Swapped89 party bus picture update
Started by swapped89, August 19, 2009, 03:12:40 PM
swapped89
Well I think i have decided to redo my cage! I built it to tight to the cab and it hits the cab. Besides I didnt really like how it turned out. Im just gonna call it a good practice run. Cut it off and start from scratch sometime after the fourth.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
mattlosch
Well damn that sucks but at least your gonna make it right. See ya this weekend??
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
crawln503
-85 ext cab swap on std Toyota frame, 3rz, built narrowed 6 lug 60's duals/4.7 42's iroks
-94 Ford CCLB 12v. 6spd, pump cranked, guages, lifted & lots of other mods:smokin:
-89 ext cab Toyota, 3.4, 5spd on 33's
swapped89
I dot think I'm gonna make it to browns camp. My starter is bein finiky. It only works when It wants to. It's like the starter and flywheel teeth don't mesh correctly all the time. Sometimes I have to put my truck in gear and rock it. To move the flywheel. Thentry starting it again. It's quite the P.I.T.A. I really don't wanna kill my truck in crushers and then not be able to start my truck cause I'm wedged in some rocks. Pretty lame.
swapped89
Quote from: crawln503 on June 29, 2010, 11:22:50 PM
sell it :dunno:
I dunno if I'll be able to get the thang off my truck without destroying it. Lol it's sooo tight I had to have a buddy help spread the b pillar hoop to get it on. I'm just gonna hack it and hope I can use some of the tubing for other misc. Stuff. :dunno:
mattlosch
swapped89
All right well after some heavy consideration. I'm cuttin the cage off tonight. Gonna try and get mystarter working/trim rear fenders. And I'm gonna go to browns camp if I get my starter working! :)
it's got a new starter.... The new one and the old one only work off and on. It f'n blows but I'm gonna bevel the teeth on the old one throw it in and see if that solves the problem.
swapped89
P.s. The problem is that the gear on the starter and the flywheel do not mesh every time. It's like the starter gear runs into the flywheel and doesn't engage the flywheel teeth, so no spinning of the flywheel= no starting, unless I can rock the truck back and forth in gear to move the flywheel to a point were the starter can engage it
swapped89
I hand filed the teeth on the starter gear. I gotta go do the family thing now so I won't have time to install it. But I'm gonna put this starter in tomorrow after work and hope it works :)
mattlosch
swapped89
swapped89
filieing down the starter teeth didnt help. Im gonaa try puttin a lil angle on the the flywheel teeth, And if that dont work im just gonna order a new flywheel from marlin. I think the problem is my cheapo NAPA flywheel i bought when i changed my clutch.
Also decided cutting the cage off and starting from scratch was ridiculous so im just goin ahead with what i got.
Added a tube below the rear window still need to add some triangulation and tubes under the front fenders but Im slowly gettin there. And made a hoop over the cowl/windshield wipers
Mega Baby Huey
The Art of Flying is Actually Quite Simple! You Just Have to Throw Yourself at the Ground and Miss!!!                                   All This Global Warming is Wearing Out My Snow Shovel!!!                        Paved Roads: Just Another Example of Useless Government Spending!                                          Toyota. Moving forward... even if you don't want to...
My Old Toy
swapped89
Quote from: Mega Mormon on July 07, 2010, 01:51:23 PM
nice rig!!!! i envy this truck!!!!!  :bowdown:
Hey thanks alot man. I really appreciate it. You got a build thread?
mattlosch
damn jason this is what i want on mine!
swapped89
Hell ya man. By the time I'm done with this I'll be a pro. And thinkin bout buildin cages for people or bendin anything you want. Shock hoops and sliders and what not :)
mattlosch
do it and earn some coin on the side! i will be your first customer lol cage and rear bumper!
swapped89
Mega Baby Huey
Quote from: swapped89 on July 07, 2010, 02:41:38 PM
my truck is mostly stock... the link is in my sig.
My Old Toy
toyotanner
possible 2nd customer! partial exo and partial tube bed.
swapped89
Quote from: toyotanner on July 08, 2010, 12:47:50 PM
Im down. Sounds like fun to me :)
mattlosch
gtoyonrocks
Looking good. I'm glad to see ur putting that bender to good use.
TIMS89CRAWLER
cage looks good man... I would highly suggest adding some triangulation and gussets in there.... one of the worst parts about an exo is they are a pain in the ass to get door bars into (A pillar to B pillar bar) which is one of the most important parts of the cage. The reality is exo cages are more for looks than structure as they require so many bends to make them fit tight and bends make metal weak... If I were you I would invest in a rule book from an offroad racing organization (SNORE or SCORE) and read up on the cage section for some strength ideas.... its lookin good though!
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
swapped89
Thanks man I'll look Into that. I still have alot of work to do on it. I'm planning on gusseting the four corners of the windshield with tube and a big v shape on the rear window with a post up an down in the middle of that. And then the same v shape on the roof with a tube from the b pillar hoop to front top windshield tube in the middle of that v shape. Prettymuch alo like the cage on the cover of this months CRAWL mag. And then a "A" shaped tube in front of the windshield connecting the top windshield tube to the tube above the cowl. Then more tubes from the a pillars to the front bumper yada yada yada.
Early
Quote from: TIMS89CRAWLER on July 09, 2010, 08:23:02 AM
thats an awesome idea. Any idea where something like that could be picked up?
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
TIMS89CRAWLER
Quote from: Early on July 09, 2010, 01:04:32 PM
you can download the SNORE rulebook on their website I believe you have to buy the SCORE rulebook but if you ask around on pirate I would imagine there is one floating around somewhere. sounds like a good plan on the gusseting and triangulation too man!
www.choptechfab.com
CHECK THE BUILD
swapped89
painted my new knuckles and hi-steer arms today!  :bling: pretty excited about these bad boys. just wish it was a lil cooler outside so i could work on my pig. :cool:
gtoyonrocks
Sweet... I have the same steering arms and knuckles.... I like the green paint.
