Hey T...Glad you are getting the bugs worked out... you are getting smarter by the day! SLC to V is probably around 800 miles. Unless you have a time constraint, I wouldn't worry about your truck.With that said... having it transported is not a bad idea. I have some words of caution for you - I have very close long time friends who have lived and traveled extensively, mostly in USA, Mexico, South America, and Central America. They have shipped their stuff all over, in containers, freight trucking, and by ship etc. Advice: Be sure you completely understand any and all liabilities and risks and WHO will be responsible for a potential accident or other event that causes you a loss. Make sure the shipping company has an excellent and credible reputation. Gnarls.
Post#354 from BestGenGood job. I think it looks great. Your going to be amazed at how much more active the mechanical temp gauge is when compared to the stock Moron gauge (similar to an idiot light but in the gauge form). I will tell you not to be alarmed this summer when you see higher temps on your gauge than expected. I see mine go up to 210 on occasion when pulling a long steep hill.This is completely normal just not show by the stock moron gauge.
22re Performancedual stage OE thermostatThis is a factory thermostat that was created to solve a certain cooling system problem on 22r/22re called "temperature overshoot". It's still a 190 degree thermostat like the original, but it has a second, smaller wax slug to help out under certain circumstances. ready? OK, time to get get bored.... Sometimes when using the heater, the interior fan will drop the temp of the coolant below normal operating temp. The "cooled" water that just came out of the heater core then travels past the thermostat causing the thermostat to close, because it "thinks" the coolant needs to get back up to normal operating temp. This causes your temp gauge to show overheating or wild fluctuations. So, as you can see, it's a pretty specific problem that it's trying to solve. As a daily driver, without this issue, I still recommend the regular OE thermostat I sell. If you are having this above issue, this could be the fix for it. I've been hesitant to add this to the site only for the reason I didn't want people buying it for the wrong reasons (thinking it'll fix their faulty cooling system). You guys are smart enough to know when you need it, so I'll leave it up to you. I have a copy of the TSB from the 80's if anyone wants to see the Toyota technical side. (bestGen)
My 1985 22R ran a 190 to 200 all the time. In the summer it could go to 210. I had an AutoMeter mechanical temp gauge.The temperature rating on t-stat is the temperature that it *begins* to open. T-stats are typically fully open between 15 and 20 degrees above the rated temperature. Toyota specs a 190d F t-stat. It begins to open at 190d F and is full open at 212d F.Installing a lower rated temperature t-stat than spec'd by the auto maker may cause issues with the ECU.It better to install the spec'd t-stat temp rating.Installing a lower temperature rated t-stat only lowers the beginning opening of the t-stat, it still will be full open at 15 to 20 degrees above it's rated temperature.Stant's SuperStat t-stats may provided extra flow based upon their patented Weir valve design.Here's a factory part:https://www.walmart.com/ip/OEM-Toyota-Thermostat-90916-03078/647969343?wmlspartner=wlpa&selectedSellerId=14117&adid=22222222227135785386&wl0=&wl1=g&wl2=c&wl3=244223852551&wl4=pla-455260784767&wl5=9030125&wl6=&wl7=&wl8=&wl9=pla&wl10=118770675&wl11=online&wl12=647969343&wl13=&veh=sem&gclid=EAIaIQobChMIhZy3ud6P4QIVwh-tBh0ouwNIEAQYBSABEgJC3PD_BwEHere's the Aisin 190 Degree: https://www.rockauto.com/en/moreinfo.php?pk=7588520&cc=1277300&jsn=406Here's the Gate 190 Degree: https://www.rockauto.com/en/moreinfo.php?pk=1145455&cc=1277300&jsn=408Gnarls.
Well, I'm almost certain it's just air trapped in the system. I pulled the cap off and let it set for an hour. The antifreeze level dropped. I'm gonna let it set overnight and see how much it drops. Tomorrow I'll also install the stock temp sender and get that hooked up, not that it'll do anything for the situation at hand. I know I can get this fixed, just a matter of finding out how! Sent from my PH-1 using Tapatalk
I doubt you have any air trapped in the system. The coolant level will drop as it cools.. normal.Gnarls.
Well it's not going to hurt anything to upgrade your radiator. I have had slight hot issues that fooled me before with a limp or lame fan clutch.
You will be fine after the new gasket. Toyota factory parts for the win! Again So what Your saying is? The factory gauge is worthless until your on the side of the road overheating? Me JesseBoy I know I sure wouldn't trust it to give any accurate information. Sounds like a moron gauge to Me.
I think the experiment was awesome.I like Definitive answers.Now all the moron gauge people know it’s worthless until overheating and should consider a mechanic gauge and a gauge pillar.
Could you still fit an internal cage Chris? If yes, would the faces still be visible?CB
Started by yota_krawler Project Research and Build-Ups
Started by nicholas99350 Project Research and Build-Ups
Started by Toyospearo « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by Doable Project Research and Build-Ups
Started by Jason E. « 1 2 » Project Research and Build-Ups
