You know you drive a Toyota when...
Started by 85_4RNR, December 15, 2009, 07:07:34 PM
BoG-ToY
when you buy a 1st  gen 4runner for $1500, drive it hundreds of miles with a blown headgasket, get a job driving a $60k sandrail, then realizing that your 4runner can do 75% of what that sandrail does STOCK.
when you cant make up your mind about doing modifications because even with a blown up automatic and a frame bent so bad your tires squeal when you  make a left hand turn doing 5mph you can STILL keep up with built jeeps and your $60k sandrail
ASK FADE ABOUT HIS BUILT JEEP... lol
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
pinkyotagirl
when every essay you write in your college English class is about wheeling your yota...haha the teacher is gunna love me
yotacrawler1
:when only reason u took auto/metal shop is to build cool stuff for ur crawler.
:when thinking about your rig has cause you ooooh soo many sleepless nights
Thomas P
your doorlatch doubles as a bottle opener..........  :beerchug:
'14 Camry SE
SCX10 Honcho on roids!
killertoy1985
when your 85 looses one brake caliper and blows a piston and still drives you through  3 miles of snow with three pistons to safety= TOYLUV!
fade
My built jeep is a pile. I stripped a inner axle shaft off, go figure dana 30s. err... But I'm gettin a toyota again soon bog. You know you drive a toyota when you like your underpowered lil 4cly over bigger motors.
86 mini truck 18" rays
09 highlander
70 suburban
