OVRAROK. My 87 4runner
Started by OVRAROK, July 11, 2014, 04:04:18 PM
megaphoneman
Did you get the whole setup or just the pump?
You can have my resivour mount i made if you want it..
Quote from: megaphoneman on March 23, 2016, 09:40:26 AM
just the pump, I'm gathering parts, ill take it, gives me an excuse to go to santa cruz
megaphoneman
oh ok cool! well im getting my link kit today, so trixxie will be broken down asap...and the resivour will need to move...i have  a pic of it some where ill find it..it spretty plain jain...but it works and it uses stock holes to mount..
Quote from: megaphoneman on March 23, 2016, 01:19:31 PM
let me see a pic, I was going to try to mount up as high as I can
megaphoneman
Blaaaahhhhhhhh
Quote from: megaphoneman on March 23, 2016, 04:59:27 PM
Blaaaahhhhhhhh
Hey Marshall, what bracket are you using for the pump
SqWADoosh
I can't make sense of that either. It for all intensive purposes seems to be floating....
It's painted red, I see it, just curious who makes it
SqWADoosh
My money is on Marshall Inc.  :yupyup:
Quote from: SqWADoosh on March 23, 2016, 05:44:46 PM
I think your referring to the resivoir
SqWADoosh
Yes I was talking about the reservoir floating because I didn't see the mount until you pointed out it being red.  :hammerhead:
megaphoneman
haha yall are funny! the resi mount i made.. and the mount for the pump, you use the stock one with a small spacer adapter that goes with the kit. if u got just the pump then you need to get that little spacer.. i can show a better pick later.. and since the resivour is soo big that was the best location for it, as well as being higher then the pump.. but my cross brace for my shock hoops for coil overs will be around that area so i will be custom mounting most my stuff, also a turbo will be right there hehe
Blaaaahhhhhhhh
well, I bought a 3rz swap donor , 500 cash, he just wanted the money he spent for new clutch, New slave, and clutch master
Sent from my HTC One_M8 using Tapatalk
1985CRAWLER
Sweet ! Your gonna love it , let me know when the swap begins I'll come down and give you a few pointers on the swap
If you need some help with the smog stuff, I learned all about it, haha
donor runner is in the driveway  :clap:, pics tomorrow
Had to make a wheel dolly that would roll in dirt, with very limited materials this is it
OTO Phil
How much weight does that need to hold?
Quote from: excabswap on March 30, 2016, 02:19:18 PM
I have no idea, but it worked great, was able to tow with a strap, over a bridge, through some thick dirt, and over some gravel, 4runner in on flat concrete now
Motor had a stumble at idle, think I found the problem
HogCanyonHopper
I have an upper intake if you need one.
#444
Quote from: HogCanyonHopper on April 01, 2016, 02:16:09 PM
I had an extra, cleaned it up. already installed, http://www.youtube.com/watch?v=Iy2I7lX0iZM
Hogcanyonhopper came by to Give a hand. Thanks Joe,
SqWADoosh
Right on, Dave! Based on the mileage of the motor and the fact that it is out and on your shop floor. You should really consider doing the valve adjustment now while it is easily accessible.
Quote from: SqWADoosh on April 04, 2016, 07:57:46 PM
valve adjustment
truck just received new clutch, slave and clutch master, along with valve adjustment,a month before wrecked,the previous owner a Toyota tech
SqWADoosh
Quote from: ovrarok on April 04, 2016, 08:02:06 PM
valve adjustment
Then you are indeed sitting pretty! Throw her in and come to Moab!
Quote from: SqWADoosh on April 04, 2016, 08:03:48 PM
wiring it will be the most difficult part for me, I'm waiting on t100 oil pan kit. going to be using donor fuel rails, heater hoses, all wiring for the most part, should be done with donor truck, by in 2 days
