Toybrota's 22R build
Quote from: :)bestgen4runner on March 22, 2019, 08:44:05 AM
.... Plan is for exo in the future. :thumbs:  ....
OH NO..... NOT AN EXO!!!  Please don't do it!  :willynilly:
Gnarls. :yikes:
Toybrota
Quote from: Gnarly4X on March 22, 2019, 12:06:38 PM
Gnarls. :yikes:
How come you don't like em? I could understand either way, definitely a look that's different. Not sure I would. I Appreciate the functionality and safety of an exo though. Other truck might get a partial one.
I think the half inner, half outer cages look the best. Hybrid exo...
:)bestgen4runner
I plan to copy this almost exact.
I am 1/5th of Perfect Fit
#425
Quote from: emsvitil on March 22, 2019, 03:58:15 PM
You can fix the stock temp gauge...
https://board.marlincrawler.com/index.php?topic=47792.msg599053#msg599053
google 'Toyota temp gauge mod'
emsvitil...
Are you serious!!  Holy hot  ca-ca!!  It would take me 3 hours just to figure out what the hell that guy said and how to apply it!!
When it's all "fixed" it is STILL a 30 degree sweep non-readable temperature number!!
I'll rather buy an Autometer gauge and install it!!
That's just me.
Now...it is really cool that someone figured out some incredible piece of electronic modification, and went to all the trouble to post it.
#426
Quote from: Toybrota on March 22, 2019, 12:10:55 PM
Well... here's a 1/2 dozen reasons that pop out of my mind based upon about 20 years of wheeling.
1.   Adding 300 to 400 lbs. to a rock crawler requires more power/torque to move - just adding to potential failures, raises center of gravity making rollovers more likely.
2.   There is no such thing as a "damage proof" cage - exo or otherwise - it will get damaged.
3.   Exo cages add unnecessary size to the vehicle - it gets hung up on obstacles 3 times more often.
4.   Exo cages limit access to exterior body parts and interior ingress and egress.
5.   Exo cages are very expensive and time consuming to fabricate - cost/performance ratio makes it a waste.
6.   THEY ARE UGLY!!!!!!!!
I am an absolute believer, and highly recommend an interior roll cage be installed in any off-road vehicle, especially in a Toy truck.  I would NOT go rock crawling again without a properly designed roll cage installed in my vehicle.
cbeers
Quote from: :)bestgen4runner on March 22, 2019, 12:35:16 PM
but no oem bar still....i don't get that?
seatbelts maybe?
CB
Lewis Hein
All I could find was information for 93 and up, nothing at all for second gens.
Quote from: Lewis Hein on March 23, 2019, 04:34:28 PM
Same principal.     Might have to vary the resistor values.
http://www.toyotasurf.asn.au/techsite/tempgauge.htm
Lewis Hein
Right, but without a lot of potentially destructive testing I can't know if I have to vary the resistance values or not
Quote from: Lewis Hein on March 24, 2019, 08:54:23 AM
At the end of the day of modifying that gauge you just polished a turd.  It's electic.  There is no temperature reading.
I have never questioned the water temp reading on my AutoMeter Sport Comp mechanical 270 degree sweep gauge.
https://www.summitracing.com/parts/atm-3432?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-autometer&gclid=EAIaIQobChMIj6mD0JOd4QIVsxx9Ch3RcwM3EAQYASABEgI9rvD_BwE
Quote from: Gnarly4X on March 25, 2019, 04:09:36 AM
Make your own temp marks..............
Toybrota
Purchased a new fan clutch. Aisin, OEM of course.
This is the model FCT-001
Figured I'd go ahead and eliminate another possible variable. Fan wasn't whiring at 230°.
Radiator comes this week. Intake gasket should also be here this week. Old gasket should come off easily, wasn't on there that long.
Debating getting a 180° thermostat. But this radiator is already overkill (3 core aluminum) for a stock application. May do it anyways, I'm heading to Nevada later this summer for some abandoned mine exploration. It needs to be able to handle 100°+ off road. An electrical fan is DEFINITELY a consideration.
:)bestgen4runner
Hold off on the thermostat.
Quote from: emsvitil on March 25, 2019, 01:06:39 PM
      :haha: "Make your own temp marks...".   :rofl:
Gnarls.  :gap:
:)bestgen4runner
Quote from: Gnarly4X on March 25, 2019, 02:03:58 PM
Gnarls.  :gap:
Ok
That was funny.
Mommy they're making fun of me.
:rivers:
cbeers
holy crap that fan clutch was cheap!! nice find!
CB
Toybrota
Quote from: cbeers on March 25, 2019, 03:11:33 PM
CB
Thanks! I usually find the Aisin number and then I shop around.
Toybrota
New fan clutch came, ordered yesterday and here today. How nice.
Got the old gasket off, still have to clean the rest of the gasket surfaces. New razor blade should do that well. Acetone always helps clean surfaces up too!
Rad comes tomorrow, I'm praying I don't need an electric fan to run it. Checked measurements, seems good so far. Hoping to have it running this week. After letting the coolant sit a bucket, I noticed some crap had settled to the bottom. I'll just flush the entire system.
You can change the fluid in the aisin fan clutches................
Toybrota
Quote from: emsvitil on March 26, 2019, 07:52:20 PM
Not worth the hassle. I'd rather pay $40 for a new one. Also, are you sure? I've heard you can on other models, not these. Nothing is mentioned about servicing it in the FSM.
Toybrota
Side question. Does everyone install their intake gaskets dry? Or with sealant?
I like to use that copper spray adhesive/sealant on something like an intake.  It has worked good for me.
Quote from: Toybrota on March 26, 2019, 09:50:05 PM
I installed mine dry.. .no gasket sealant.  I don't know what the "Pros" do or recommend.
The bolts and nuts will need to be checked and rechecked after installation to keep tight.
Quote from: Toybrota on March 26, 2019, 08:03:08 PM
I agree.
Gnarls. :gap:
Toybrota
Quote from: H8PVMNT on March 27, 2019, 03:40:05 AM
I've also heard good things about that copper spray. Did you use it on this style of intake gasket with the rubber rings around the coolant passages? I may install this one dry, and try again if need be.
Toybrota
Quote from: Gnarly4X on March 27, 2019, 03:58:47 AM
Thanks for the tip regarding the bolts.
I'm using the LC engineering kit that uses all studs, with nylon lock nuts. I'll probably replace the nylon nuts with newer ones since these have been taken off a few times.
