Southeast Missouri Feakin PUNISHER Build! 20R/22R Hybrid Engine!!
Started by DeMented Toys, November 14, 2007, 09:53:25 AM
DeMented Toys
Here is the cab being stripped down and the wiring harness being labeled and pulled out.
Jeff DeMent
-DeMented Toys-
DeMented Toys
Here is it with the bed off, almost ready to lift off the damaged cab.
Jeff DeMent
-DeMented Toys-
DeMented Toys
Lifting off the damaged cab...  By myself with a engine hoist.   :dunno:
Jeff DeMent
-DeMented Toys-
DeMented Toys
Damaged cab off finally!  Ready to lift on the 94 2wd cab!  Get excited.
Jeff DeMent
-DeMented Toys-
DeMented Toys
#34
94 cab in place!
Jeff DeMent
-DeMented Toys-
DeMented Toys
Taking the time to label every wire and connection was definately worth it!  The wire swap went alot easier than I thought it would.
This is a picture of the interior being put back together...
Jeff DeMent
-DeMented Toys-
DeMented Toys
#36
There are still some wiring issues to get worked out...  Guage lights aren't working, need to wire up the dome light and that sort of thing.  It did pass inspection though, and as soon as I can find a bed, or build one...   :driving:
Jeff DeMent
-DeMented Toys-
Doof
nice steering wheel
sounds like one hell of a sketch drive after picking up the truck and the drive home
nice pics
DeMented Toys
Quote from: silly58willy on November 14, 2007, 07:58:43 PM
nice steering wheel
nice pics
And no radio  !!   :yikes:
Jeff DeMent
-DeMented Toys-
Doof
haha that sucks....i blew my radio fuse the other day and rolled around town and to college without with. it sucked, the silence sucked
i cant imagine driving that far with no sound
DeMented Toys
Jeff DeMent
-DeMented Toys-
John Doe
Make sure you transplant the hood paint onto the new cab. Great work!
DeMented Toys
Quote from: John Doe on November 16, 2007, 09:15:19 PM
Wouldn't be complete without it!!
Jeff DeMent
-DeMented Toys-
DeMented Toys
Today I was messing around in my Toyota parts field and decided to go ahead and pull the 2wd shortbed off the truck that donated the cab (94 2wd).  I thought the bed was trashed, but after cleaning out a bed load of trash and old parts, it's really in great shape!  Just a few minor dents...  Anyway...  i set the bed in place to see what I had.  The problem would be that the frame is a longbed and the bed is a shortbed.  With the other cab and bed on there, the rear quarter panel section of the bed was just cut off on both sides.  I never had any clearence issues like that, and most people didn't notice that the rear wheels didn't line up with the fenderwells -->  The rear wheels center around 42" from the back of the cab, and the fenderwells center about 32" from the back of the cab.  So the rear tires are about 10" behind center of the openings.
My question is...  Any suggestions?  I was just going to cut the lower rear sections of the bed sided off, like before, but wonder if there is a better solution...  Or a cooler way cutting it, or doing it?
I'm getting ready to swap chevy rears on too, and couldn't finnd any info on this but could I just move the front hangers farther forward to relocate the axle forward a few inches?  Here are some picks of the way it sits now.
Jeff DeMent
-DeMented Toys-
Big Pap Dog
Bob the bed....then use the left over piece to lengthen the bed near the cab to center the wheelwell :gap: (or) find a long bed? Good luck man, in all seriousness, the truck is coming together well!
DeMented Toys
Yeah I may just try and find a long bed.  Custom is always cooler though.  May just build one too, just don't have time right now and want to get a bed on ASAP!
"I'm getting ready to swap chevy rears on too, and couldn't finnd any info on this but could I just move the front hangers farther forward to relocate the axle forward a few inches?"
Jeff DeMent
-DeMented Toys-
DeMented Toys
I haven't been able to find any info about this being done...  But I think I can just move the front spring hangers farther forward when I mount the chevy springs.  That would move the whole axle forward.  Anyone know if that would work?
Jeff DeMent
-DeMented Toys-
Gittinit
find center of the wheel whells then locate your axle under the truck. Tack hangers where they need to be check everything for square, check pinion angle, rotate perches if nescisarry, and weld it all up slolid. If I make it sound easy thats couse it is, let me know if I can help.
Happy turkey day, turkey!
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
DeMented Toys
That's what I figured on doing.  I didn't think it would matter how far forward the front hanger was moved, as long as the axle ends up where I need it.  Good to see you back!!!
Jeff DeMent
-DeMented Toys-
Gittinit
my favorite places:
DeMented Toys
I also need to do the firewall mod to fix the front clearance issues.  I moved the cab back about 1.5" when I mounted it, so that helped some too.  Think I will almost center the rear axle with the bed wheelwell or maybe just split the diference and cut and bob the bed...  If I didn't have these term papers to finish up I would be heading down there to get started on it!   :hammerhead:
Jeff DeMent
-DeMented Toys-
Gittinit
Some crossover steering and rears up front would fix that clearance problem and give ya better feel and controll on and off road. After rears up front and crossover on my truck all I needed was to pound the seam flat at the firewall and I have not rubbed there since, even with relatively flat springs, low stance and fat 36" tires. I rember rubbing with 31s before. My tires do rub ,but they rub where the inner fender slopes down for the battery tray.
As far as the rear moving the axle foward means gas tank, and driveshaft issues. Modding the bed is the best solution if your happy with your wheelbase. A shorter wheelbase will give you a tighter turning radious, and better breakover angles, but a longer wheelbase means better on road ride, and a less tippy feeling on steep climbs.
my favorite places:
DeMented Toys
Well, I got the bed bolted down and cut out the bed fenderwells for clearance.
Here is a poser pic.  I was trying to see where the front was binding up at, but need to find a higher bank to back up on I guess...
These are crappy cell phone pics...
Jeff DeMent
-DeMented Toys-
DeMented Toys
Jeff DeMent
-DeMented Toys-
DeMented Toys
Woo-HOOOoo!  Finals are over!  This was my last undergrad semester!!  Now I have time to get busy on the Yotar!!!   :driving:
I need to finish the front bumper...  I was thinking about putting a new front spring hanger on there too.  I have one from Marlin that I used to SAS a frame, but never did anything with the frame so I may cut it off and put it under the front of this truck.
Any thoughts on that idea?
Jeff DeMent
-DeMented Toys-
skipnrocks
Quote from: snakeeyes on December 12, 2007, 04:03:52 PM
Cool congrats on finishing up your undergrad, thats pretty exciting,  are you going to get more schooling?
WILLYNILLY
DeMented Toys
Quote from: skipnrocks on December 12, 2007, 04:05:30 PM
I still have a 400 hour internship to do, then I may apply for grad school for next fall...
But first, I have a Toyota to build!!!
Jeff DeMent
-DeMented Toys-
Gittinit
my favorite places:
Trail-runner
The trucks coming along pretty good :thumbs:  I stoped by the shop on Rt. K and talked to the guys there.  They said they havn't seen you in a while.  Now I know why you've been busy.  I just started working on my 4runner again.  I should have it ready this coming spring.
DeMented Toys
Jeff DeMent
-DeMented Toys-
