0 Members and 6 Guests are viewing this topic.
... these tires didnt budge at all till they were under 8 new, now they are nice and soft and flexible.
Yea I think hes runnin them, definatly a good alternative to all out beadlocks! I have heard really good things about them!
..... the only "street legal" beadlocks........
I call bs on that, if you google dot aproved beadlocks more than one company will come up! But they are nice to have!
Volcom, maybe your slightly "used" tires are already broken in and don't need to be aired down as much.
Hey man, i know this is from your post along time ago, but in this pic you say the egr valve. Last night doing my install i noticed i had a leak also and thought that this big plate right off the back of the head was the egr valve. When i pulled the bolts out antifreeze came gushing out. Do you or anyone else know what the hell this plate with the bolts is and if i screwed anything up by breaking the seal?? Sorry to highjack your thread but it's your picture i have the ? on. Thanks
actually, that thing transfers exhaust from the exhaust side of the engine to the EGR valve, and coolant is in the head behind it. it is called the exhaust cooler or some . it's main purpose is to lower the temp of exhaust before it is redirected into the intake.
what part of Colorado springs do you live in?
is your rear axle moved back? man that thing will look sick on deez
question.... cudnt you stretch the bed part of the 4runner body.... in front of the wheel well. and then bob the back part an equal amount.? have that tire back in the correct visual spot..and have the top still fit?thatd look
Started by vatoyrunner Project Research and Build-Ups
Started by 19904runner Toyota Pickup/4Runner Tech 1979-95
Started by 4xtoy Project Research and Build-Ups
Started by Oddmar Project Research and Build-Ups
Started by pyrosnow911 Toyota Pickup/4Runner Tech 1979-95
