Dual Case Toyota Crossmembers Now In Stock!
Started by Marketing, July 09, 2004, 08:59:19 PM
Marketing
Heavy duty dual transfer case crossmembers. Each crossmember is precision laser cut from 3/8" plate steel. Crossmember mounts to both front and rear cases. Solid one piece design featuring slotted mounting holes and extra wide openings around transfer case mounts. Easy drain holes access to both cases. Black powder coat finish. Includes (8) T40 Torx flush head bolts for both transfer mounts. Fits 1984 - 1995 4Cylinder dual applications.
Great Low price...Just $195!
Marketing
The BudBuilt unit is a two part, bolt together unit. Ours is made as a single piece of steel.
supratruck
Is there going to be a single case version??
84runner
Ya I could of used this for my runner about 2 days before the 4th of July weekend , that is when I decided to build my own. And that is one damn good price compared to the competitors  :thumbs:
Marketing
Quote from: supratruck on July 12, 2004, 08:03:12 AM
We are not planning single case versions.
Marketing
KSToy
#6
Just got mine on! Fit and finish are great thanx :thumbs:
92 SAS
duleonar
regarding the dual case crossmember
I know I have asked before, but couldn't you just drill another drain hole in the appropriatte place if you only have a single case and are planning to get a dual set up in the future?
Dustin Leonard
Marketing
duleonar
Is there a particular reason why it will not work? If not when will the single case version be available?
Dustin Leonard
duleonar
If it won't work then I might have to buy the BUDBUILT crossmember, because they make one for a single case.
Dustin Leonard
Marketing
It's not going to fit and we are not working on a single case crossmember at this time.
UNBREAKABLE
#12
I dig it...I like it better than that All-poo I had....Now I am just gonna build 1 kinda like skys.
Go BudBuilt.
That's how I roll
blackdiamond
I just installed the marlin crossmember in the single case configuration.  I installed a new v8 mount and already had a low profile drain plug.  I notched the plate under the drain plug for access, but I don't think that it would have hit if I didn't.   :turtle: stuff is :banana: :clap2: :bounce: :rara: :cheer: :biggthumpup:  :thumbs:
Willy Mammoth
You need to post some pics and show how you installed it. I have mine installed on a single too, but Jeeps don't count here. I used the back mounting holes and slid it forward. This works good and helps protect the transmission.
blackdiamond
Here is the thread where I posted pictures:
http://board.marlincrawler.com/index.php?topic=9215.0
I didn't consider moving the cross member forward, but I think it works great in the stock location and now I can get used to the location under the truck so I will be ready when I get duals installed.  It is true that the ground clearance increases, but since it is so long I think it will actually reduce the useable ground clearance, the protection is awesome!
Oh, I meant a V6 mount, not a V8, and who has a Jeep?  My glasses are made by Jeep, but I drive a toyota.
Willy Mammoth
rednk1980
will that crossmember work on a 1980 truck.  i already have the dual cases
