how far forward from stock is the axle right now?
let me know how those axles work...i made a couple today and one yesterday, they haven't been trail tested yet, but i just barely finished them. they've seen the block. i'm still happy that i can ghost ride my truck while barely walking
i just watched the video over on rockfrogs that was great.its gonna be at the perfect height when it settles with the 36s. you have the 1.5" spacers in the front for that width, but what else? backspacing on those rims im assuming?
Badass! Looks good man. Feels good to finally put it in 4wd and go! Beautiful stance too. My 4runner ended up a little lower than I had hoped after my springs settled, so i have to modify a few things. im going to swap out my front springs and shackles ad add a 1 inch block to my chevys, hoping that will make it look a little closer to your stance. Do you have a body lift at all? Congratulations!
nice Volcom...good to see everything's coming together. we did our doubler ghost ride this week, it's nice to be able to start out in 5th gear in LOW LOW and wrap it out in 2 seconds while still only going about 3mph. Good luck at moab bro
are you going to put a rear bumper on there volcom?
I haven't gotten to drive it much so I didn't really try starting in 5th gear double low. I'm pretty sure I'll be trying it in Moab. The group I'm going with takes a ton of pictures and video so I should have some nice pictures of the trip!
Hey you got any picturs of your rear shocks bolted up yet?
i think i caught a picture of this thing flexin in Moab over on rockfrogs, but how did the trip go? truck work flawlessly?
I'm sure you'll have time to play around, but if you need the muscle, you know 1st gear with that setup is the only way to get to 223:1 on the trail the other gear ratio's should be higher, so crawl low in first since your first gear ration is 3.93...just my opinion.
What are you impressions on the aussie lockers? Are you happy with that setup? Im mainly curious about the rear and driving around without the front hubs engaged. I might get one just for the rear just curious what you think
Started by vatoyrunner Project Research and Build-Ups
Started by 19904runner Toyota Pickup/4Runner Tech 1979-95
Started by 4xtoy Project Research and Build-Ups
Started by Oddmar Project Research and Build-Ups
Started by pyrosnow911 Toyota Pickup/4Runner Tech 1979-95
