oregon 3rd gen build ****FOR SALE****
Started by TIMS89CRAWLER, November 26, 2007, 01:49:55 PM
TIMS89CRAWLER
 :woohoo: finally got my pics here :woohoo: here is a pic of the whole truck lifted  :biggthumpup:
front shot
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TIMS89CRAWLER
then here is the rear spring hangers i built   :yupyup:
then the rear shackle hanger i got from skys mfg. (just tacked up till i flex test it out)
another angle of the custom hangers ( crappy pic )
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I decided to only move the hanger up 4 1/8" rather than the 5 that marlin said to go.... my shackle angle just didnt look right so I tacked it up and will try it this way and see what happens ???
and another view of shackle angle and mounting
and a full rear shot  :yupyup:
other side hanger tacked up
the rear mounted up finally
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
here are a few other pics of the suspension  :yupyup:
then here is my bellhousing from the w59 tacoma trans that will be getting bolted up to my w-56 to allow me to bolt my 2rz up....  :yupyup:
and my crawl box that I need to get some x-tra  :twocents: and order up the mc07-r10 adapter!!
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
then i have been chopping up my old drivelines to build some schedule 40 drivelines as rick did on tuki  :yupyup: :yupyup:
then my 1/2" steel that i am building my t-case x-memeber from :beerchug:
the stock 2rz motor mounts that came off so I can build my leaf spring bushing motor mounts....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
Quote from: ImaHoToy87 on April 07, 2008, 05:39:58 PM
leaf spring bushing mounts eh?
yes I am building some spring eye bushing motor mounts (cause I am sick of breaking weak stock motor mounts) as well as my t-case x-member will ride on spring eye bushings as well cause I havent been hearing any good reviews about the front range x-member... I have been hearing from a few different people that they are cracking... so I figured I will just build one up for myself and not have to worry about any cracks... mine will be made of 1/2" plate steel for the main ring which I would think should be plenty beefy... I will be cutting that out and working on getting it all drilled and tacked together for a test fit...I will be mounting the motor and trans this next weekend just to start getting the wiring together since I now have some schematics to work with...
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I got a few more things done to the truck this weekend.... I traded a buddy my 81 front axle from my first gen str8 across for a 85 front end and I got it all torn down for a much needed rebuild (not in as bad of shape as my old one though) and all my parts cleaned and inspected and ready for assembly... I just need to get my order in to marlin for my gusset, knuckle ball kit, diff armor, knuckle rebuild, and some heavy duty inner seals so she will be new as I already have new wheel bearings....I also got one side of my bed welded back together finally..... I rounded up some free parts from a truck my buddy is parting out such as my new seats, brake booster & master cyl., and some steering shaft parts to fab mine up.... FREE parts kick  :moon:  :yupyup: I will get some pics up on my lunch break..... :biggthumpup:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I got a few more things done last night.... I got my steering shaft built since 2 different ones came in my truck and neither of them fit... so I just took the 2 and built 1 that does fit... I also cut out the front cross-member out and replaced it with a piece of 2"x3"x .120 and welded that in place since the stock one was bent to high hell....I will get some pics when I get some spare time....
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
 :biggthumpup: here are some pics finally  :woohoo:
front dovetail
rear bobbed bed and a partial comp cut... i will finish that tonight
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
more pics  :yupyup:  :beer: :beer: :beer:
the old front crossmember
and the new
here is the steering shaft I built
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
I traded my front axle out of my 81 for this 85 straight across... I tore it down for a rebuild I am just waiting on my order from Marlin & Trail gear to get it all put back together.... I got my knuckle ball kit and HD inner seals from Marlin & from trail gear I got my diff armor, axle gusset, knuckle rebuild & spindle nut kit... I already have my new wheel bearing kit waiting to get put back together  :woohoo:
and my trusty Lincoln locker for the front  :yupyup:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
Oh ya and I also got my forward shift t-case to tear down for my crawl box.... now I have my w56 > forward shift crawl box > top shift 2nd crawl box > top shift rear case.... I am just gonna run the 3 cases and 4.10 gears in the diffs I should have plenty low gears running the 40's
www.choptechfab.com
CHECK THE BUILD
3 cases!
double clocking of 20*? single clocking of 10*? or no clocking?
TIMS89CRAWLER
 :dunno: i havent decided that yet  :dunno: prolly go with 20* just so its that much less I will have to lift the drivetrain for my flatbelly.... we will see what the boysat marlin thing about running 2 10* adapters....
www.choptechfab.com
CHECK THE BUILD
Quote from: timsyota on April 18, 2008, 09:48:55 AM
its been done and can be. :thumbs: on this forum somewhere.
i say do it....
you just need custom dogleg short shifters.
TIMS89CRAWLER
 :yupyup: ya thats for sure on the dogleg shifter.... I prolly will go with both adapters clocked prolly save me some floor choppin too!! :yupyup:
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
youll have to cut the floor with both the adapters i bet for the back t case.....unless u leave that  :gay: BL on :nonono:
TIMS89CRAWLER
 :thumbdown:body lift is coming off cause its :stopit: I will prolly run a skys 1" though just so I get new bolts and bushings  :yupyup:
www.choptechfab.com
CHECK THE BUILD
Ramrod
anything over 10* rotation doesnt really get you anything since then the main part of the tcase will be your lowest point
TIMS89CRAWLER
 :yupyup: ya thats kinda what I was thinking the case would be... I will prolly run 1 clocked adapter and one regular one come to think of that great point ramrod just made!! thanks man  :beerchug:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
oh ya I also got the bed bob finished up last night and got one of my bedsides dove-tailed it looks pretty cool but I need to get the other side done tonight.... I will try to get some pics of the bed up at lunch  :yupyup:
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
here is a pic of some weekend progress
comp cut and bobbed bed
dovetailed bed
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
also got started working on my flatbelly t-case cross member this is the center section i made from 1/2" plate
www.choptechfab.com
CHECK THE BUILD
DTB
that plate is pretty sweet...good work
TIMS89CRAWLER
also worked on building my diff armor for my front axle ... most of the way done I just need to add the triangle plate in and cut the hole out for the fill plug....
and here you can see how i shaved the drain plug!!
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
TIMS89CRAWLER
ya the plate seems to fit pretty good I had to do some grinding to make the speedo cable fit... but I think it will all work out
couple more pics of it
www.choptechfab.com
CHECK THE BUILD
sick progress.
that flatbelly mount is floppering thick!!!!!!!!
oh thats guna be one sick truck on the road and trail.
TIMS89CRAWLER
Quote from: HO on April 21, 2008, 11:57:01 AM
sick progress.
the flatbelly mount im building will be just like 4rnrrick build on his tuki suzuki project....I still have some work to do on it though
www.choptechfab.com
CHECK THE BUILD
