Dingman's Build Thread
Started by Dingman., March 01, 2009, 08:42:37 PM
Dingman.
Cliff notes:
Engine:
-3.4L swapped from a 99' tacoma.
-Custom made crossover pipe/exhaust
-cone intake
-Magnaflow high flow cat
-Magnaflow muffler
Front axle:
-chevy dana 60
-5.38 sierra gears
-sierra gear master install kit
-arb air locker
-chassis unlimited steering arms
-solid diff cover
Rear Axle:
-14bolt ff
-5.38t sierra gears
-sierra install kit
-yukon spool
-solid diff cover
-high angle driveline 14bolt- toyota flange
Transmission:
-R150f
Transfercase:
-inchworm v6 adaptor
-Marlin xd-07 23 spline adaptor
-23 spline crawlbox from turbo truck
-23 spline 4.7 gear rear case
-Longfield chromoly output shaft
-two stock crossmember mounts
Armor:
-Trail gear sliders
-Trail gear front bumper
-Trail gear Crossmember
Wheels/tires:
-39" bfg baja ta
-17" soft 8's
I guess its about time for me to make a build thread.  So here it goes...
Ive done a bit to it since i got it but herwes a recap.
I own a 1990 toyota 4runner.  I bought it with 240,000 miles on it stock as can be. 3.0, 5 speed.
Now we did have a problem the day we got it on the way home...
The damn 3.0 had a fuel fire...  A minor setback.  Got it running a little while afterward.
So i removed the running boards and thats all i did for a little.
I did some wheeling like that for a while and then i decided i just wanted something to build up.
Threw some 33's on it and a rear locker and called it good..
I had a problem with the rear diff for the 2nd time after a local guy built it so after that i decided to regear it (5.29's) and sent it out to zuk to have it built so i wouldn't have to worry about it again.
I ended up putting an ifs lift on it.   :dunno:
Regretted that decision and about 3 months ago i sas'd it..
During the build i found a locked front diff so i picked it up and used a 4" sas kit.
Got sick of the 33's and got some 36's.
I need to still convert the rear to leafs...  Which was gonna be my next mod, but other things came up..
As of now...   The 3.0 finally took a :pokinit: on me after 258,000 miles on it..  I managed to only get 18,000 miles out of it since i got it, but overall i don't think it was a horrible run for a 3.slow that never had the head gaskets replaced...
So i bought something to replace it..  which i am working on gathering information on exactly what needs to be done.
:greengrin: :greengrin:
Dingman.
Okay for this 3.4 swap..
I purchased the motor, wiring harness, and ecu.  Well basically everything out of the engine compartment.
This all came out of a 99' tacoma, auto, 4x4 package.
I know i will need to get:
99 tacoma 3.4 M/T  ecu,
charcoal canister as the donor one broke.
Thats all i know of thus far.
I believe i can resuse the 3.0:
flywheel,
clutch,
oil pan,
radiator,
fan and shroud.
Anything else im forgetting?
Im not absolutely positive about reusing the 3.0 flywheel, can someone verify?
TIMS89CRAWLER
ya you will love the power for sure man! looks good!
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TheCookieMonster
the 3.0 pan will work but its a mid sump pan for the ifs....with the straight axle you might need the rear sump pan to clear your steering....the swap we did the truck still has ifs so the original pan worked.
TIMS89CRAWLER
ORS is out of business.... even if they werent they were wayyyyy over-priced for EVERYTHING especially wiring harnesses..... dont wast your time with all that crap man..... do some research on the boards and if you need help with anything specific just ask me man..... its really an easy swap though you will be just fine....
www.choptechfab.com
CHECK THE BUILD
Thomas P
its about time mike, you ever get those sliders on????
'14 Camry SE
SCX10 Honcho on roids!
TIMS89CRAWLER
the 3.0 pan will work... however its a mid-sump pan and might hit your steering and or axle.....
www.choptechfab.com
CHECK THE BUILD
bolt your 3.0 pan up son.... whoopty do.... if it dont work.... you can take the pan off and hit it with a hammer to clearance it enough to clear the steering.
Dingman.
Yes thats what i plan on doing..
Ill see how it works out...
Still looking for a 3.4 M/T ecu.  and clutch components and then ill pull my 3.0 and bolt the 3.4 up and deal with the wiring
wampum
Mikey! You should have pulled the motor when you got home. What's holding ya back?
1985 EFI Xtra Cab -> http://board.marlincrawler.com/index.php?topic=50415.0
1993 4x4 22RE
Dingman.
Quote from: Wampum on March 03, 2009, 10:25:04 PM
IDK man,  i still need some stuff for the motor..
Plus it was raining.
ill get to it this weekend for sure...
wampum
Is your Runner gonna be outside the whole time?
It's gonna suck if it's raining all the time when your trying to work on your rig.
Let me know when you have free time to work on it, and I'll try and come help you out.
1993 4x4 22RE
808
Quote from: Wampum on March 03, 2009, 10:36:44 PM
"help" moral support by sleeping while u work ahahah jk
85 toyota pickup(sold)
92 toyota ex cab pickup SAS'd 4d's 27 spline chromos 5:29's and lockrights front and rear arp knuckle studs
my build: http://board.marlincrawler.com/index.php?topic=44691.0
Dingman.
Hey will do..
unfortunally yes..  My work space is the driveway..  Yes its like that for everything, even that sas i did.
I hope to get the motor pulled and at least put in so i can roll the front into the garage to work on the wiring so its not in the rain.
wampum
Quote from: 904_runner on March 03, 2009, 10:39:42 PM
Hey will do..
Yeah, errbody does the driveway work. It would be nice to have some indoors for getting all that wiring figure out. If not... start settin' up the tarps!
1993 4x4 22RE
84t0y
and for bobbing my bed!
and suspension work and sliders and maybe even bumpers.
TIMS89CRAWLER
yes if you plan to build your own x-over pipe then you will.... I hate dealing with exhaust so I take them into my local exhaust shop for all that crap  :yupyup:
www.choptechfab.com
CHECK THE BUILD
wampum
Did you make any progress today?
1993 4x4 22RE
86bobbedtoy
I hate 3.0's
head dont like its been overheated, just looks like expensive oil was used.
lobes do look worn
Dingman.
#20
This is what i got done today.
Now im tearing down the 3.0L motor in the garage..  gonna try to tear it down quite a bit..  Im going to get a new flywheel/ and clutch components for the 3.4, so i can't put the motor back in untill then, i don't get paid until Monday or Tuesday so hopefully next week i can at least get the motor back in.
wampum
1993 4x4 22RE
Dingman.
lol.
I spent 800 on the motor and everything related to it from the donor truck..
I am going to get a new flywheel/clutch assembly..  I think mine is still good but i don't want to have to do it again later.
and i will have to buy a M/T ecu since the one i have is for a automatic trans..
Once i get the flywheel and clutch parts im going to put the motor in and then i can worry about the wiring.
TIMS89CRAWLER
you want to use the 3.0 clutch and flywheel..... as for the ECU just get the same year ECU as your engine in the manual trans version and the plugs should be the same.... my buddy got one from the local wrecking yard and the plugs were different but after some research we realized the wrecking yard gave us the wrong ecu.... they made it right with us and the proper year ecu plugged right in to his engine harness.... let me know if you have any questions regarding the wiring.... I will grab my notes from my buddies place and take some pics of the splices we made as well....looking good though bro!
www.choptechfab.com
CHECK THE BUILD
Dingman.
Yea thats what i was thinking..
Do you know if that will make the pedal a lot stiffer?
On a side note im going to buy a welder tomorrow, so i can start on my exhaust, sliders, bobbing a buddy's rig and converting mine to Chevy in the rear..
Any suggestions on a welder.  I don't really want to spend more than 500..."
I was thinking either the lincoln 125  $430, or the lincoln 140 $530.
Im going to swing by mjb welding tomorrow to see what they have though.
Thomas P
i drove by the other day to see if you were workin on the beast, the day you worked on the motor but no one was around  :dunno:
posted the pics
http://board.marlincrawler.com/index.php?topic=44652.msg694129;topicseen#msg694129
'14 Camry SE
wampum
That's sick you are getting a welder.
I would say just resurface your flywheel unless it is warped. Heck dude you could resurface it down in machine shop.  :biggthumpup:
1993 4x4 22RE
Dingman.
Quote from: Wampum on March 09, 2009, 09:15:58 PM
Nah id rather let someone do it that know what they are doing.!!  Lmao
Thomas P
looks good, what welder did you get?
'14 Camry SE
Dingman.
Little lincoln 140c...    120v..
I like it soo far..
