The Tuki Suzuki - Toyota drivetrain, Samurai body
Started by 4RnrRick, October 14, 2007, 09:24:42 PM
skipnrocks
You could recess some cup holders into the larger one next to the seat!!  LOL
WILLYNILLY
4RnrRick
Started cutting up the rear wheel well last night and mocking up a 14" coilover....
KDXSR5
Whats the plan on mounting the reservoir deal? Looks nice! :thumbs:
MiniSimp
Do you have a shot from the top or back or front showing how far it sticks in?
Are you sick of answering questions yet, Rick?
:talkingn: :talkingn: :talkingn:
4RnrRick
Quote from: KDXSR5 on April 10, 2008, 08:03:23 AM
Yes....  :thumbs:
Quote from: MiniSimp on April 10, 2008, 08:04:08 AM
No, I still have to test flex it the other direction because I'm not sure if this is the final location. heck I've already moved the top mount 3 times and the bottom mount 4 times.
Quote from: DirToyBoy on April 10, 2008, 08:10:29 AM
no.
MiniSimp
He is going to get a 90* fitting and run it up through the fender and mount it on the roll cage. :greengrin: :dunno:
TIMS89CRAWLER
 :biggthumpup: damn im really liking the rear suspension so far man... this thing is gonna go anywhere  :yupyup:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
skipnrocks
That is a good Idea with the angles shock to keep it out of the way of the tire!!! I know there is things to concider about effectiveness of shocks at particular angles.  Did you use something to determine an angle that works well?  Or just tried to get it out of the way?  I ask because I have been debaiting doing that to my rig because the tires want to rub on the shocks at full flex.
WILLYNILLY
4RnrRick
Coilovers are fully tunable, so I'm just trying to get it out of the way for the tire for now without using up too much interior space. I can tune them to suit later.
twistedtoy92
skipnrocks
WILLYNILLY
4RnrRick
yes, a higher spring rate and more dampening in compression and rebound as opposed to it being mounted vertical.
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
4RnrRick
Well there was no way for me to get the coilover over in there without notching the frame rail - So today, I pulled the cage out and the body off AGAIN and worked over the frame rails. And now I'm in the process of extending the frame rails slighly for teh rear winch and dual 2" recievers which in the future will be used for a spare tire mount and/or a removable storage bin.
KDXSR5
This is so awesome! So you are doing coilovers and not air shocks? Weren't air shocks an option at one point? Why no air shocks?
The idea of removable tire carrier and storage bin with dual recievers is awesome. I can't wait until this is done!
SolidAxle
#888
Are you still using the 110v for most everything.  :flamer: What model do you have?
I remember you briefly talking about it on the quasi build, and how you use .023" wire for EVERYTHING. With all the talk about needing a 220v it's amazing to see what can be accomplished with a 110.
Awsome build, your fab work is incredable.
4RnrRick
Got some more done on the rear crossmember / winch mount.
4RnrRick
Quote from: 4RnrRick on November 24, 2007, 07:40:31 PM
People always seem to me ask me what welder I use, so I figured I would just tell you now - its just the base model 110 Volt Lincoln with a Mig bottle kit. I use 0.023 solid wire and 75/25 gas mix. seems to work good for me......
SolidAxle
 :doh: sorry Rick. I try to find most stuff by searching for it.
4RnrRick
I didn't like the look of the rear (too "blah" for me), so I tack welded on some scrap steel as a edge template and broke out the cutting torch. Then I recess mounted (2) Napa Tractor lights beside the winch for my backup lights.
Duffil
:headscratch:
wondering how you mounted those 50-620W3 lights...maybe inside the tube you have tacked on, just on the backside?
4RnrRick
Nothing special... just a welded on tab.
Jud
"bout tree fiddy"
Duffil
Quote from: 4RnrRick on April 14, 2008, 10:28:45 PM
oh...yeah I guess that would be the easy way, huh? :gap:
TIMS89CRAWLER
 :yupyup: I like the rear lights that looks hella sick  :yupyup:
www.choptechfab.com
CHECK THE BUILD
Quote from: timsyota on April 15, 2008, 08:09:14 AM
Not worried about those gettin smashed out rick?
