Southeast Missouri Feakin PUNISHER Build! 20R/22R Hybrid Engine!!
Started by DeMented Toys, November 14, 2007, 09:53:25 AM
DTB
Gittinit
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
DeMented Toys
Jeff DeMent
-DeMented Toys-
DTB
DeMented Toys
The truck is down at the ranch...  I'm at my school apartment...  Then there is that Cancun trip tomorrow...  So I won't be be able to go home to work on the Yotar until next weekend!  But then it's on...  well, if we don't get all that snow...
Jeff DeMent
-DeMented Toys-
jprinehart84
DeMented Toys
Quote from: jprinehart84 on December 16, 2007, 06:07:00 PM
I like your thread, Keep it goin
Thanks!  I'll take some more pics this weekend!  Should finally be swapping on the Chevy rears and such.   :eyebrow:
Here is a pic of the start of the chevy spring swap.
Jeff DeMent
-DeMented Toys-
Gittinit
Quote from: snakeeyes on December 19, 2007, 06:07:49 PM
Thanks!  I'll take some more pics this weekend!  Should finally be swapping on the Chevy rears and such.  then heading to Flat Nasty for some wheeling :eyebrow:
Fixed it for ya! :biggthumpup:
my favorite places:
yota_krawler
DTB
Gittinit
He is swapping in the 63 chevys and has run into some minor dificultys. NBD!  8)
my favorite places:
Doof
minor difficulties? that doesnt sound to good. when i say that :pokinit: hit the fan twice over
DeMented Toys
Minor...   :hammerhead:  difficulties...
I got the driveshaft thing mostly figured out.  And today had a couple top spring plates made for the u-bolt flip and got the springs bolted to the axle.  Tomorrow I'm going to attach the driveshaft and get it where it needs to be then mark the spring hangers wherever that puts them and weld them on.  Then figure out this shackle angle thing for running double shackles.  If not I'll just have the machine shop make me a couple of new rear shackle hangers and cut the stock one off and use an 8" chevy drop shackle on there.  But they won't be open until Wednesday and I'm running out of time before Nasty.  If I had some metal I could make some myself...
So the to do list...
1.  Finish the chevy spring swap
2.  Put the bed back on
3.  Fix the wires the packrat chewed into so my dash lights and guages work
4.  Clean out the heater core or replace it
5.  Put the dash back together
6.  Bolt the seats in
7.  Duct tape down the shifter boot  :)
Go to FLAT NASTY !!  WOO HOOOoooo
Jeff DeMent
-DeMented Toys-
DTB
DeMented Toys
Quote from: DirToyBoy on December 24, 2007, 08:37:45 PM
I have a good heater core if you need it
I think I have one over in my parts field...  If not I may need to come up with one for a 94.
Jeff DeMent
-DeMented Toys-
Gittinit
Quote from: snakeeyes on December 24, 2007, 08:35:13 PM
You can cut the origonal shackle hangers off with a sawzall and re use them. There is still enough material to reweld them to the frame after cutting them loose. This is what I did then I used some 3/8 flat stock from the local steel yard, and drilled the different sized holes in each end. I think the toy shackle hanger end was a 3/4 bolt, and the chevy either was 9/16, or 5/8....I'm thinking it was 9/16. I kept my rear shackles short and didn't need a crossbar between them.
I am partial to the single shackle setup becouse of what I have read. The only set of double shackles I have ever seen used just didn't help as much as I would have thought they should. :twocents:
my favorite places:
DeMented Toys
I guess either way the shackle angle need to be around 45 degrees?
Jeff DeMent
-DeMented Toys-
Gittinit
After they settle or before? I think that might be close to what I got in the rear after everything settled in.
my favorite places:
DeMented Toys
 :willynilly:  Got the chevy spring swap finished, swapped an 89 IFS rear under there, and got my lower shock mounts welded ontop of the axle housing.  I also and added a new rear crossmember.  I plated the insides of the frame right above the rear bumpstop location so I can weld in a new higher shock mount crossmember thing tomorrow.  For now I put the old shocks back on.
The price of metal is crazy high!  I just spent $80 on 3 - 42" pieces of square tubing!!  Ouch! :o
Even without the bed on it (for weight) I can tell a huge difference in ride quality!  It is much smoother, and flexes like a champ.
Jeff DeMent
-DeMented Toys-
DeMented Toys
Didn't have time for poser shots...
I did however have time to get a wild boar roasting for tomorrow.   :eyebrow:
So in the morning I will put my rear brake lines on and try and figure out how everything (springs, adjuster, crap) goes on under the rear drums  :crossed: and fab and weld in my shock mount.  Then I can put the bed back on and start putting the interior back together...
Jeff DeMent
-DeMented Toys-
DTB
Quote from: snakeeyes on December 27, 2007, 07:30:33 PM
hurry! :whip:
DeMented Toys
Anyone have a picture of what springs and things go where under the rear brake drums of an 89 rear?
Jeff DeMent
-DeMented Toys-
DTB
Quote from: snakeeyes on December 27, 2007, 07:36:42 PM
the springs INSIDE the drums? dont you have a factory service manual? :bat:
DeMented Toys
Jeff DeMent
-DeMented Toys-
DeMented Toys
Pics of my spring plate for the u-bolt flip, and the double shackle setup that is NOT finished yet!
Jeff DeMent
-DeMented Toys-
DeMented Toys
Quote from: DirToyBoy on December 27, 2007, 07:41:56 PM
Uh..  Yeah, right, good call!  :)  The welding fumes must be getting to me...
Jeff DeMent
-DeMented Toys-
DTB
DTB
DeMented Toys
Jeff DeMent
-DeMented Toys-
DeMented Toys
Here is my double shackle setup with a bumpstop above it.  I'm going to weld a bracket to the frame between the top shackle so I can pin it to the frame for highway driving, ect., even though it would probably be fine the way it is.
Jeff DeMent
-DeMented Toys-
