oregon 3rd gen build ****FOR SALE****
Started by TIMS89CRAWLER, November 26, 2007, 01:49:55 PM
Quote from: timsyota on April 21, 2008, 11:59:30 AM
thanks man   :beerchug:
the flatbelly mount im building will be just like 4rnrrick build on his tuki suzuki project....I still have some work to do on it though
he is definately an inspiration.
TheCookieMonster
Quote from: HO on April 21, 2008, 12:00:34 PM
you got that right :yesnod:....all his ideas are great :yumyum:...im stealing some of them :outtahere:
TIMS89CRAWLER
ya and one hell of a fabricator for sure!!
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Quote from: TheCookieMonster on April 21, 2008, 12:04:02 PM
Quote from: timsyota on April 21, 2008, 12:04:15 PM
Oh i have some ideas, thats for sure
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
so does anyone know what clutch and flywheel I need for installing my 2rz in my truck with W56 trans w/W59 bellhousing... I am assuming that I need the 4x4 tacoma 3rz flywheel & clutch?? is this correct or does anyone know?
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
Ya from what I understand I just need the stock tacoma clutch and flywheel.... I priced them out from the local parts store and its $249.99 for the clutch and $60.80 for the flywheel with a $40 core charge... I also ordered all my oil pan parts to convert to a rear sump pan on my 2RZ and also picked up my whole tacoma dash wiring harness and began tearing into all that.... I put my order into marlin for my MC07-R10 adapter and the rest of my front axle rebuild parts.... everything is back-ordered  :thumbdown:
www.choptechfab.com
CHECK THE BUILD
get your clutch from marlin dude!
if your spendin that much.
TIMS89CRAWLER
ya I will im definatley not spending that much for some cheap :pokinit: from the parts store thats for sure  :thumbdown: but the price on the flywheel isnt too bad  :dunno: I got my oil pan parts in this morning.... everything except the dipstick it should be here this afternoon or in the morning  :woohoo: now its time to get the motor in the truck :woohoo:
www.choptechfab.com
CHECK THE BUILD
you may as well buy a flywheel from marlin as well, it has the .026 step on it or whatever.... if your in there.... may as well.
TIMS89CRAWLER
ya if they have it in stock I may get it from them.... It does not show one for the 3rz though but I imagine they have on for it.... :dunno:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
 :woohoo: picked up my ECU this morning for $85 with a 6 month warranty  :woohoo: as soon as my knuckle parts get here so I can put my front axle back together I will be moving the truck to my work to get the motor installed.... all I need to start it up now is just a starter.... to drive the truck I still need a flywheel, clutch, header and a few little things but its all down hill from here... :yupyup: I will work on getting up some new pics....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I made a list off the top of my head of parts I have purchased since I started this build and im not doing as bad as I thought as far as spending goes... I guess I better start spending more.... :yupyup: these are just things I can think of at this point....and I am nowhere near done spending for this project :sheerterror:
-2RZ engine, bellhousing, and engine harness $450
-W56 trans & forward shift T-case $250
-Marlin crawler spring hanger $90
-Marlin crawler HD steering box mount $60
-96 taco dash wiring harness $50
-96 taco ECU $85
-MC07-R10 crawler adapter $369
-oil pan conversion parts for 2RZ $250
-front axle parts $130
-shackle hangers $35
-misc steel $100
-misc bolts & hardware $100
-R150F trans (not yet installed) $250
TOTAL THIS FAR              $2219.00
then these are parts I bought for building my 1st gen truck which was parted out for this build to begin
-All pro offroad 5" long travel springs $600
-All pro shackles $180
-All pro hi-steer $400
-All pro U-bolt flip kits $120
-IFS rear axle $150
-Marlin extended brake lines $90
-Marlin wheel 1.5" wheel spacers $90
-Marlin tall shock hoops $70
-IFS steering box $100
-greasable bolts for suspension $140
TOTAL STUFF I ALREADY BOUGHT FOR 1ST GEN (PARTED OUT) $1940.00
TOTAL INVESTED BETWEEN MY 2 TRUCKS $4159.00
just a rough idea of what it has cost me so far to get where I am at... and I have fabricated alot of my parts by myself....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I got tired of the timsyota name so I changed it up some  :biggthumpup:
www.choptechfab.com
CHECK THE BUILD
oh someone else has OCD, like me :gap:
NorCalToy
Quote from: OREGON89CRAWLER on April 25, 2008, 04:09:49 PM
i thought it was somebody differenet so i looked at your name and was like SWEET another 89...realized it was you and that ive read the thread already...
:flamer: IFS
TIMS89CRAWLER
haha oops I got all my front axle parts in from trail gear today so hopefully after work I can get the front axle back together and mounted back under the truck... that means tomorrow I can start mounting up the 2rz!!!   :woohoo:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
got the front end partially put back together last night... or at least I got the knuckles rebuilt and got the housing back under the truck before it started raining like hell on me.....tonight I will finish putting the axle back together and get her back on all 4 tires once again..... then this weekend I am hoping to get my motor mounts finished for the 2rz and test fit the motor  :woohoo:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
time for some new pics! :woohoo:
I finished up my t-case crossmember finally  :bling:
got my hanger the rest of the way welded on and painted all pretty
got the front axle all finished up and painted with rebuilt knuckles & a  :turtle: knuckle ball kit
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I also got my  :turtle: steering box mount welded on
here is a shot of the front dovetail....
www.choptechfab.com
CHECK THE BUILD
86bobbedtoy
TIMS89CRAWLER
ya I guess it would be a dovenose huh  :smack:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
 :woohoo: marlin is shipping my mc07-r10 today finally  :woohoo: this means I can get my motor, trans, and t-cases installed finally!! yay
www.choptechfab.com
CHECK THE BUILD
Quote from: OREGON89CRAWLER on May 06, 2008, 03:25:14 PM
you installing as one unit?
