it.   :thumbs:
Peterbuilt84
Just got back from the Hammers a couple days ago for New Years. Besides dumb driver truck ran tits. Ran Claw twice, Sledge, Turkey Claw and Wrecking Ball. Only issues were leaky diff drain plugs and broken marker lights  :biggthumpup: Other than that zero breakage. Here's some pics from the facebooks.
Claw
Almost flop on Sledge
Zs Confederate Toy
Looking good man. Nice to see it in action finally and on some kick ass trails to boot
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
86yoter
Nice dude. Action shots. The work has payed off. May e you will see me and my mall crawler this year down there.
nisota
Lookin great, Good deal on no flop truck looks great!  :beer:
Oregon wheelin'
82' 2wd-4wd project
daniresch
loctupdave
Quote from: Peterbuilt84 on June 22, 2011, 04:57:50 PM
Passed smog today, it's street legal again :woohoo:
Cage and duals soon!
Smog sucks. What is next a probe in your shorts so a fart is not putting out to much hydrocarbons and a special funnel so you dont leak when you pee?
A real man builds it... Then his wife points out all that he did wrong.
86yoter
dude i like the three wheel pic because you rear axle is kinda the same shape as the rock. that was a good shot. :popcorn: :thumbsup:
greenjacob
1986 4runner 93 22re 5.29s locked f/r duals twin sticks 39.5s
Peterbuilt84
Thanks everyone. Haven't been on the forums much lately. Haven't really done anything since New Years to it, just tightened up what's loose haha and still driving it everyday. Need to give everything a once over and throw some paint at this thing before I go on a snow trip I'm going on next month.
WarSaw
Sweet rig, cant wait to get mine together :thumbs:
Bazzi
Peterbuilt84
Just got back yesterday from snow wheeling. Went up to Bald Mountain and wheeled Saturday. Had a blast, definitely want to go back.
Also finally got the rig painted. Really like how it turned out.
Here's a couple pics.
camhays556
that thing looks really good with the paint job.. i gotta get my pile outta rileys driveway
Ghettofab88
That looks good!  What did you paint it with?  Why isn't there a build thread on the polygoat board?
Kevo
86yoter
got to love the snow. cant wait for my selectable front so both fronts roll...... i hate looking at my front when i stop and there is a tire not moving normaly the one that need to be
Peterbuilt84
Quote from: chays2464 on February 19, 2013, 11:01:39 AM
Thanks dood. And yes you do haha
Quote from: Ghettofab88 on February 19, 2013, 07:53:23 PM
Kevo
Thanks! It's just some painters touch rustoleum rattle can.
Not sure why I haven't started a build thread on the forums yet. Only got many truck down and started getting involved this year. Gonna start putting in a legit cage soon so I'll probably start one then.
Quote from: 86yoter on February 22, 2013, 07:09:27 AM
Lol. Locked f&r worked pretty well for me even with bald ass tires haha.
J_Cole92
Nice build and love the new paint.
92 4Runner built on Toyota axles
84 Xtra Cab stock Daily Driver
55 Willy's Pickup Cab
Can't find it grind it
4runner build: http://board.marlincrawler.com/index.php?topic=96221.0
