looks nice..did u make the steering box brace yourself?also are you rebuilding the axle?keep it up!!
from your axleswap12r pic it almost looks like the box needs to be farther foreward, but then again it is at an angle and the weight of the truck isnt on the axle
Could be... I think it is in a good spot. I could have gone about another inch forward.
Here is a close up in case anyone doesn't understand what I did. I found several articles/threads about drilling these shear pins out to lengthen the shaft, but no actual pictures... So here is a closer pic.
If you do, let me know!
quite a few people have that issue. yank the wedge and you'll be OK.
wat tires and rim size are you using
I bolted the V6 calipers on the vented rotors... When I put the wheel on however, I ended up having to grind down the caliper so it wouldn't be touching the back of the wheel. I took quite a bit of material off the caliper with a 40 grit flapper disk.
YOU NEED 1.5in SPACERS!
Yeah, I need quite a few things but I'm on a budget here... So I do what I can with what I've got.
Started by kneedownnate Engine
Started by dune_it86 Toyota Pickup/4Runner Tech 1979-95
Started by lilbuddy Rigs For Sale
Started by DeMented Toys Parts For Sale
Started by Trail-runner Parts For Sale
