HAM operator check-in
Started by helipilot77, July 08, 2014, 05:17:35 PM
helipilot77
Don't know why this hasn't been done yet.
Call sign: KG7LUX
Equipment: Kenwood TK-780 Mobil (25 watt)
Dr.Maxwe001
Jeff Maxwell
Tuscaloosa Alabama
KK4SXA
HT= Icom ID-51 Dstar
Mobile= Kenwood TM-V71A
Antenna= RuffRider Hyper Gain
Base= Yaesu 897D
Tuner= AT-897 PLUS * mounted to radio for away from home use*
Tuner= AT-1000 proII
SWR/POWER Meter= FLT Meter *designed for the Yaesu 897D*
Antenna= HF G5RV inverted V 65 ft. up on a fiberglass pushup pole.
Antenna =2 mtr 70cm- Hi Gain Yagi 10db gain
AMP= HF Ameritron ALS 600 with power supply
AMP=144 mhz. Mirage 180 amps
and a list of other things as well to help with the CW AND PSK31
send me a msg on here and we can try to work each other
73 KK4SXA
[img]http://bo
n6dlh
Guess I am late to the party!
Dave
Hampton VA
N6DLH
Run Kenwood TK-790's Mobile
Also run Midland CB I converted to 10m 25W on a Firestick
Run Kenwood TM-281 and TK-890 in the shack
Also have a Icom IC-746pro for HF
1989 4Runner 3rz Swap
Dr.Maxwe001
N6DLH we are with in a close range we should try to work each other in a QSO
[img]http://bo
helipilot77
Thought I would add some photos of my mobile in my 4runner. This is how I decided to mount it.
Dr.Maxwe001
[img]http://bo
helipilot77
chim
I have a Kenwood TK-7150 sitting around, is this a commercial use radio only or can I use it like a normal HAM radio?
I am a complete noob when it comes to HAM, but I am trying to learn..
BenMara
Im local to Charleston, SC.  If im around V/Uhf it camping on 146.52.  I also run V/Uhf in the mobile. Soon to have HF in the Mobile. Mobile is a TS-480 and a FTM-350AR. Base is a Elecraft k3, and a Ftm-350r.
I also monitor the local repeaters, i care to do all my QSOs on HF and on 146.52. Staying away from the local repeater Drama.
helipilot77
Quote from: BenMara on September 26, 2014, 11:34:21 PM
What is your call sign though?
BenMara
I rather not, all you need is a call sign to find out were some one lives.  http://wireless2.fcc.gov/UlsApp/UlsSearch/searchLicense.jsp
But think of all the underage hams, sub 18yrs old. They are minors, and their info is public.   I just think the FCC should keep some of our info away from prying eyes.
Dr.Maxwe001
Just use a PO Box and dont worry about it
[img]http://bo
helipilot77
Dr.Maxwe001
I say we try to work each other on the air HF or Echolink
Whos with me ?
[img]http://bo
Dr.Maxwe001
We need to get a QSO soon on a band
[img]http://bo
helipilot77
FYI: after chasing down an RF noise for a couple weeks I finally found that my Trucklite LED headlights were creating the noise. I will have to shield the back sides of them.
Dr.Maxwe001
I got my ticket for my extra class! Even though i got my paper copy i will feel better when its in the computer and i have a hard copy in my wallet and on my wall
[img]http://bo
BenMara
Quote from: Dr.Maxwe001 on February 08, 2015, 01:20:17 PM
Im in the Same Boat, i just dont feel comfortable saying /AE
Dr.Maxwe001
I am using a G5RV iand made a control box that lets me get on 160 m havent tested it yet but I think it will work  :crossed:
[img]http://bo
BenMara
yea alot of the local Ham are just realizing the advantages of Ladder Line.  As you have a decent Antenna Transmatch, you should be golden
my set up is posted on http://www.qrz.com/db/KK4CRY
Dr.Maxwe001
My NEW UPGRADE is in the computer !!!! Just checked it tonight KK4SXA 73
[img]http://bo
BenMara
Congrats, im still waiting for mine to drop on FCC ULS
BenMara
Finally updated on ULS and paper came within a week...
Phazertwo
Wow, I am a touch late to the party...
KD0JCA
Denver CO
Yaesu FTM-350AR with GPS for APRS
Yaesu VX-6
Yaesu VX-7 (willing to trade for another VX-6)
Picture of the mount for the FTM-350 (Blue cable has been replaced with a black...)
PZ
92 xtra cab, with some stuff...
Quote from: yotabj on October 30, 2006, 10:01:02 AM...why buy when you can build?
helipilot77
Ooooooh! If you have APRS tell me about your setup. I am planning to install APRS in my 4Runner.
Phazertwo
I picked the Yaesu FT-350AR because it has dual receivers, cross band repeat, and is capable of APRS with the GPS antenna.  Cross band repeat is a great function. I use it for boosting the range of my handheld when I am hanging out at my property in the mountains, and I also let it run when the truck is on the trailer, and just use my handheld in the tow rig.  Again this is just boosting the range (handheld is only 5 watts, FTM-350AR is 50 Watts).
APRS was VERY easy to setup, I was actually quite surprised.  I read though the instructions of the radio, set the "beaconing" the way I like, and that was that.  I don't actually use it very often, but it is great for 4 wheeling.  If my wife is not riding shotgun, she can just log into the APRS website and enter my call sign to see where I have been/am.  The track is not always the best because it plays connect the dots and for some reason it doesn't use the time stamp to figure out which dot is next...
If you have some other friends with APRS in the area it is also very useful.  For example, if my buddy beacons, my radio picks up his call sign and plays a jingle telling me he is in radio range.  I don't even have to pay attention the beacons coming in, I just have to listen.  That way I don't have to call him on one of the calling freqs.
Here is the website: http://aprs.fi/#!lat=39.92850&lng=-104.95590.  Punch in my call sign (KD0JCA) and you should be able to see my last track (this last summer, before my truck died).  I would like to figure out a way to send text messages quickly, no reason why really, I just think it would be nifty to be able to text your friends over the radio!
PZ
BenMara
I have the Same FTM-350AR loved it some much purchased a Used FTM-350R, but sold it year later when work dried up...
helipilot77
I am now APRS capable!  :woohoo: I will be hiding this baby in the dash and sleeping much better knowing that I can check the location of my truck whenever I want. Took me all of two minutes to be sending a signal that showed up on googles APRS map.
BenMara
