Swapped89 party bus picture update
Started by swapped89, August 19, 2009, 03:12:40 PM
swapped89
got bored saturday took a few flex pics to see how the clearance on the hoses and what not is. looks good to me.
could go another1-2" before hittin the bump stop. but everything clears nicely!( driver side compressed)
Driver side droop
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
87pickup
Quote from: swapped89 on March 29, 2010, 09:39:58 AM
Well I broke down picked up a trail-gear pump ordered the filter/res kit. Gonna have some hydro lines made up once I get everything home. Also ordered Daves offroad 3.0 bracket for the TG pump. And I got a rebuild kit for the surplus center ram just because. So this is no longer hydro assist on the cheap. :smack:
You will be happier in the end.
swapped89
Ya I think so too! :yesnod: Im gettin stoked about doin it all over again. With new parts.  I think "EARLY" might be stoppin by this weekend to assist in gettin "r" done!  :beerchug:
I cant wait to drive my truck again. :driving: This is the longest its ever been down. :slap: Except when the main bearings went out.
al76
NICE! Im sure you'll like it! I started on my pump with my buddy today..I should be done tomm and ill do a write up on my build on what I did on my truck.
F**k Idacurt
swapped89
Right on. Send me a link when you do.
swapped89
#275
Since im piecing together this hydro assist system on my 3.0 the trail-gear Hydro assist hose kit will not work for me. So i am having some custom hydraulic hoses made.
1 hose goes from TG pump to a special fitting on the steering box. The hose will have #6 JIC fittings on both ends and have to be about 5.5' long to be routed nicely from the box to the pump. I.D. 3/8" high pressure.
2nd hose goes from res/filter to the pump #10 JIC fittings on both ends 5/8" I.D. low pressure.
3rd hose goes from 3/8" barb on oil cooler to #6 JIC fitting on res/filter
got them quoted through an account at work and its only gonna cost me 66.00$
swapped89
Got my Hydro lines made during lunch!!! Im super stoked as long as my Dave'z Offroad bracket comes for the TG pump today i should have everything hooked up tonight. I also have to make a bracket to hold the TG res/filter but i got half of it made last night. I also tore out the old pump and hoses last night to prepare for the install of all this new  :pokinit:
pic of hydro lines i got made from Intermountain/Unisource
mattlosch
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
swapped89
So more bad news. just because i know axled89 likes to here me pregnant dog about things. Dave'z Offroad or the UPS shipped my steering pump bracket to Broad Run, Virginia!!! I live in Oregon. So Im screwed again. I might still go up with you guys tomorrow but i would be in my girlfriends 4runner so we'll see what happens.
TheCookieMonster
dude that blows. ive had that kind of :pokinit: happen before and it sucks, but o well what can you really do ?? to bad you couldn't get your cheap setup working im not sure what the deal was with that, seems like everything was correct  :dunno:. hopefully the other stuff works for ya  :thumbs:
swapped89
Quote from: TheCookieMonster on April 02, 2010, 08:07:22 PM
Ya i think the problem with the cheap set up was that my stock pump was allready on its last leg. If i rev'd the truck up to like 2 or 3 grand and turned the wheel slowly i could tell the Hydro-assist was workin. But it just wasnt cuttin it, ya know. And i didnt wanna just put another stock pump on. So tomorrow im gonna finish the bracket im makin to hold the new res/filter. And hook all the lines up. I think i can get the first part of the bleeding done with the lines hooked up to the pump i just cant turn it over and what not. I'll get everything done so when the bracket does show up I can slap it on and GO!! :gap:
swapped89
 Just called Dave'z and he said he dont know why UPS shipped it to Virginia but he is shipping another one to me ASAP!  :cool:
swapped89
Got all the lines and everything hooked up and bled as best we(me and EARLY) could yesterday!  Just waitin for another pump bracket to get shipped to my house from daves offroad.
Had to remove the radiator overflow to make room to mount the res/filter kit. It looks way bigger in person than it does on TG's site. Im just gonna use a big pop bottle to replace the overflow tank.
Pump hooked up and ready to go just waitin for the bracket!
mattlosch
Early
A little behind the scenes action. Layin lines next to the 44 mt/r
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
mattlosch
Early
jason's rig. haha, i just thought his rubber looked huge compared to him
swapped89
They do look pretty big in that pic. Thanks for the help sat. I'lll let ya know when that bracket comes in.  :beerchug: you get my message about makin plates to brace the frame where your slider legs will be welded on?
swapped89
#288
Another question for ya'll.
My ram seems to be moving in the opposite direction of my tires. I have the truck in the air on jack stands tires off the ground. And the ram un-bolted from the axle/tie rod.
This is the diagram I used to figure out how to route the hoses.
I have checked, double checked and re-checked and had my friend look at the pic and my set up. We both come to the conclusion that the hoses are in the correct order. but the ram moves the wrong way!!?
The hose with the duct tape on it goes to the top of the steering box.
But when the cheap set up was hooked up and working slightly it felt great the ram was helping me turn the direction i needed to turn?
swapped89
Any body got a clue  :inthedark: why it moves the wrong way, even though the hoses are right. Could it be a clogged hose, or bad steering box?  :willynilly:
Hey EARLY can you post that video you took? some how bleep that f-bomb? lol
swapped89
jackson58
 Generally the hyd. cylinders shaft pushes towards the drivers side knuckle with the body of the cylinder mounted on the passengers side of the axle. just switch the hoses around on the ram.
Dirt is for wheelin not for wearin you filthy hippie!
swapped89
Quote from: jackson58 on April 06, 2010, 07:14:48 PM
I did that. it goes backwords when the truck is off, when the truck is running it goes the right way. Its just wierd that it does not go the right way no matter what.
swapped89
I used the diagram to figure out which side of the truck the hoses go on. It dont matter if the ram is flipped if the hoses are oriented on the correct side of the truck.
jackson58
well that sucks, sorry I could not help. On my setup i had my hoses switched at first and then changed them then all was good. Good luck!
gnarrkill
you rollin to browns camp this weekend
79 toyota duals,caged,40 mtrs
the build thread i dont update
http://board.marlincrawler.com/index.php?topic=65367.0
swapped89
I dunno im havin troubles gettin my truck back together
Early
no package?  :dunno:
everyone cross your fingers for tomorrow  :beerchug:
swapped89
Package came but no bolts. I can't go get any bols cause ash is downtown all night. I can't get the pulley off the pump to get a bolt in the bracket. I think my GF has my wheel lock key makin it a total pain to finish my front bump stops. I'm pretty much fed up with everything right now and just gonna finish my truck this weekend. Sorry guys.
