Swapped89 party bus picture update
Started by swapped89, August 19, 2009, 03:12:40 PM
0 Members and 17 Guests are viewing this topic.
Early
I think your on the right track for the extra stud fur sur.
Also, i feel like "grade 8" dosen't transfer over to metric. I think they are on different scales essentially making a metric 10.2 the same rating as a std 8. Don't hold me to that. and as far as Taiwanese metal, whatever, they are newer stronger and easily available as a kit( lets not start that crap)
And to reply to ur mail, im definitly a fan of the bolt idea. now ur going to have to strip a bolt or break a head. I think much better friend.
O, and i always have my ipod charger in the truck if you need it in the woods. Hopeing for some day to talk myself into another one so i can loose it too.
When you do the studs if im not there, take a note for me on the clearance of the stud to anything that moves. id be interested in doing this a little later but i would probably run down to wink's, i love wink's. I wonder if a full headed bolt would fit in there.
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
Early
axled89
yea jay that is how we did ours.   drill threw both then remove the third and then tap.   all done you have a good idea to tho.   i went all the way around with mine tho.  just in between all the stock ones.    but that is were they always start to come apart tho, is the bottom.
i love oregon wheelin.
Early
swapped89
Ya man winks is the :pokinit: thats were i got the drill and tap today.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
axled89
what tire were you runnin in the that vid that early posted up???
swapped89
Anybody got a set of rear ifs springs? I'm gonna swap out the main TG leafs up front with stock rears hopefully drop it down another inch or two. Then cut my my fenders and wrap my beast with mossy rock.
When I was wheelin last weekend my rear tires got chewed up prettygood by my fenders. Kinda lucky they didn't get pop'd causethey got some pretty good gouges in them.
And ya EARLY I will measure for clearance of the diff studs to moving parts.
swapped89
I think ill be doin work on the diff studs friday or saturday. I'll let ya'll know how it goes/take pics and what not.
swapped89
Im
Quote from: axled89 on May 05, 2010, 10:28:05 AM
Im runnin 37x 12.5x15 Goodyear wranglers
Early
swapped89
 :beerchug: Nice! Thanks for the pic
I got a couple of the diff studs I could post tomorrow. Or I'll try to do it on my phone rrrrright noww
swapped89
Old diff studs out
new diff studs
new diff studs installed, pics kinda blurry.
twistedtoy92
swapped89
Quote from: twistedtoy92 on May 07, 2010, 08:59:02 PM
Very nice!
Thanks man! the install was simple. And i chased all the holes with a tap before i put the new studs in. Really helped clean up the threads and make it all feel good.
swapped89
swapped89
Quote from: Early on May 04, 2010, 06:35:59 PM
did a lil research today check it out.
I think everything i looked at. Has told me that the strength ratings are the same. (the grade that was marked on the Trail-Gear diff studs is 10.9)
Metric Fastener strength chart- http://euler9.tripod.com/bolt-database/22.html    Scroll down
Standard fastener strength chart - http://www.americanfastener.com/technical/grade_markings_steel.asp    Scroll down
CONVERSION Calc. for MPa(metric) to Psi(standard) - http://www.chapelsteel.com/mpa-psi.html
American Grade 10.9 Minimum tensile strength                                   150,000 Psi
Metric Grade 10.9 Min. tensile strength 1040 MPa converts to               150,839.208 Psi
:thumbs: :beerchug:
swapped89
Got the old Trailer Home pretty much completely scrapped! So far structuraly it looks pretty good just some surface rust but nothin a flap disc wont take care of.  :gap: Gotta get some new tires for it. So i can move it from my parents house to my house. Im probly gonna cut out most of the  angle iron cross sections and replace with some small tube steel. And cover the deck with expanded sheet metal. I havent quite looked into yet cause I have a bunch of other projects. But im sure its gonna be sweet when im all done.
swapped89
 Here is my :pokinit: paint skills at work. But this is the idea Im dreaming of. The front end would be part of a scrapped enclosed trailer, hopefully with swinging doors in the back also. Or just a camper for a truck. I think you get the idea.
The trailer deck is I think 25 feet long, I only measured with my arms stretched finger tip to finger tip a few times. And my truck is about 14'6" so i will have some room to play with  :gap:
If this is the idea i go with I will move the axles on the trailer to best distribute the load.
axled89
that's a sweet idea.   kegarator on the front of the trailer.    :biggthumpup:    LOL!!!
swapped89
Quote from: axled89 on May 10, 2010, 03:41:52 PM
Haha kegarator FO SHO! and some fold down bunk beds or somethin  :gap:/work bench and stuff ya know :cool:
axled89
swapped89
Here is a link to a thread on pirate. Horrible Tacoma crash. They say the driver walked away.
http://pirate4x4.com/forum/showthread.php?t=888913
thegoofster21
Quote from: swapped89 on May 17, 2010, 02:46:26 PM
and the one i made for the marlin board.
http://board.marlincrawler.com/index.php?topic=70809.0
it was a pregnant dog to get it on the road
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
swapped89
So ya. I haven't done anything on the Yota lately just been gettin my dirtbike and my GF quad ready for our riding trip. Headin out to Winchester OR. :gap:
NorCalToy
Did you ever finsih her runner?
I wanna go back to winchester again soon. Me and a few buddies were up they for a wkend back in march.
:flamer: IFS
swapped89
Na I still need to do shocks and links and limit straps in the rear. I just don't have the money for it right now. Still payin off the front end too. I'm hopin to get the ass end done before summer is over.
I'm gonna re-do the rear links in stock location only with rod ends at the axle and rubber bushings on the chassis. Make them outta some nice DOM. And I'm planning on bendin some shock hoops with my new JD3 bender. The hoops will go on the outside of the frame rail and they will hold some 2.0 King shocks with remote resi's. I got it all planned out I just gotta start buying :pokinit: and do it. But like I said I got other projects goin on suckin up my extra funds and time.
Jared88
Great job on you truck man. It's been inspiration for me to drop the money i drop on parts weekly! have also really enjoyed the build on your girls runner..( i frequent yotatech as well).........now...if only i could get my girl to pickup the grinder and head into the garage with me............
1988 standard cab, SAS, 5.29's....and a few other things  **SOLD**
1958 Volkswagen Bug, 2276cc, close ratio gearbox, quite a handfull.
swapped89
Quote from: Jared88 on June 08, 2010, 07:14:56 AM
haha ya i dunno how i got her out there. she usually only helps work on her stuff but its still nice to see her do work and be able to really appreciate the time and effort it takes to build these toys.
Thanks for the compliments on my truck, i hAVE DEF FIGURED OUT that more money spenmt onm good parts is most always the way to go. everything i have went cheap on has gone to :pokinit:
swapped89
 Started a new project last weekend. I put my bender together and built a stand for it :)
swapped89
