oregon 3rd gen build ****FOR SALE****
Started by TIMS89CRAWLER, November 26, 2007, 01:49:55 PM
TIMS89CRAWLER
the only thing I still need to figure out is if the alternator color coating is the same between the 3.0 and the 2rz so I can get that wired up..... if anyone knows the info would be much appreciated....
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TIMS89CRAWLER
ya I almost can too... I have to pull the motor out this weekend and pull all the egs crap off and get the exhaust manifold off as well as I have to replace the throw-out bearing and put the little clip in there.... then put my drivelines together and it should run and drive....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I also got the interior pretty much back together and got all the glass installed.... I am going to get the body work fixed up and fit the hood hopefully by the end of the week...then I need to get it all painted up and button the cage up and finish the plumbing and fill all the fluids and go break it.... I will post some pics and lists of stuff left till wheelin tomorrow....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
im trying but so far its killin me man .... this damn thing is taking way too long to get together.... I need a shop so I can be working on it now
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
got my first gen hood cut up and mounted today just need to get my hood pins attached to the tubing and thats out of the way... also got my steering shaft shortened up and installed so now I can steer the beast... I will get some pics up tomorrow of the misc things I have been working on... I will also get a list together of exactly whats left...
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
also been doing some research on a few little things that I still have to get squared away... I can across this for a good deal and wasnt sure if it will work on the toyota or not as I dont see why not...if anyone has any input on this lil guy it would be much appreciated...
Summit SUM-G3905
www.choptechfab.com
CHECK THE BUILD
Duffil
I just bolted that thing on mine. you'll need to make some adapter brake lines to convert to 3/16 inverted flare from the 10MMx1.0 that is on the toy.  Other than that, couldn't tell ya. My junk doesn't move right now.
COToy91
have it, adapted it, works great makes adjustments easy
TIMS89CRAWLER
 :thumbs: sweet thats good and cheap and my broke  :moon: can afford that and its all i need to make this junk stop... I see they offer a 10mm version of that too will that work?
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I made a list of whats left till its first snow wheelin trip comin up soon hopefully... looks long but really not too bad I dont think
-get brake proportioning valve installed
-install brake lines, calipers, new pads
-rear diff armor & axle gusset
-rear cage
-mount fuel tank
-mount batteries
-build battery cabels
-install tool box
-belly skid-plate
-motor/tranny skid-plate
-install new clutch master & slave cylender
-build line for clutch
-mount fuel line to frame
-install starter
-install maf sensor & air filter
-mini header & exhaust w/my flowmaster
-install radiator hoses
-install new guages & build panel for the cluster
-install rock lights
-install stereo
-build tranny tunnel
-install carpet kit
-paint cab & cage
-build new rear crossmember with receiver and shackle mounts (kind-of bumper)
-install power-steering box & hydro ram
-install  :turtle: steering knuckles & arp studs
-30 spline longs
obviously I could go wheelin without a lot of these things but I really wanna get this much done before I go out and beat it up...
www.choptechfab.com
CHECK THE BUILD
toyotanner
TIMS89CRAWLER
ya ya i know I have to work this week so that kinda limits what I can get done....I am laid off again next week so I have plenty of time to work on the truck... kinda kicks my  :moon: on the money situation but I can cope with that and get this thing done.... I am gonna go snap some pics here in a few...
www.choptechfab.com
CHECK THE BUILD
KYOTA
Quote from: TIMS89CRAWLER on October 12, 2008, 07:36:03 PM
Summit SUM-G3905
I have the same Summit PV on my truck plumbed into an FJ80 MC. Using the following adapters, you wont have to cut and re-flare any lines unless you want to mount it somewhere else.
you'll need (Summit part #'s)
EAR-592032ERL    (comes with 2 fittings)
EAR-989538ERL    (comes with 2 fittings)
EAR-916103ERL -  ( only 1 fitting- YOU NEED 2)
the brass fittings included with the PV from Summit arent used. can get a pic later if you want
TIMS89CRAWLER
Quote from: KYOTA on October 14, 2008, 02:08:43 PM
hell ya man thanks for the numbers... I was just wondering if the pressure range was right for the toyota thats hella cool it will work much cheaper than the fror one....thanks again bro
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
oops I messed up by re-organizing my photobucket and it moved all my pics around and really screwed the build up.... woops I may just start another we will see!
www.choptechfab.com
CHECK THE BUILD
GJToyotabug
NO!! ive been following this too long you have to finish!
TIMS89CRAWLER
ya I am gonna keep it going and the pics that are moved ohh well theyre just gone... I have some more updates coming soon just gotta get the pics posted up! soon
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I havent got much done on this recently due to the fact I have no money for my header and exhaust or driveshaft metal.... but today I figured I would try and knock off some of the little stuff so I tore into the truck wiring harness today to re-route the power leads to the bed where the battery will be mounted and fix some of the corroded wires I have came across... I chased the 2 front looms of wire back into the cab and removed all the wires that either dont work or the ones that are not being used...
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
and I got the rear axle all put back together for now I still need to get my inspection cap/fill hole installed....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
and I also started cleaning up the front end where I removed the core support and getting that looking half way decent... got 1 side done minus the seam sealer I still need to get on there....
www.choptechfab.com
CHECK THE BUILD
Burl Earl
Quote from: 1985efiyota
next thing you know marlin will be makin a moon crawler for nasa
gotta be Burl to be called Earl
83 Toyota P/U Webber carb. Sky high-steer, front drop hanger & rear  hock hoop. Marlin brake lines, IFS mount, rear spring mount & shackles. Trail-Gear front 12" shock hoop. Rancho RS900X 12" Adj shocks. All-Pro 6" front springs & Triple XXX cross member w/ e-brake. 63" chevy springs rear w/ 3" blocks. Removable mud flaps.
Thread, Build and Pics Click Here
TIMS89CRAWLER
Quote from: Burl Earl on November 26, 2008, 12:54:22 AM
got any more pics of the cage? :popcorn:
you will just have to look a few pages back in the build there should be a bunch of pics of the cage being built.... thats if all the pics didnt get moved in my photobucket and not show up on the board anymore... I will have to repost some when I get time....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
ok well the truck fires but I think I have a fuel delivery issue as it does not want to stay running but there is good spark.... the fuel tank/pump I am using in the truck is the origional that came in the truck and has not been used in many years... I replaced the fuel filter and checked power to the pump and all is good... earlier today the truck fired up a few times and ran for a few seconds then died but now I cant even get it to do that...I am lost and out of beer if anyone has any ideas or much 2rz/3rz knowledge I would appreciate any ideas or things to check.... thanks guys
www.choptechfab.com
CHECK THE BUILD
sounds like your tank might be gummed up and plugging your pump maybe?
TIMS89CRAWLER
Quote from: 85HOrunner on December 21, 2008, 10:01:40 PM
well from looking down inside the tank from the fill spout the tank appears to be clean inside... I have not yet pulled the pump out of the tank to check the screen yet as I want to run a fuel pressure test tonight after work and see what that shows....I still have a few other things to get done to get it on the trail anyway so I will start working on some other things to keep me busy till I get some ideas on the motor issues....
www.choptechfab.com
CHECK THE BUILD
greenjacob
you gett that thing done you still needing any parts
1986 4runner 93 22re 5.29s locked f/r duals twin sticks 39.5s
