what are the plans on the link setup? I am assuming you are moving the inner link mounts on the axle...or building a whole new truss..that one looks pretty weak
Do you have any close ups of your spring pad? From here it looks a bit scary, but it coudld be the pic, looks like a flat plate welded to a piece of tube welded to the frame? It would be a real good idea to build something more HD.. Again maybe its just the pic?
but if you are thinking that is a bit scary you should have seen my old trucks rear suspension lol.. it was definitely one of a kind the uppers were welded to the lowers for an effective 2 link setup with no panhard. it had no side to side movement and minimal flex steer. IT SHOULD NOT HAVE WORKED but it did and it did beautifully
they were 38x12.50's
right on. maybe ill see you in the snow this coming winter?
Im starting on a budget build.should be done in a month.you should do a snow run with all the o-town boys.do you know anyone from ontherocks 4x4 club or Double deuces?that pic of your last truck was at the claypits huh?
Started by davidt Rig Gallery
Started by spacoli Toyota Pickup/4Runner Tech 1979-95
Started by polykid Engine
Started by fatkidskickrocks4x4 For Trade or Barter!
Started by YotaRick Project Research and Build-Ups
