Author Topic: what kind of oil?  (Read 3921 times)
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
what kind of oil?
« on: Feb 01, 2010, 11:13:19 AM »
im going to change my oil. and i was wondering what type i should run. i was thinking 5 30w. :headscratch: :dunno: i was wondering what type you guys run. i have a 1990 22re. thanks. if you guys can help, that would be great.  :greengrin:
83yota
  • Turtle Points: 372
  • Member since Mar '04
  • rollin my nike's
Re: what kind of oil?
« Reply #1 on: Feb 01, 2010, 01:39:20 PM »
if it is over 75k you will want to stay away from full syn. I run 10 w 30 high mileage penzoil in my runner. just remember when you chose a brand stay with it. mixing oils can cause them to brake down quicker. (they have different ditergents in them) cheap oils are ok but they brake down faster.
Goldrush [OP]
  • Male Posts: 1,381
  • wheelin!!
« Reply #2 on: Feb 01, 2010, 01:54:09 PM »
o ok. thanks for the info. i guess ill still with 10 w 30 then. thanks!
zippo
  • Turtle Points: 569
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
« Reply #3 on: Feb 01, 2010, 02:22:16 PM »
If you have alot of oil burn you could also bump to 10-40. i might stay away from it if its really cold where you live though
If you see it, its for sale.
Goldrush [OP]
  • Male Posts: 1,381
  • wheelin!!
« Reply #4 on: Feb 01, 2010, 02:29:42 PM »
I'm in kingsburg, CA. not that cold this time of year. so would 5 w 30 work or probably not?
94MtnYote
  • Turtle Points: 6
  • Member since Oct '07
  • - 94 std cab-
« Reply #5 on: Feb 01, 2010, 02:40:39 PM »
It would work however Toyota recommends 10w-30 for 22r series engines.
 Marlin 1200LB clutch
Goldrush [OP]
  • Male Posts: 1,381
  • wheelin!!
« Reply #6 on: Feb 01, 2010, 02:45:40 PM »
ok. thanks for all the info fellas :thumbs:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #7 on: Feb 01, 2010, 05:13:44 PM »
86 22RE; 169,000 miles.
From about 50,000, I used 20w50 GTX or Havoline.
Last change I went to 15w40 Delo Diesel oil for the zinc.
Oil pressure didn't drop, so I'll be sticking with this...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #8 on: Feb 01, 2010, 06:08:28 PM »
You want the Delo 400 but it only comes in 15W-40 for Diesels or 30W.  I run the 30W.  But if you have to smog, you won't pass inspection due to the zinc additive.
Generally you don't want to run 15W-40 in a gas engine, due to specific additives for a diesel engine.  But Delo 400 is reverse engineered so it can be used in gas engines.  AFAIK it's the only one that will allow that.
This post covers everything on how to pass smog.  Including what oils to use.
http://board.marlincrawler.com/index.php?topic=1119.0
JoeWelder
  • Turtle Points: -4
  • Male Posts: 146
  • Member since Jan '09
  • Tonka
« Reply #9 on: Feb 01, 2010, 06:17:05 PM »
whats the zinc do?
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #10 on: Feb 01, 2010, 06:34:20 PM »
I passed without any problems.........
Zinc is a wear additive that's being phased out because it damages cat converters.
It's good for metal on metal contact at startup.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
« Reply #11 on: Feb 01, 2010, 06:36:49 PM »
I have always run Valvoline 10w30 in my 22re
Goldrush [OP]
  • Male Posts: 1,381
  • wheelin!!
« Reply #12 on: Feb 01, 2010, 07:08:22 PM »
cool. i didnt know that it would effect your smog.!
b0x
  • Male Posts: 110
  • Member since Aug '09
  • 187k miles & counting
« Reply #13 on: Feb 02, 2010, 07:00:23 AM »
Its good to stick with a oil you an afford. 10w30,10w40 are perfect for a Toyota 22RE. If you feel that you are looking for an extended protection while not harming your motor. I suggest adding a bottle of Lucas Motor Oil in place of a quart of reg oil in your oil changes. Been using Lucas in my Yota's for over ten years and it has proven to help extend the life and MPG. You can pick it up at any Auto Parts store.
Hope this helps....:beerchug:
New Mexico wheeling
Goldrush [OP]
  • Male Posts: 1,381
  • wheelin!!
« Reply #14 on: Feb 02, 2010, 08:39:31 AM »
it does. thanks! :yesnod: :beerchug:
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
« Reply #15 on: Feb 02, 2010, 12:42:40 PM »
I use Castrol or Mobil 1 full synthetic. Works well for me and I can get it cheapish at Costco. I change it every 5000 miles or so.
85_4RNR
  • Turtle Points: -23
  • Male Posts: 265
  • Member since Nov '09
« Reply #16 on: Feb 02, 2010, 06:43:36 PM »
same here
I work a 2000 BMW 540i 6 speed
Travis H
  • Turtle Points: -367
  • Male Posts: 789
  • Member since Sep '08
  • 5100 ft
« Reply #17 on: Feb 02, 2010, 07:54:25 PM »
i use castrol gtx high mileage 10w 30 and either a mobil 1 filter or toyota filter.
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #18 on: Feb 02, 2010, 08:18:13 PM »
delo 30w here also
Those are some huge welds!
Tillamook, OR
Last post Jul 11, 2011, 09:14:50 PM
by Yoturd
Last post Jan 30, 2012, 04:14:04 AM
by Hunterwarren
Last post Mar 14, 2013, 11:19:57 PM
by bleakhorizon
Last post Jun 28, 2013, 09:18:14 PM
by jimbo74
Last post Jul 07, 2016, 09:19:06 PM
by toe
