You know you drive a Toyota when...
Started by 85_4RNR, December 15, 2009, 07:07:34 PM
85_4RNR
This is a great thread that was on another toyota board. Contribute any you can think of.
Ill start.
Reverse takes a few trys to get in
You stare at every toyota...weather it be lifted, stock, or rustbucket
youre in 3rd gear by the end of intersection
People are amazed that your  25 yr old truck on 35s can get 22mpg which is better than their vehicles most of the time.
I work a 2000 BMW 540i 6 speed
toe
You don't think twice about towing a 1200lb trailer with a 2900 lb car and 500 lbs in the bed cross-country in a 16 year old truck with a 4 cylinder engine with over 130,000 miles on it...................
Me
85_4RNR
 :haha: thats awesome. my friends 22r 85 pickup pulled a 93 4runner but nowhere near that long of a distance.
BoG-ToY
mine got 19mpg, but it was sitting on 35x16x15 tires... over 500lbs of tire and rim. Also, I did alot of cruzin around at 80 with those tires on, and airsoft beads DO work, becuase I  totally had NO lead on those rims
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
46&2
You don't have to change the oil because your truck burns so much oil
unclejpl4x4
Quote from: fortysixandtwo on December 15, 2009, 07:42:55 PM
so true  every month my truck gets a oil change
axled89
when it starts every time.  and gets you home.
i love oregon wheelin.
86rustbucket
.....when your runnin a trail and the only jeep in sight is upside down
NorCalToy
When people are jealous of how good your IFS truck wheels compared to there own other brand vehicle
:flamer: IFS
84t0y
84t0y
when your 23 year old 4runner is worth as much as a 2003 car.
84t0y
when you would rather have the 4cly motor than the v6
84t0y
when you see another toyota truck on the road you stare at it, and then you realize the other guy is looking right back at your truck.
my last one for now.
sparkys83yota
When you park your 2008 nissan titan in garage and use your 83 that marlin built this year as a daily driver.
83 shorbed pickup. 22 re swap. Dual ultimates, l52hd tranny, 5 " marlin trailflex lift. Yukon 529. Grizzly in rear zip locker front. And a bunch of other stuff....
iNfErNaL
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
germ
When your neighbor comes over and asks if you'd be nice enough to come pull his full sized, 4x4 [insert make here] out of the lake bed, and in a single pull, you yank him out and the rest of the neighbors stand there slack jawed.
germ
Your daughter wakes up, rubbing her eyes while your driving down the road and says; "what was that bump daddy?" and you kind-of smile and reply "go back to sleep sweetie, it was just a Honda".
yota_krawler
when your time spent on marlincrawler.com is almost at a month
when you know when 1st gens changed head lights from round to sqare
when you try and talk all your buddys into getting rid of thier pile for a 4runner or pickup
when you get excited to wrench or fab or weld or hell fix something broken.
when you look on CL and someone is trying to sell a yota and they post the wrong year, and you say "its a 90 not an 89 dumbass"
46&2
locked 4x4
84t0y
these are all great especially the last one.
Quote from: yota_krawler on December 15, 2009, 11:14:08 PM
#21
Try around 4 1/2 months  :ack:
When your rear end locks up on a dirt road when you break a ring and pinion, you back up and keep going, tighten the pinion nut when you get home and keep driving it, then a few months later it does the same - rinse, lather, repeat, then when it lets go 40 miles from home for the last time sending a piece through the housing draining the oil, you're still able to drive it home.
When you're able to drive your truck with oil mixing into the coolant for 1 1/2 years before you decide to fix it, change the head and get another few years out of it before a rod bearing lets loose... at about 370,000 miles.
SLIVER
......you run a trail and the only jeep gets left there because it's broken.
......on the freeway the car next to you is playing the "Evens Game" with you and when it finally annoys you enough that you turn your head to look at the person driving the exact same speed as you, you get two thumbs up from the dude driving because you are driving a kick ass 4runner!!!!!
It happens to me all the time actually.
))--SLIVER-->
))--SLIVER-->
yota_krawler
when you "race" to see who is slower in 4lo
when you think a 22re or 22r with no muffler is fast
when you are talking to your friends and jeep get brought up, you either talk about your toyota or bash the person talking about the "heep"
86rustbucket
when your $2500 rig just passed a $25,000 rubicon broke on the trail
yota_krawler
when your rims and tires cost more than the truck is worth
86rustbucket
Quote from: yota_krawler on December 16, 2009, 12:34:13 AM
or your transfer case
86rustbucket
when you can part your truck out for twice what its worth
b-radhutch
when you walk out to your truck to see that your seat belt is hanging outside the bottom of the closed door
toe
Quote from: b-radhutch on December 16, 2009, 12:49:33 AM
:yupyup:
Me
