oregon 3rd gen build ****FOR SALE****
Started by TIMS89CRAWLER, November 26, 2007, 01:49:55 PM
toyotanner
did you get the bodylift off yet?
TIMS89CRAWLER
 :thumbdown: not yet as soon as I get the motor all mocked up and the mounts built I will pull that off... I just like having the extra space while moving the motor around in there...
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TIMS89CRAWLER
here is close to where it will sit for good.... I need to measure it all up and build some mounts now.... my engine stand holds it perfectly where it needs to sit... worked out great...
here you can see roughly where the mounts will sit... I have been going off mike's pics in his build but I will do some more measuring once my buddy comes over in his third gen....
and it has quite a bit of clearance with the body lift of but I dont think it will be all that bad without it anyway...
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
ok so that motor placement was wayyyy off here is the final resting place... :yupyup:
here is a shot of how I built my motor mounts
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I have also been busy building my crawl box with my mc07-r10
:beer:the tear-down...
the adapter!!
all cleaned up and ready to be a crawler
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
test fit the adapter to the crawl box
shift fork with the keystock welded on and installed back in the crawl box
old spare parts!!
www.choptechfab.com
CHECK THE BUILD
mtsnow29
nice work on the swap... looks to be coming along nicely. i bet your getting anxious. cant be easy. i would be  :shocking: to get it done. keep up the nice work.
TIMS89CRAWLER
Quote from: mtsnow29 on May 22, 2008, 11:23:04 AM
thanks bro... ya I am getting super excited I want to go wheel this beast now!!! ya I have to pull the motor one more time to do the final welds on the motor mounts and paint the frame up again then I will put her back in for the final time I hope  :crossed: then its just down to getting the wiring all figured out...thats the fun part though  :yupyup:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
anyone happen to have a pinout for a 1996 taco harness I just need to know whats what in the 1k1 & 1k2 plugs???
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
ok so I made some progress over the long weekend.... not as much as I would have liked to make because I had some other projects going on around the house.... I got my motor pulled back out, mounts final welded and painted, got my shock hoops welded on as well as got my winch mounted up.... now tonight I will get the motor back in for hopefully the last time and stab the tranny & t-cases in there as well.... I will be cutting the floor out tonight for the flat belly I will have to do more cutting then planned since the body lift is finally gone  :woohoo:
here are some pics
no body lift anymore  :woohoo:
motor mounts finalized
shock hoops installed
and my winch mounts
I also got my tranny/t-cases all assembled and ready to install this evening
www.choptechfab.com
CHECK THE BUILD
damn talk about progress, i cant wait to see it finished.
TIMS89CRAWLER
ya I finally have some damn motivation to get this thing done.... I will have it done by our northern oregon get-together @ browns camp with a bunch of the guys from this board.... I got all the interior stripped down and ready to start cutting my floor out after work this evening.. then I can get the motor, tranny and t-cases all put in and finish up the t-case crossmember.....
here are some pics of the original trans tunnel all stripped down ready for some chopping
www.choptechfab.com
CHECK THE BUILD
toyotanner
hey i just noticed your missing the ex-cab windows and the rear window... my friend just decided to pull his cab off and build a buggy he has a complete 3rd gen ex-cab minus the bed and dash. so if you need those windows or the backseat interior or whatever let me know. or if you'd want the whole cab its marroon.
TIMS89CRAWLER
how much for the whole cab??? clean title?
www.choptechfab.com
CHECK THE BUILD
crawlerdan
lookin great man!! your in albany area right?? i got married in corvallis :D
i might need to come see this before our get together...and steal your welder :D
toyotanner
its a washington title not sure if its clean or not... its already cut out for flatbelly no dash or front seats
TIMS89CRAWLER
Quote from: crawlerdan on May 27, 2008, 07:07:11 PM
ya I am in albany.... feel free to come check it out anytime man....
Quote from: toyotanner on May 27, 2008, 10:53:35 PM
thats cool just find out what he wants for it and let me know... if nothing else I want the x-cab windows and passenger door if its any good.... let me know bro :thumbs:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
got the motor back in last night.... now the motor mounts dont fit quite as well :dunno: they must have warped or moved just a hair when I welded them up.... its ok I will make them work but it does piss me off....
this one fits just perfect...
this one not so much  :thumbdown:
got the harness ran through the firewall....
ecu mounting location figured out
I finally started chopping up the taco harness to get the plugs and wires I need sorted out..
I need to find a pin-out for my 3rd gen v6 harness to figure out what is what for the guages and other circuits needed for my 2rz harness :dunno:
www.choptechfab.com
CHECK THE BUILD
toyotanner
he said 300 bucks for everything. cab, doors, hood, fenders. not all in perfect condition but pretty good. w/ clean washington title doesnt have any plates.
Quote from: toyotanner on May 28, 2008, 05:58:14 PM
JUMP ON THAT!
TIMS89CRAWLER
I want that beast.... where at in washington is it or is it in oregon?
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
think ya can get a pic or 2 of it and post them up on here for me im all excited now! that would be cool if ya can...
www.choptechfab.com
CHECK THE BUILD
toyotanner
its in milwaukie oregon right by portland. i'll see what i can do for pics....
TIMS89CRAWLER
 :thumbs: hell ya man I want it I just need to figure out when I will get a chance to go pick it up.... and I kinda wanna see a pic of it first too... thats cool man thanks again...
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
ok so I think I am going to pass on the cab deal since there is no dash I will have a hard time getting an oregon title they need it to be intact with all the #'s present.... I however do want the x-cab windows, hood, passenger door if it is straight..... I already have my rear window and interior parts so I should be good on all that...you should find out how much he wants for those parts I listed....thanks bro :thumbs:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
oh ya and I almost forgot to post some progress from last night....
I moved the cab way to the back of the frame to make it much easier mounting my motor, trans and t-cases I will be getting all that installed over the weekend finally
:woohoo:
now you can see I have a little bit more room to work with while installing all my drivetrain  :yupyup:
although I will be moving it back more before its all over I have a feeling I didnt go far enough to get the transfer case x-member in there...
www.choptechfab.com
CHECK THE BUILD
Wermz84
I like to Drive!
TIMS89CRAWLER
Quote from: Wermz84 on May 30, 2008, 01:25:14 PM
Damn man.  Great progress!   :thumbs:
well I thank you my friend. :biggthumpup: I got plenty more work to get done in a quite short period of time.... I will make it happen though :yupyup:
www.choptechfab.com
CHECK THE BUILD
toyotanner
he said $150 for passenger door ex-cab windows and hood. i think the hood has a little wrinkle in the front of it but probably repairable.
GJToyotabug
I know where you can get a NEW hood for like $56 it's from this place called certi-fit the only thing that sucks is you would have to pick it up form one of their locations
