81 Trekker Build
Started by dropzone, December 04, 2011, 04:24:10 AM
dropzone
Quote from: Cheesemaker on April 04, 2015, 04:04:35 PM
Groundhog Rock Crawl is June 27th.
http://www.deschutescounty4wheelers.com/whatsnew/view/groundhog-rock-crawl-9
Link to last years comp.
http://www.deschutescounty4wheelers.com/page/groundhog-rock-crawl
Not sure if I can make it in June.  Will know closer to the date.  Thanks for the heads up..
81 Toyota Trekker 221:1
dropzone
Went to see Furious 7 today.  Good movie..
anyway Watching some of the clutch work reminded me my pedals were lacking traction so
this
And this:
Made this:
Cheesemaker
I did something similar to my old 85 Nissan.  But I used pop rivets instead.  The issue is, over time, the diamond plate will polish up, and become smooth.  Need either oem pads.  I even tried 3M grip tape, and on hot warm days, the glue would soften and cause the tape to slide.
megaphoneman
dropzone
Quote from: Cheesemaker on April 06, 2015, 07:55:39 PM
i have had this truck 8 years, put less than 8000 miles on it.  I haven't had any luck with keeping the OEM stuff on the pedals.  it will probably be a long time for these to get smooth :gap:
Quote from: megaphoneman on April 08, 2015, 08:51:01 AM
small dimple dies...
that is a possibility if i pick up a small press in the next couple of months..
megaphoneman
fyi.. most dimple dies can be used with nut and bolt...
dropzone
Quote from: megaphoneman on April 10, 2015, 11:29:46 PM
cool, thought you had to have a press.  may pick up a couple of the smaller sizes sometime if I can find a decent price down the road
added a set of MRAP retractable shoulder harnesses.  Should make the trail a little  safer and more comfortable than the normal 4 point harnesses.
The anti sub belt will be removed
dropzone
#337
haven't really done much to the truck lately.
After paying $42 to refill my CO2 tank I started looking for alternative fast air sources.I thought about a Viair system but didn't think $400 was worth it.
Decided to give ebay a shot with a seller I have had good luck with in the past, picked up one of these, only bidder at $99
Heavy Duty 150PSI Portable Air Compressor 12V High Volume Extreme 35" Tires | eBay
It basically looks like a generic Super Flow MV-90
it sucks a ton of juice but is fast
Filled the empty 35x12.50 from 0 to 30 psi in a little over 2 minutes
SqWADoosh
Quote from: dropzone on May 22, 2015, 06:07:14 AM
This looks like the same one that Smittybilt sells. My local 4wheelparts guy was talking these up making claims similar to what you are confirming above. Maybe he wasn't bullshitting me after all. Your ebay link doesn't work above buddy.
dropzone
I'll have to repost the link from a PC.
Sunday night replaced my tie rod ends, took it for a test drive..life was good.
Headed out monday for a Run out at Tillamook State Forest and all was fine until about 2 miles from the meet up spot and had death wobble from hell..checked lugs and they were fine.
turns around and drove the 20 miles or so home not being able to get above 30..it sucked.
Scored a set of trunnion bearing eliminators cheap so started the tear down today.
They look pretty good compared to the stock bearing, finding someone local with a press may be a challenge though
Dirty 30's were installed about 6 years ago by a local guy who needed some $ and I didn't have time.
He didn't mention that the driver side must have had a blown birf at some point, not chunked up too bad bUT not as clean as the p/s
drivers side
Passenger side
Axles came out now And easy and looked awesome
It was nice to see the inner axles seals still in good shape
SqWADoosh
dropzone
dropzone
Haven't had a lot of time lately.
picked up a HF 12 ton press that made short work of the pivot pins
redneckcustoms13
Alot better than a hammer
01 double cab hunting truck
06 tacoma street truck
dropzone
So been moving slowly forward on the slowest front end rebuild.
My first grandson finally entered the world, Meet Tatum my future wheeling buddy
Tatum
He and his mom are living with us so household will be going through a few changes. ..
Thrilled my wife with this in the sink
My new favorite cheap tool
got a little bit done, pressed the trunnion bearing Elinator studs in the steering arms
Hitch mounted vice
SqWADoosh
Quote from: dropzone on July 09, 2015, 07:34:32 PM
Tatum
Congrats! Looks like a healthy boy there.  :beerchug:
chim
Nice name, that's mine as well :)
dropzone
Thanks Guys.  Became a grandparent a few years earlier than expected but sure wouldn't trade it for the world.
been spending a lot of time with Tatum, but need to get the truck back on all fours.
I was trying to talk the missus into an ARB equipped third for the fronT since the front end was already apart but negotiations were unsuccessful  :mad:
Oh well
Scored a used Galaxy Tab 2 10.1 in awesome shape dirt cheap that should come in handy
download the FSM and will make some procedures easier
Download some trail maps and it can also double as a big GPS
Cheesemaker
Nice!  I been thinking of getting a tablet lately.  There are times I am in the shop, and need to look up something part wise, or troubleshooting, and I have to run back to the house to look it up.  A tablet would make things easier.
LittleSteve
Quote from: Cheesemaker on July 22, 2015, 10:06:16 AM
I have a tablet but there only good if the shop is in range of the wee fee,  if you want FSM's hardcopy is the way to go, they dont ask permission to do anything, dont go flat just after youve walked thru the shop door, they dont make stoopid noises and dont mind being dropped or if you drop tools on them, they also have the same information on them every time you open them and dont refresh or lose the page your looking at every damn time you pick it up, you can also turn the page and it will actually have the info your looking for on it, not 'internet connection lost'
Im not bitter, honest.
Oh and they make better fly swats than a tablet.
Refusing to fit in or comply.
Easy is not worth anything.
Wainiha
dropzone, where are you getting the FSM?  I need one for an 05 taco
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
OVRAROK
Cheesemaker
Little Steve, I have a phone line and a WiFi in my shop.  It's my little happy place.  Stereo, fridge, BBQ's, and tools.  What more does a man need?  Well there is that, but things dry up after a while, and hence the reason man needs a shop, to take his mind off things.
SqWADoosh
I have switched to using the girl's galaxy tab coupled with Gaia GPS loaded with gps tracks of Tillamook and Naches on the last 2 trips. It has made the navigation on the trails 10 fold easier. Of course I always make sure to have a paper map backup however with this route the girl gets to be more involved (navigator) and not bored so easily. Also I haven't gotten lost yet using this method. I'm pretty sure I'm hooked on it.
megaphoneman
hey do you have some input on how you mounted your cage/body? and what works what doesnt for the fiber glass body?
dropzone
Hey Marshall-
Here you go
Frame to fender well mount
Center hoop
Haven't noticed any cracking in the fiberglass.
Something like this would probably be the way to go
megaphoneman
yea! thats excatly what i want to do but the other way.. the bushing will be at the frame..
Blaaaahhhhhhhh
megaphoneman
but img glad to know you had success doing it with just hard mounts
Blaaaahhhhhhhh
dropzone
SqWADoosh
Quote from: dropzone on August 13, 2015, 05:03:41 AM
Below are some of the online FSM's I have found, saved to a local forum
http://gitout.com/showthread.php?1980-Toyota-Service-Manuals-Online
Here is an online version of the 05-06 Tacoma
http://www.ether3al.com/taco05-06fsm/
93 Toyota Truck Factory Service Manual
http://www.ether3al.com/93fsm-mobile/
Another 93 link
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
3th Gen 4Runner 96-02 Service Manual
http://www.ether3al.com/runner96-02fsm/
1985 Carb Truck & 4Runner Download
http://www.precision4wheeldrive.com/1985FSM.pdf
1983 Truck Download
https://www.rapidshare.com/files/141...ckup%20FSM.zip
Web archive
http://web.archive.org/web/200807310...ttora.com/fsm/
includes download links!!
1990-1995 4Runner
http://web.archive.org/web/200808020...5/contents.htm
1999-2000 Tacoma
http://web.archive.org/web/200806220...000/index.html
2001-2004 Tacoma
http://web.archive.org/web/200809151...003/index.html
2007 FJ cruiser
http://web.archive.org/web/200807311.../FJ/index.html
I have the pdf form of the 85 4Runner (EFI) and 88 Pickup I can send your way to add to the list.
