A.J.'s Runner - "Please Stand-by"...Product Review
Started by CTENG in KS, July 14, 2004, 01:22:37 PM
skipnrocks
Quote from: topar on November 18, 2007, 05:25:00 AM
Try putting a spare gas tank or cooler or some type of lockable box opposite of the spare tire I like the spare in that location.  Run bars just above and below the side windows connecting the rear and middle hoops.  I think that would look good.  However I think it looks good as it sits, once its level.  :thumbs:
Yep sounds good to me!  I still think that wood is pimp!!
WILLYNILLY
Shoyrtt
Quote from: CTENG in KS on November 17, 2007, 06:51:48 PM
I may get a set of 4.7's soon, duals will wait till after I have linked the rear.
When you link the rear, bring it up a bit (a little too saggy now  :therethere::twocents:). I agree the wood looks good. :)
http://www.sharetrails.org/
Jud
WOW I just read this entire build! You do some crazy looking stuff but it always turns out bada$$!
I don't remeber if I read it or not. But How is that traction bar working out? I had thought about using that stock front axle link bracket thingy to make a traction bar like you did here.
"bout tree fiddy"
CTENG in KS
It's here It's here It's here!!!!!
TIME TO PLAY!!!!!!!
skipnrocks
WILLYNILLY
CTENG in KS
Scratch and dent $299 plus shipping!
Can't beat that!
Wermz84
I like to Drive!
skipnrocks
wow, where from, and what thickness is it rated 4
WILLYNILLY
Yota4life
Quote from: CTENG in KS on January 14, 2008, 08:44:42 AM
Can't beat that!
I didnt know they offered those! I was about to buy a new one for 400$ Ill have to give them a call
CTENG in KS
It is a dual voltage machine.  On 220 it is rated to sever 1/2 inch I believe.
All I could find were some rubs on the outside of the case, it don't looked very scratched or dented to me.
skipnrocks
Cool, was it online you got that?  I really want one.
WILLYNILLY
CTENG in KS
Quote from: skipnrocks on January 14, 2008, 12:57:29 PM
Go to PBB vendor section for TOOLS, you can't miss the HUGE thread about these.
skipnrocks
WILLYNILLY
Doof
on my way... why have one welder when you can have two??
:wiggle:
skipnrocks
Quote from: sillywilly on January 14, 2008, 09:52:09 PM
:wiggle:
Is it a welder, I thought it was a plasma cutter?  But having two welders iss cool!!  LOL
WILLYNILLY
Doof
:smack:
i just assumed it was a welder... didnt look at the face of it... a plas would be tits to add to the shop
CTENG in KS
I now have a wire feed welder, a stick welder, and the little plasma.  I returned the POS HF compressor though cause I killed it on the first tank full.  I have ordered another so no updates until it gets here.
skipnrocks
Quote from: CTENG in KS on January 15, 2008, 10:46:59 AM
What size compressor do you need for your new plazma,  I have a 35 gallon but I dont know if its big enough?
WILLYNILLY
CTENG in KS
35 gallon won't fit in my garage, but thank you.  Size is not much of the concern.  It needs to put out AT LEAST 4.5 cfm at 75 PSI to provide enough air.
skipnrocks
Your welcome!!  LOL,  That output isnt too bad, could be met with many  compressors.  Again nice score!
WILLYNILLY
CTENG in KS
Weather is getting better so BACK TO WORK!   :_order:
The bed is str8 now and the hoop is cut down and will be integrated into an X-brace later on.  Time to start collecting parts to plumb the fuel cell.
Wermz84
:hyper:  CTENG is thawing out for the Summer....   :)
I like to Drive!
CTENG in KS
YUP!  Happy to be able to get my weld on!  Now if I could figure out how my plasma cutter works I would be golden.  I am a plasma RETARD!
CTENG in KS
Figured out the plasma.  WHen I put the new tip in I forgot to put the ceramic isolator back in with it so i was using the whole tip as an electrode...DUUUUHHHHHHHH....   :hammer:
Now it works more better.  I don't make the prettiest cuts, but at least I will be able to do compound shapes with ease.  On a lighter note, this thing goes through 3/16 plate like a hot knife through butter.
MMMM hefty gusset good!
unclejpl4x4
I got shaky hands 2  at least u got a plasma cutter and not the blue wrench
CTENG in KS
It is tough to keep in a good position to make the cut smooth...as I move the cutter I get worser and worser.  I will practice to get perfect.
*** YELLER ***
nice work AJ try some of those bug triangle magnets and a straight edge to steady the hands of a master fabricator  :biggthumpup:
:usa: :beerwhack:
except BACON
CTENG in KS
They have this tricky little device that you put the plasma torch in and it holds it at the perfect hight off the metal and it is on rollers so you can be like a human powered plasma CNC.
skipnrocks
Quote from: CTENG in KS on March 10, 2008, 08:50:33 PM
I wondered if there was something like that, that would be cool.  There is also I jig you can get, but it may cost a few pennies.
WILLYNILLY
CTENG in KS
Started the dr side rail for the flat bed...took me 2.5 hours to build it...like some kinda OCD or something, I couldn't get it JUST right.  Came out good though...but not done.
