oregon 3rd gen build ****FOR SALE****
Started by TIMS89CRAWLER, November 26, 2007, 01:49:55 PM
0 Members and 14 Guests are viewing this topic.
TIMS89CRAWLER
Quote from: greenjacob on December 22, 2008, 12:49:05 PM
you gett that thing done you still needing any parts
I still need a couple things but nothing too big... its just down to the nitty gritty now and figuring out why my stupid ass motor wont run ???
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
greenjacob
you looking for a frount axle for your other truck still. motor wont run you ever gona get hat thing goign alot of snow on peak
1986 4runner 93 22re 5.29s locked f/r duals twin sticks 39.5s
TIMS89CRAWLER
 :woohoo: the truck runs finally.... one of my fuel hard lines after the fuel filter was clogged with rust and thats why there was fuel at the filter but not at the fuel rail.... but anyway it finally fires up and runs pretty damn good actually it just needs exhaust and a few other little things.... then I am down to drivelines and building my tranny tunnel and finishing up some cosmetic tubing work....but it will be going for the test run on new years at my buddies property in crabtree so it should be fun!!!
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
ok so I got a bunch more stuff done to the truck last night... trying to have it ready for our new years wheelin party.... I got my rusted fuel hard line replaced and new fuel filters installed... got my rear axle re-assembled and all the brakes plumbed and bled....I also got the clutch plumbed and bled and then we realized that we forgot to install the little retaining clip/spring onto the clutch fork and throwout bearing so the clutch fork wont stay put.... I am gonna keep my fingers crossed that it will work the way it is for this wheelin trip as I dont care to pull the trans out again.... another problem I ran into was my power-steering hard line from my 3.0l is a tiny bit too small to fit on my 2rz pump....so I need to figure out what to do with that now... I will post up some pics of the steering fitting after work today and see if anyone has any ideas....
www.choptechfab.com
CHECK THE BUILD
greenjacob
sounds like its going good get that :pokinit: done lets wheel
yeah no :pokinit:, finsh that pile of crap already.
:gap:
TIMS89CRAWLER
ya jake wheelin at crabtree on new years day man my truck will be there! take yours
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
alright well I got a bunch more :pokinit: done to it tonight.... we fired it up and let it run for about 15 minutes to make sure that the smoke it was blowing the other night was just oil in the cyls from me turning the motor upside down to put the new oil pan on and not a new issue and it quit smoking in about 2 minutes and will not start again so that made me happy, the motor runs great with no noise at all and no smoke and it revs so fast!!!  :cheese: I ran a new hard fuel line all the way from the rubber line off the motor to the tank. there is a fuel filter under the cab and one on the motor so I have no more fuel leaks and it works great
the line runs along the top of the frame until it gets under the cab then it runs on the inside of the frame rail and it is 5/16" SAE line and flares with my metric fittings on it and works great we even learned how to do bubble flares too for the fitting going into the tank it was fun  :yupyup: I got my clutch hardline built, installed and bled and again that is SAE line and flares with metric fittings...
(crappy pic)
my bro helped me build the air filter adapter for my intake and we got that put on  :yupyup:
that came out pretty good I think we did some more I just have to dig through some pics and I will post up some more...
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
and I went to hook up my power steering line from the 3.0l truck to the 2rz (it looked like the same fitting) and it is too damn thin so it needs some thick brass gaskets and it should work fine....
(notice the small gap on both sides)
www.choptechfab.com
CHECK THE BUILD
toyotanner
nice progress... yeah just throw some beefier brass washers in there and it should be good.
you could run the shorter bolt from the 3.0, so you don't possibly block the hole in the bolt and lose power steering pressure or cause the lines to burst.
Just a thought.
otherwise... GREAT JOB
TIMS89CRAWLER
Quote from: 85HOrunner on December 28, 2008, 06:46:52 PM
Just a thought.
ya I tried that but the 3.0l is the same exact bolt..... I think I will try the washers and see what happens since I have to have it ready for wheelin this weekend....
www.choptechfab.com
CHECK THE BUILD
you could possibly even cut the bolt down?
TIMS89CRAWLER
Quote from: 85HOrunner on December 28, 2008, 10:33:19 PM
thought about that too but the bolt has a flare machined into the end of it so it seals to the pump....I think the brass spacers is gonna be the best way to go but thanks for the suggestions
www.choptechfab.com
CHECK THE BUILD
oh I forgot about that.
yeah the washers should be fine.
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
well got most of the other little stuff done late night before our wheelin trip as usual and took it out on its test run..... it did very well but I found a nice sized list of things that will be done very soon.... It ran great all day and performed very well but did get pretty warm 1 time.... I think the truck needs a V6 radiator and a bigger fan.... there are a few things that still need finished up like the tranny tunnel and some interior stuff and the truck needs re-wired badly cause the PO chopped the hell out of the factory harness  :slap:
www.choptechfab.com
CHECK THE BUILD
toyotanner
86bobbedtoy
TIMS89CRAWLER
thanks guys... it felt great to finally get it out on the trail and test it out.... I have to go to go down south for a week to work but when I get back I have a few things I would like to get fixed up and go get it on some more rocks and find some damn snow already.... there are tonsmore pics floating around and lots of video of it wheelin if I could find everyone there taking pics and filming.... hopefully I get more soon
www.choptechfab.com
CHECK THE BUILD
yota_krawler
TIMS89CRAWLER
Quote from: Yota_Krawler on January 04, 2009, 11:43:27 PM
wow that thing has sure changed...
ya just a little bit....
I did a bunch more stuff to the truck today after the test run.... I noticed after wheeling slow for long periods of time that the truck would get a little warmer than I like it to be so I decided to do a few cooling system mods just to be safe.... I took out the 22re radiator and installed a 3.0l V6 radiator as well as installed a clutch fan and coolant reservoir......
the old weak radiator
the 22re radiator and the 3.0l v6 radiator
all torn apart....
then after a test fit of the new radiator I realized that the v6 radiator requires more room on the bottom of the mounts and the bottom of the radiator hit my front cross-member so I made these little spacers to move the radiator closer to the motor and it all fit great!
I also used this little medal elbow when I installed the heater hoses which must have been cracked or something cause the stupid thing was leaking on me when I took it wheelin...
and the system needs a good flushing anyway so I just installed a flushing T and it works great!
I ended up having plenty of room to run a clutch fan using a 2rz fan clutch assy. with the 3.0l v6 fan blades bolted to that.... I did have to use some small washers between the fan clutch and blades to keep the fan from hitting the pulleys on the motor but it works good now :yupyup:
I also changed the thermostat since I already had the coolant drained and all... figured I might as well
www.choptechfab.com
CHECK THE BUILD
Ramrod
looks good, you can stick the stock dipstick in there without any issues
TIMS89CRAWLER
Quote from: TEAM RAMROD on January 13, 2009, 08:53:45 PM
thanks man... I can use the front dipstick even with the rear sump pan?? that would be tits if so I dont have the stick so I havent tried yet....
www.choptechfab.com
CHECK THE BUILD
Wermz84
Awesome man.  Nice to see you got it running and out on the Trail.   perfect way to start the new year.
Was your winch cable hanging loose in those photos?
I like to Drive!
TIMS89CRAWLER
Quote from: Wermz84 on January 13, 2009, 10:49:06 PM
thanks bro it feels good to get it out and get some use out of it finally..... I still have some things to be done soon before I am all the way satisfied.... and ya the winch cable is hanging loose and that is currently being taken care of.... were gonna button some things up on it this week and hit up a decent rock garden this weekend and give it a little more in depth test.... I will shoot some pics of my progress through the week and the crawling this weekend...
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
 :booya: got the bed mounted up.... I like it much better with the bed on! just need to trim the fenders out so I dont mash them with the tires....
:yupyup:
www.choptechfab.com
CHECK THE BUILD
Ramrod
ya just stick it in there and fill the truck up with oil and make a new mark on the dipstick.  that is how mine is. i went right back in
TIMS89CRAWLER
Quote from: TEAM RAMROD on January 15, 2009, 08:23:38 AM
hell ya I will have to go swoop one up today and get that done... 1 less thing to have to worry about later.... thanks bro
www.choptechfab.com
CHECK THE BUILD
Mavericks
Yeah it looks much better with the bed on!  nice work!
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
