Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
well i  went down today  and  put the u bolts  on  so the f150's  are  nice and tight,  problem is  i need  some  degree shims to  rotate  the pinion up
i might look at grinding the perches off the ifs  housing  but since i dont have any spacers  i'll run the  axles  under it  till i can afford to go 5.29's  then  i'll put the 35's on
and get this, i measured  the  spring to frame height  with the old springs on  and  then  after  i got the f150's installed,  the f150's  sit 1/2 inch LOWER
but the are softer  so  hopefully  it will ride really smooth
i'm  also doing a  weird  double hanger set up,  using the f150  shackle  and a  mixmatch of toyota shackles
i'll take a pic tomorrow
anybody got another f150 shackle ??  i cant find my other one :snare:
lilbuddy
RIP Kyota.... you are the man
GET IT!!!
thanks Chris,  thats the way  i mounted the drivers  side today
did you use degree shims to rotate the pinion up??  or  did you cut  and reweld the perches??
lilbuddy
I didnt need to do anything. Just with the springs and dual shackles (using a stock f150/chevy shackle amd a 6" eye to eye) it put the pinion at an angle that was perfect.
GET IT!!!
#2134
Quote from: LILBUDDY on April 13, 2008, 01:04:47 PM
sweet,  i'm thinking  my angle will be better  when i put  the bed back on, if not i'll get some  steel shims  and weld them to the spring perch
lilbuddy
I think yours may not be so good cause you have such a small shackle thats the second shackle.
If i were you id switch the shackle placement that u have. put the longer one hanging down and the shorter one resting against the frame. Itd give u a better shackle angle AND will keep it from inverting more.
EDIT: Or is it just an optical illusion and they are the same length shackles? If not like i said put the smaller one against the frame and the longer one hanging down.
GET IT!!!
i gotta make some longer shackles,  those are too short to allow  full compression
i removed my header  and welded up all the little cracks  with a 3/32 6011 rod  and 40 amps,  it  did a very good job  ,  it sucks  cause my old  headers  have lost almost all the ceramic coating, :rivers:   they wont last  but  another year or so before  they start falling apart
first pic  is  the pipe  from the header  to the glasspack,  Jordan  was  getting a little happy  with the sawzall  when he was under there
unclejpl4x4
dam glen clean that thirdmember
Jordan7118
Quote from: 79coyotefrg on April 13, 2008, 03:54:53 PM
I just did what I was told  :slap:
Quote from: Jordan7118 on April 13, 2008, 09:39:45 PM
I'm sensing some hostility in this thread :eye: :eye:
:rofl:
unclejpl4x4
darn kids always running around with there saw-zalls.   It's alfun and games till some one losses a limb.
Jordan7118
Quote from: DirToyBoy on April 14, 2008, 05:54:30 AM
:rofl:
Haha! Nah, I'm just dishin' it back to Glen.  :ladys-man:
Yoat Goat
Im kinda leary about the double shackle deal. Are you gonna have a locking mechanism to keep it on the frame when not wheeling?
T urning
O ver after
Y ears
O f
T rail
A buse
Quote from: Yoat Goat on April 14, 2008, 04:47:42 PM
yes  i was  thinking about that today,  i think a large  pull pin  will do the trick
i'll  think on it awhile  and  get back atcha
Quote from: unclejpl4x4 on April 14, 2008, 06:15:27 AM
darn kids always running around with there saw-zalls.   It's all fun and games till some one looses a limb.
:rofl:
YotaJosh
Quote from: 79coyotefrg on April 12, 2008, 06:36:56 PM
I got 2 that I'm not using.  :gap:
Don't worry about the pinion angle, it'll all work out once you get the bed on it, and maybe find some longer shackles.
Getting closer everyday, huh?  :thumbs: :yesnod:
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Quote from: YotaJosh on April 14, 2008, 07:54:54 PM
:woohoo:   :smooch:  thanks
yes  i got me  some longer shackles  for shipping  :woohoo:  should be here next week :woohoo:
:snare:  now how am i gonna mount  the spare gas tank  :smack:
i might look at re routing that
Yoat Goat
T urning
O ver after
Y ears
O f
T rail
A buse
unclejpl4x4
spare gas tank ........................ U can bearly fill one
Quote from: unclejpl4x4 on April 17, 2008, 10:43:38 PM
:rivers:
well thanks to Krawlz,  i  recieved a set of  extended shackles  very similiar to lilbuddy's
WOO  i found the pic
i think it said " Glen, I'm ready to go!!!"
and i had  to do something a little different  since my reciever hitch was kinda in the way,  SOOOOO,  i cut the  top off a  couple  old  motor mounts  and tacked them in place  :disturbed:
Yoat Goat
"Hi ho silva and away!!!"  :horseride:
T urning
O ver after
Y ears
O f
T rail
A buse
unclejpl4x4
:down:  no  its 86*  and  70 % humidity  :down:
Jordan7118
What you waiting for  :headscratch:  It's only going to get worse, my friend! :ack:
Oh, and update your poll  :moon:
