When you know what a 15/16th is used for on a toyota.HINT HINT THE DIFF DRAIN BOLTS!
It's probably a 24mm
http://www.youtube.com/watch?v=89AxuhEHc3o&feature=relatedThings like that make you smile and tear at the same time. But knowing you can get home from the trail with a hole in your damn motor and a cly or 2 missing is a good thing.
spark plug i've got allen drain bolts.
Spark Plugs are 13/16
you know you drive a yota when you have to tell a newbie about the "secret" bolt in the intake manifold!
I don't remember that one.......... Is it carb or EFI?
EFI
So where is the secret hiding space?
its the allen bolt on the intake behind the fuel runner
When you drive though a foot of ocean water at 35 mph and then you water log your motor, crank it for 2 mins and it starts up sputters for a mile then runs great again with a wet air filter.
Started by lhack524 New Member Check-In!
Started by BCB General 4WD Discussion
Started by toy87 General 4WD Discussion
Started by Toydanota Parts For Sale
Started by toyotamobing Parts For Sale
