Are all tanks usually on the right side? If not, get one that's normally on the left side...............Where's the exhaust going to go?
weld it your self! pull the fuel pump, drain it, flash it(light it on fire from a good distance) then cut it up and weld it
In 86; the SB frame and 4runner were the same length;LB and Xtracab longer frame.The SB frame was 17.3 gallons, LB frame 19.2.Maybe latter 4 door 4runners had longer frame...........
my thing is i like to maximize the space on my truck. I would "like" to have a spare tire in the original location... gonna have to see how that plays out. if not i want to put recessed tool storage there and make a baja style tailgate with a spare carrier on it. I can have jerry cans, but once again im about maximizing storage space and why have cans when you can just mount a 2nd tank in a place where noting is currently mounted? Not to mention it keeps your weight lower and thus your center of gravity.
so put a spare parts storage/tool box there?I would do the mods on your tank for you.... just gotta get it up to me in redding and tell me what you want done. and give me a couple bucks.... might have to figure out what method to use as currently all I have is a BIG arc welder or a mapp torch with brazing rods.... probably would need a peice of steel to to fill the hole... I have an air nibbler to cut the new holes that shouldn't put any debris in your tank... and if it does too big to make it through a proper strainer....
It would probably be easiest to see if you could fit either the 17gl or 19gl. oem tanks into the original location, that would give you about 40-60% increase in fuel capacity, w/o much expense or any body work. The 22r engine is not that thirsty and the larger tank might be all you need for your usual wheeling range.Given the amount of tools/parts/gear most carry, it is unlikely you would have enough space with a box replacing the spare tire, not to mention having to unload the bed to get to the access door, or having to lower it from the spare tire mount. I would go with a behind the cab between the rails(leaves the bottom of the bed open), over the rails or along the wheel wells(would leave the entire bed open). You can often find used metal truck boxes for under $100, and often full sizes under $50. If you have some light fab skills you can easily section/cut down a full truck box to fit a mini.
This is all just in a theoretical state right now, nothing is set in stone. I might find out i cant even do what i want. For example, I would need to make a custom Fuel door for the driver side of the toyota.
Does anyone know if you can fit a 35" MTR in the spare tire location? I have heard yes and no.
As for cutting out the mount for the fill neck of the bed and placing in on the other side, i was planning on doing that, it will look a little weird as its not going to hug the fender flare and it will open backwards (towards the rear of the truck).
Started by Marketing New Announcements and Info
Started by donkeykong Project Research and Build-Ups
Started by Shamb Parts For Sale
Started by 87pickup Engine
Started by JeepMan4wd Tow Rig and Trailers
